lights wiring diagram internal
Wiring Diagram [Internal Lights]
Does anyone have a wiring diagram for the astra J?
I am looking for ignition power for a dash cam, hopefully within the map lights area?
Hello cubez,
You might want to check my thread from a few weeks back.
Note that I haven't been able to install the dashcam yet due to lack of time.
https://www.vxoc.org.uk/forum/Thread-Wir...power-from
I will probably end up wiring the dashcam to the cig lighter in the center console.
As this keeps powered on even when the engine stops running but also turns off when you remove your keys.
Cheers i saw that when i was looking though.
I just wasn't too sure about if the power would be there on the key or not.
There are devices now that will power a dash cam from the OBD port.
eg, https://www.ebay.co.uk/itm/OBDII-Micro-U...2717034030
https://www.ebay.co.uk/itm/OBDII-Chargin...2821323516
https://www.ebay.co.uk/itm/OBD-HARDWIRE-...3672876788
There are different ones, depending on size of USB connector on the dash cam. You'll just need to do a search. They all offer Low Voltage Input Protection where if the voltage drops below a certain amount it will shut down to save flattening your battery.
Also, some have switches on to enable you to leave the dash cam powered up all the time, or to switch off after approx. 1 hr.
  wiring info niteram 2 3,774 17:th-May-2020, 14:19:45
  puddle lights marky79 2 2,936 29:th-Nov-2019, 00:46:59
Last Post: Collster
  Rear registration lights LegendOfEagle 2 3,404 7:th-Feb-2019, 17:42:57
Last Post: LegendOfEagle
  Wiring diagram Badenj 1 3,997 19:th-Oct-2018, 11:16:07
  Sports tourer open boot flood lights - where to connect? umognog 7 6,587 2:nd-Apr-2018, 19:15:02
Last Post: umognog
  Schematic Diagram needed vagepap 5 5,697 28:th-May-2016, 16:16:30
Last Post: vagepap
  Footwell lights hungrydiscus 5 5,805 26:th-Apr-2016, 18:26:05
Last Post: hungrydiscus
basem_mostafa_mosallam (8:th-Oct-2024, 22:53:00)
