to throttle map body maf valve sensor identify need egr
EGR VALVE, MAP SENSOR, MAF SENSOR, THROTTLE BODY NEED TO IDENTIFY
Hi Guys,
I did have a look at Tucpal post, but i wasnt sure on mine, as it slightly different, so i have uploaded the picture to see how i can service and clean these parts.
I just wanted some information how to service my car EGR Valve, EGR Pipe, Throttle body ,  Map Manifold pressure senser.
I wanted some advice or if anyone done a 1.7cdti Elite 2011 , 61reg, as i want to do my service.
Thanks Guys.
the last pic is your egr
the map sensor will be on the inlet manifold
and the egr pipe will be near the egr
pic four is the throttle body
Thanks Tucpal for your reply, as i never realised i got a reply.
  Lowering springs identify front rear martinpe68 1 4,071 12:th-Sep-2021, 15:22:37
  Brake pedal sensor learn. Richiew1986 0 2,971 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Oil Leak at Intercooler pipe / Throttle body everson38 0 3,981 9:th-Jun-2021, 23:26:09
Last Post: everson38
  parking sensor Qaranc 1 3,834 8:th-Feb-2021, 01:33:43
Last Post: loeb
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 7,969 2:nd-Feb-2021, 21:12:47
  Intermittent start, stalls after clock sweep no throttle response Jump to Latest Brendonm9477 5 8,620 5:th-Jan-2021, 13:55:10
  Glowplugs with pressure sensor or not Euroshopper 3 5,650 2:nd-Nov-2020, 16:01:21
  Fuel Shutoff Valve NuttySqurill 1 3,670 12:th-Aug-2020, 07:58:08
  DPF pressure sensor richardhmorgan1 3 6,946 24:th-Sep-2019, 20:08:31
Last Post: Saunter
  Cracked tyre valve with TPMS Craig2305 5 7,601 5:th-Oct-2018, 13:31:48
Last Post: Craig2305
