problem sound j astra infinity
Astra J Infinity Sound problem
Hello,
I just bought an Astra J 1.6T (2009) with an infinity sound and a DVD800 system.
If noticed that the volume varries, also when the auto volume control is tunes off.
Is there any way to fix this issue?
Have you tried adjusting the settings and tone setup?
Yes, I did change them.
When the volume is rather high, it will increase volume up by itself. The volume automatically good up and down.
Is it related to the speed you drive?
No, it just changes randomly.
Very strange the Infinity setup is a rare option, I'm in the throws of retrofitting it.
I'll have a look on TIS but I doubt there will be anything on there.
I've specially bought the car with this option, because audio quality is high on my list.
I hope you can find something on TIS
And did you find anything on 'tis?
I've noticed that it's more noticeable when I listen to an USB device or when I play a cd.
I have to turn the volume up more the hearse the same loudness.
I the a source level adjustment hidden somewhere?
No as I suspected nothing on TIS.
There is a test mode but I can't remember how you get into that but it may show you something.
I have Find Someting on the net about it: https://m.facebook.com/My-Infinity-Sound...185963753/
Aperantly it is a problem that is there for a long time
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,704 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,627 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,083 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,962 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,941 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,521 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,363 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,457 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 7,125 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,147 24:th-Jan-2021, 14:44:22
c4nny (24:th-May-2025, 00:10:37)
