questions pad few brake rear replacement
Rear brake pad replacement - Few Questions
Hey guys I have a Astra gtc 2013 1.7 diesel .
Looking to change my rear brakes and got a few questions. Does anyone know the:
1) Torque specs: Brake caliper bolts
2) Torque specs: Caliper Bracket bolts
3) Torque specs: Wheel bolts
3) Winding back rear calipers : Clockwise or anti clockwise?
Any other tips that you think are important feel free to chip in. Thanks again
(24:th-May-2019, 13:28:48)everson38 Wrote: Hey guys I have a Astra gtc 2013 1.7 diesel .
For anyone else who see this. The wind back is clockwise. I do bracket bolts to 100nm and one good grunt of a pull and the caliper bolts to about hand tight. Bought 30nm u would say. All seems good and ready
1) Torque specs: Brake caliper bolts 28 N·m (21 lb ft).
2) Torque specs: Brake hose-to-calliper bolt = 40 N·m (30 lb ft).
3) Torque specs: Caliper Bracket bolts = First pass to 100 N·m (74 lb ft) second pass to an additional 60 - 75 degrees.
4) Torque specs: Wheel bolts = 140 N·m (103 lb ft).
5) Winding back rear calipers  = Clockwise
I know it's a little late but official Torque settings.
Thanks again. It still helps or may help someone else.
  rear fuse box paula9568 2 5,134 18:th-May-2020, 12:20:52
Last Post: paula9568
  Astra J 1.7 CDTI Tech-Line rear light cluster issue AstraCDTI 1 8,925 29:th-Aug-2018, 07:27:16
  Check brake lights Iaintruten 2 10,447 14:th-Jan-2018, 20:56:10
Last Post: Iaintruten
