wiring diagram
Wiring diagram
hi can anyone provide me with a wiring diagram for the a20dth engine.
I need to find what pin on the ecu is for the lambda sensor and test from that end.
Many thanks.
Please see attached.
  K20 Engine Control Module X1 (LBS).pdf (Size: 44 KB / Downloads: 23)
  K20 Engine Control Module X2 (LBS).pdf (Size: 37.43 KB / Downloads: 17)
  wiring info niteram 2 5,022 17:th-May-2020, 14:19:45
  Wiring Diagram [Internal Lights] cubez0 3 7,190 25:th-Jun-2018, 11:28:03
  Schematic Diagram needed vagepap 5 7,661 28:th-May-2016, 16:16:30
Last Post: vagepap
dellpiron (27:th-Apr-2025, 19:22:33)
