2.0 CDTI Stop/Start and the DTUK RED BOX
Vauxhall have issued an update for the ECU for all 2.0 CDTI 160/165Ps with Stop/Start.
There has been reports that this is stopping the DTUK RED BOX working correctly, DTUK are aware of this and have worked on a fix for it although the fix might not work for all at this time.
I emailed DTUK this morning to find out where I stand as I already own the box I was told
[quote]You'll just have to wait and see what happens once the car is serviced in September as there is no pattern. Some cars are a
How to stop Smelly air-con
I can't take the praise for this one as such, although mine is slightly different to the how to guide available elsewhere on the Internet.
Here goes: For a few months I have had a bad smell from the air con after it has been turned off, especially the day after. I understand this to be a build up of bacteria within the system, but I hadn't realised how cheap and easy it is to resolve.
Firstly, buy a can of this [ATTACH=CONFIG]242[/ATTACH] which cost me £3 from Asda. I understand it has been
How to Stop brake Squeal, Astra J.
This How to covers How to stop Brake Squeal
and How to Grease the slider Pins and Pads and Shims This will stop the Pads from Sticking and making Noise
And will also keep your Brakes in tip top Condition .
SLIDER PIN GREASE. Silicone grease.
[url=http://www.ebay.co.uk/itm/271642430344?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT]http://ww
How to stop Interior Trim Rattles from Passenger side area Astra J.
This How to will Stop Rattles that Appear to be Coming from the Seat Belt or A Pillar Area.
For a while now i have a Wired Rattle that seems to come from the Passenger Side Area
Around the Seat Belt or A Pillar Area and i have not been Able to Put my Finger on were Exactly it has been Coming From
[img]http://i179.photobucket.com/albums/w301/tucpal/trim%20sp%20006_zpsbagsk
Start/Stop
Has anybody else had issues with their SS where it doesn't kick in?
Mine seems to only be working as and when it wants to with no obvious pattern.
I have no warning lights and as far as I can tell there should be no reason for it not to work as intended.
Just has my battery tested as that's the only thing I can think which I'd causing the problem. Came up saying replace on the test machine.
Just over 4yrs the battery has lasted.... Not good!
Sent
Astra gtc wiper and start stop not working
I have a 2012 astra gtc with 27000 miles. My service light is on however i do not need one as it has just been serviced however when the light is on my start stop wont work it just doesn't do it and my wipers will only work on the last highest settings thats it (my back one works fine) however the light in the past has turned off for the odd minute or 2 and everything works fine then but it comes back and they don't work again. I was wondering if anyone knew a solution or what the problem is. Th
Start / stop
Hi guys..... sorry if this as been asked but I have searched but to no avail.
I have a gtc 2.0 cdti Sri with start / stop..... my question is =
Is it more economical to use the start stop or just let the engine tick over ? I know it has been designed to have start / stop but surely it isn't very good for the engine mounts / glow plugs and everything else really keep stopping and starting ..... I know it may sound a bunch of stupid questions but it's more curiosity
Thanks in advance
What would cause stop/start to not work?
As above, on an Astra-J 2.0 CDTI, what would cause the stop/start to not work? I have seen 3 now, which have stop/start but it hasnt worked on the test drive, evernthough the car is warm and performs as it should?
Thanks.
"Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please
Hello, thanks for allowing me to join your forum.
I have a 2013 Astra Tourer Auto 2.0 CDTI SRI which I'm very fond of and have owned since Sept 2016.
It's been faultless in the time I've owned it, and has done about 54000 miles, normally goes very well, and has full Vauxhall history.
Today, however after an 8 mile drive at fairly low speeds it broke down.
I had just negotiated a roundabout when a message came up on the display "Stop Vehicle Immediately Engine Has Overheated"
I pulled
Power loss and stop start not working
Hey guys
I have a 62 plate astra J 2.0 CDTI.
I have noticed a few things and wondering of could shed some light on things to check.
1) my rev needle is sitting at 500 revs (not sure if that is low and then at times it fluctuates.
2) when driving and trying to set off it just doesn't seem to have the same power. It's intermittent but at times the power just don't feel there
3) The automatic stop start doesn't work anymore, or shall I say majority.of the time it doesn't work and then here an
