Sound Proofing
I am thinking about sound proofing my car as I do a lot of motorway driving and find the road noise quite bad.
Basically the plan is to get http://www.amazon.co.uk/Silent-Coat-Soun...d+proofing and stick it inside the doors and boot.
Has anyone done this? Are there any better ways to reduce road noise?
Matt
Headlights Levelling Sound
So the only issue I've noticed with my new headlights is that one of them seems to make a sort of mechanical noise when the engine is switched off... Sort of like it's trying to auto level or something... Any idea why this is?
Infinity sound system parts
WANTED.
I'm looking for all the Infinity sound system parts from an Astra-J Hatchback 5-door
So all speakers (incl sub-woofer and housing) plus amp
A bonus if the whole interior loom and boot trim panel.
part numbers are.
x2 13264618 front tweeter speakers
x1 13240954 centre dash speaker
x2 13240968 front door speakers
x2 13308350 rear door speaker
x1 13340344 Subwoofer
x1 13265735 or 13352132 Amp
x1 13311895 boot Trim
Bluetooth - what are my options with infinty sound
I have just bought an Astra GTC (2012) and it doesn't have bluetooth as part of the spec. I've done loads of searching but haven't been able to find an answer to my question.
My GTC has the CD400 HU, with Navi 600 and infinity sound system are there any options to fit bluetooth if it's an aftermarket system (Parrot, Bury etc.) any info on leads required?
Rich
Astra J Infinity Sound problem
Hello,
I just bought an Astra J 1.6T (2009) with an infinity sound and a DVD800 system.
If noticed that the volume varries, also when the auto volume control is tunes off.
Is there any way to fix this issue?
Engine sound
Hi I have a 12plate 1.6t astra gtc and the engine sounds like it is about to overheat or the fan is working overtime, it is very loud and my friend said that when I was outside his house it sounded like a fighter jet, I have checked the water levels and they are all fine could sound one please help me
How to Astra gtc 2.0cdti sound loud and good
Hi I m new here but I wanted to know how could I make my Astra gtc 2.0 cdti sound Sporty and loud not to loud tho
And still being able to pass the mot
V5754: Indicator sound not loud enough
Hello all,
does anyone have a solution for the almost unhearable indicator sound that the little extra speaker produces.
I put it right below the unit, right behind the cover and it still is barely audible when I'm listeining to music.
Is there a secret setting in the options? Has anyone replaced the speaker?
Any help is appreciated.
Water sloshing sound
So I've noticed since I picked my Astra Tourer up at the weekend that I can hear a very occasional noise which sounds like water sloshing about if I pull away a bit quicker than usual. I've had a good google search and think it's probably inside the doors, now I've seen that to rectify this you can remove the rubber grommets at the bottom of the doors and give them a good clean. My question is, would it cause any problems if I left the grommets out altogether, or are they there for a reason? If
Flapping Sound when driving.
Hello Everyone,
I do have an Hatchback Astra J 2015 1.4NET with auto transmission.
I did detected a flapping noise like as you are driving something stick on the tires or it sounds like there is some lines on the road and you are passing on them.
I know it's a very low chance find this kind of a sound issue without hearing it but I'm out of ideas to tell to service to check.
So I made below checks and fixes:
- When I first noticed the sound I re-balanced the summer tires on th
