check door making strap right clicking noise front stop
DOOR CHECK STRAP STOP FRONT RIGHT Making clicking noise
Hyper hi Guys,
I am having noise on the driver side door and it is making clicking noise. Do I need to replace it or I can twist and remove it
(4:th-Aug-2019, 19:56:56)caretaker Wrote: Hyper hi Guys,
Please see attached pictures, as I could not upload the pictures from ipad. I was watching you tube on the Vectra and the guy was turning around the check strap door hinge.
I don't know if you can do this on this particular model Astra j elite 2011 Model.
Sorry I could not upload the image, so I have used the external website, so you can see the image.
https://imgur.com/WLxkGJS
https://imgur.com/UW1tdT9
https://imgur.com/SIRHTV3
https://imgur.com/g4IP7it
https://imgur.com/MPDz6kg
Hi, mine has just statrted clicking, but on closer inspection the bolt that holds it to the A pillar is loose,
I'll have to tighten it tomorrow and see what happens
I've just tightened the retaining bolt and my noise has now stopped.
Hi Niteram,
Mine still makes the clicking sound, as I tighten the bolt and still makes the sound , so now I need to change the right hand strap and I think I will have to remove the trim card off from the door.
Thank you for your reply.
  How do you check gearbox oil on A20DTH/160ps? Vx-Mad-G 3 6,608 7:th-Dec-2020, 08:12:26
  front brake discs bgb65uk 4 5,233 23:rd-Jul-2020, 10:56:25
  Head repair weird air noise? trevorgetty@aol.com 5 7,907 1:st-Apr-2019, 15:39:45
Last Post: trevorgetty@aol.com
  Front coil springs ericzed1962 0 3,457 11:th-Nov-2018, 21:23:40
Last Post: ericzed1962
  ghost noise twisted spanner 6 9,180 2:nd-Apr-2017, 20:50:46
Last Post: jason.dexter
  GTC 2.0 cdti front pads tatters40 1 7,009 7:th-Mar-2016, 22:04:02
Last Post: irmartyn
