Servicing the egr valve. .
. .can this be done on a 1.7 CDTI..
Jj0063 - Replies:
Has anyone blanked an EGR on a 1.7?
So my 1.7 CDTI 125 is idling funny & I'm wondering if the EGR is playing up. Has anyone blanked it on this engine? I'm not fussed about having the EML on but wondered if it's as easy as it looks? (To me, EGR looks to be to the right of the engine cover right on top of the inlet?
tucpal - Replies:
2.0 CDTI, EGR VALVE, MAP SENSOR AND THROTTLE BODY CLEAN
[Image: http://i179.photobucket.com/albums/w301/...5fce57.jpg ]
[align=center]
HOW TO CLEAN THE EGR VALVE AND EGR PIPE AND MAP SENSOR AND THROTTLE BODY AND MAF SENSOR.
This How To will cover The Process of cleaning the EGR Valve
And Related Parts Needed if you are having EGR Related Problems
on the 2.0 CDTI Engine But This is also a Recommended Thing to do Every 10 or 20.000
Blank/Remove EGR
Anyone know what the best method is to blank off or fully remove the egr on these cars?
Ta
EGR VALVE, MAP SENSOR, MAF SENSOR, THROTTLE BODY NEED TO IDENTIFY
Hi Guys,
I did have a look at Tucpal post, but i wasnt sure on mine, as it slightly different, so i have uploaded the picture to see how i can service and clean these parts.
I just wanted some information how to service my car EGR Valve, EGR Pipe, Throttle body , Map Manifold pressure senser.
I wanted some advice or if anyone done a 1.7cdti Elite 2011 , 61reg, as i want to do my service.
Thanks Guys.
Egr removal
Hey guys, anyone removed the egr from a 2016 insignia or one with the b20dth engine? Seems it's well hidden and hard to get to.
Want to give it a clean.
1.4t EGR
I currently keep getting a underboost error on my 1.4t.
I am looking to clean my egr valve as the error points to that. But I can find naff all about the valve on this engine. Where is it and how can it be removed? Anyone got tips or even better a link?
Does the egr need to be deleted in the ecu if blanked on this engine?
Thanks,
Ben
