cluster issue light j cdti line 7 astra 1 tech rear
Astra J 1.7 CDTI Tech-Line rear light cluster issue
I hope someone can assist. Is there anyway to completely open up the rear clusters.
I have an odd issue where my brake light clear section has snapped in both the rear clusters and rattles around within the larger cluster. I have removed both but after removing the group bulbs out the  rear I cannot find how to disassemble the rest. It looks like anti tamper screws have been used.
Not so much an issue but it keeps on knocking on the brake bulbs and causes intermittent errors when starting the car suggesting rear brakes are at fault. I then have to remove the cluster and secure the bulb back in for a period of time until it happens again.
Any suggestions on this or is it new cluster time on both sides?
Regards
Only way to fully open them is in the oven.
  P0171 error and ESC light on Rymaan82 0 3,473 1:st-Aug-2021, 17:57:49
Last Post: Rymaan82
  Passenger Door won't open - Astra GTC everson38 6 6,695 17:th-Jun-2021, 13:05:42
  Reverse light bulbs cl0ned 6 7,442 15:th-Feb-2021, 19:15:34
Last Post: loeb
  DPF problems cold weather 1.7 cdti 110 hp A17DTE seekar 1 5,479 19:th-Dec-2020, 22:27:52
Last Post: Kiel0777
  Astra J Total power loss Galway11 2 5,694 15:th-Dec-2020, 16:37:26
Last Post: Galway11
  rear fuse box paula9568 2 4,632 18:th-May-2020, 12:20:52
Last Post: paula9568
  Astra J Power Sounder dawks 4 7,919 20:th-Nov-2019, 18:27:56
  Rear brake pad replacement - Few Questions everson38 3 6,832 26:th-Aug-2019, 09:51:09
Last Post: everson38
  Astra J 1.7cdti - oilk catch can milika 0 5,149 2:nd-May-2019, 23:27:18
Last Post: milika
  Astra J 1.7CDTi - Boost sensor location for Chipbox jason.dexter 8 13,704 4:th-Feb-2019, 14:40:25
Last Post: rlievens
