2.0 CDTI, EGR VALVE, MAP SENSOR AND THROTTLE BODY CLEAN
[align=center]HOW TO CLEAN THE EGR VALVE AND EGR PIPE AND MAP SENSOR AND THROTTLE BODY AND MAF SENSOR.
This How To will cover The Process of cleaning the EGR Valve
And Related Parts Needed if you are having EGR Related Problems
on the 2.0 CDTI Engine But This is also a Recommended Thing to do Every 10 or 20.000
EGR VALVE, MAP SENSOR, MAF SENSOR, THROTTLE BODY NEED TO IDENTIFY
Hi Guys,
I did have a look at Tucpal post, but i wasnt sure on mine, as it slightly different, so i have uploaded the picture to see how i can service and clean these parts.
I just wanted some information how to service my car EGR Valve, EGR Pipe, Throttle body ,  Map Manifold pressure senser.
I wanted some advice or if anyone done a 1.7cdti Elite 2011 , 61reg, as i want to do my service.
Thanks Guys.
Throttle body problems
If the throttle body is connected I get poor idle ruff idle and stalling when I disconnect it it's fine any body had issues cheers ?
Intermittent start, stalls after clock sweep no throttle response Jump to Latest
Hi Guys,
Like most I’m here cause I have a problem!
new here and to Astra’s apologies for lengthy post,
I have 2013 Astra J 1.7cdti..
[color=#3333cc][size=small]came to me as non runner and someone had attempted to remove injector 3but they unscrewed the top didn’t even take the rocker cover off! Anyway new injector
Oil Leak at Intercooler pipe / Throttle body
Hey guys
I have a 1.7 62 plate GTC. I have noticed there is a semi decent oil leak coming from the underside of the pipe , where my intercooler pipe meets my throttle body. The issue is, that the clamp seems to be in fully seated and there is no o ring so why is it leaking? I doubt it's a split hose as it was replaced a a couple years back for a new one at the garage where I bought the car?
Any ideas?
Thanks in advance [IMG]https://uploads.tapatalk-cdn.com/20210609/7eacd31e427b601533617216
