problem with drl
Problem with DRL
Hi guys
I have an issue with my Daytime Running Lights. When the light switch is set for just the DRLs, the passenger side's DRL doesn't work at all. If I switch to the park/side lights, they work fine (and are dimmed as they should be). If I switch to dipped beam, then both the DRLs are on along with the dipped beam. Could it still be the bulb or is it something else?
The bulb is due filament so sounds like the drl filament is gone
(18:th-Sep-2017, 15:53:23)Rusty2009 Wrote: The bulb is due filament so sounds like the drl filament is gone
Even though when I have my dipped beam on, the passenger DRL then works fine?
It's not your DRL it's your sidelight.
DRL's are only one when the lights are off.
Turn to sidelight the DRL dips down to the lower filament in the bulb (DRL go's off)
Switch to dipped beam sidelight stays on and dipped beam come on (DRL remains off).
Right, okay. I'm following now. I was thinking of getting some better bulbs anyway, as these are extremely yellow. Thanks for your help
Same as mine but mine are leds
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 3,886 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Injectors or SCV problem? kartush45 1 4,655 11:th-Mar-2020, 11:08:58
  Electric Window intermittent problem Stanhope 3 6,996 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  Astra J self starting problem Jopo2311 8 7,935 16:th-Mar-2019, 10:29:33
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 18,244 26:th-Sep-2018, 23:50:59
Last Post: everson38
  Can't get in gear - clutch problem? klargon 0 4,865 9:th-Dec-2017, 16:21:11
Last Post: klargon
  Intermittend starting problem eliasvdv 2 6,826 18:th-Jun-2017, 10:48:13
Last Post: eliasvdv
  Astra J Infinity Sound problem abba34 9 11,565 11:th-Mar-2017, 17:59:21
Last Post: abba34
  CD400 reception problem MDS2017 3 11,145 3:rd-Mar-2017, 21:00:27
Last Post: GOKIWI
  Astra Gtc 1.4t clutch problem Wayneofwolves 2 6,374 25:th-Feb-2017, 09:16:33
Last Post: Wayneofwolves
