make light corner
Corner light make
Hello !
I have the 2015 Astra j NB 1.4 140 hp. I have no AFL headlights in my car. Halogen lighting. I want to make an application like the link I gave.
Using existing fog lamps I want to make steering-sensitive cornering lighting. For this purpose, the directional trigger cable for the headlamp cables I don't think so. I have it with the arduino kit to read the signal from the steering angle sensor and turn on the corresponding fog lamp I want to make a module that will allow. However, I do not know if the steering angle sensor is connected to the BCM or where it is connected. Many forums I searched but could not find. I need to know where the cable coming from the steering angle sensor goes, the position and the socket outlet find. BCM socket diagram if connected to BCM.
I am sorry for my English. I used a translation program.
Thank you in advance for your interest.
https://www.youtube.com/watch?v=xlexbzZaVUE
Does help you?
[Image: High%20Speed%20Chassis%20CAN.jpg]
İlginiz için teşekkürler Bay Rusty
İyi işler
Thank you for your interest, Mr. Rusty
Good work
  Rear light power problem phlyer 1 5,181 21:st-Dec-2023, 08:27:49
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 16,459 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 5,103 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  Eco button light flashing jw021979 6 12,103 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  Rear light out but works again with headlights Willcbrbikeboy 6 10,101 14:th-Jan-2019, 09:43:44
Last Post: vocky
  ESC and Engine Light Acond 2 7,761 16:th-Nov-2018, 19:32:48
  Service power steering warning light. R4hulb 4 23,479 23:rd-Mar-2018, 13:01:58
Last Post: R4hulb
  Boot gate light GTC13LFP 1 4,968 16:th-Nov-2017, 21:26:22
Last Post: Iaintruten
  Problem reverse light Keith2017 6 18,345 1:st-Apr-2017, 17:55:16
Last Post: Keith2017
  Green Auto Wiper Light DaPa 12 14,891 13:th-Nov-2016, 13:20:42
