lights footwell
Footwell lights
So looking at putting footwell lights into my new ride and I've read and re-read through the how tos. When looking through pages and pages of stuff on eBay I stumbled upon these...
http://pages.ebay.com/link/?nav=item.vie...47&alt=web
What do you guys think?
Too bright?
Can/cant be wired up to come on with the courtesy lights?
Tucpal: any thoughts?
P.S. I'm completely clueless when it comes to this stuff haha.
Sent from my Nexus 10 using Tapatalk
There ok but the ones linked are Better
Those ones are would work although you would probably be better off buying LED strip light like these
http://www.ebay.co.uk/itm/2x-12V-3W-5050...zZwM3aPPqg
All you would need to do is crimp the connectors onto the wires and then run the wiring up to the interior lights. then make sure you get a secure live feed and an earth.
Sorry I haven't been on for a few days; had an oil leak on the new GTC which turned out to be the oil filter seal. Dealer sorted it today with no problems so all good now
@tucpal, I was a little put off by the ones linked because @tonto mentioned in one of his posts that they were a bit dull but I appreciate your help
@shortys91, by crimp do you mean splice and tape up or should I use scotch blocks? Do scotch blocks actually cut the wire or do they simply form a connection between wires?
(26:th-Apr-2016, 14:52:29)hungrydiscus Wrote: Sorry I haven't been on for a few days; had an oil leak on the new GTC which turned out to be the oil filter seal. Dealer sorted it today with no problems so all good now
Personally i would stay away from scotch blocks. I'm meaning if you buy bullet terminals like these
http://www.ebay.co.uk/itm/100-Red-Bullet...ZUFXZO7zrg
you can crimp them onto the ends of the wires to bridge the connections and then all you would need is some wiring to run up to the interior light
Thanks, @Shorty S91, they look spot on. Looks like a nice mini project on the horizon
  Footwell full of water Benthomas 16 22,335 17:th-Feb-2021, 07:10:32
Last Post: Mk101
  puddle lights marky79 2 4,361 29:th-Nov-2019, 00:46:59
Last Post: Collster
  Rear registration lights LegendOfEagle 2 5,335 7:th-Feb-2019, 17:42:57
Last Post: LegendOfEagle
  Wiring Diagram [Internal Lights] cubez0 3 7,090 25:th-Jun-2018, 11:28:03
  Sports tourer open boot flood lights - where to connect? umognog 7 9,499 2:nd-Apr-2018, 19:15:02
Last Post: umognog
