| Welcome, Guest |
| Forum Statistics |
» Members: 12,317
» Latest member: lar77
» Forum threads: 4,566
» Forum posts: 49,709
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
| electric heated seats |
Posted by: Budd - 17:th-Apr-2020, 10:37:12 - Forum: Medium cars Astra, Cascada, Vectra, Monaro & Insignia
- Replies (4)
Hello all, i retrofitted full leather interior on my 2012 insignia, easy enough, but now the electrics!! got the buttons for it on the dash (retrofitted as well) any ideas on the electric side how to make them work (the heated system, as the rest works).
got the receiver for the plugs for the seats of the donor car as well.
many thanks
| Astra Issues – Faulty thermostat? |
Posted by: dmort - 15:th-Apr-2020, 09:36:50 - Forum: Astra-J/GTC
- Replies (1)
So, my Astra A16 LET 1.6 Turbo recently sprung a leak as the thermostat housing had split.
Replaced the thermostat and housing and the 2 temperature sensors (one in the housing and 1 on the radiator), which fixed the leak. However, the fan is still constantly on maximum all the time, coolant level low message appearing (I think the radiator is empty as the reservoir is filled up and doesn’t drop), and the coolant temp won’t get over 75C using an OBD reader.
No codes are present with the OBD reader and the heater vents are producing hot air.
Also, Since fitting the thermostat, the fuel gauge is stuck on empty even though it has half a tank in. This was working prior to having the Thermostat and sensors replaced. I assume this is related? It was working prior to this with no issues.
Any help would be greatly appreciated.
| dash cluster faulty |
Posted by: niteram - 12:th-Apr-2020, 17:29:07 - Forum: Electrical
- Replies (3)
Hi, we've got a problem with my daughters J (1.6 petrol)
started it today and the central info display between the speedo and rev counter doesn't light up
it looked like it trying to say the normal warnings, change oil, put foot on clutch etc all barely visible as not lit up in red
the last thing it said was PROGRAM CLUSTER
which doesn't sound good to me,
any ideas how I can cure this at home?
| Which version of op-com |
Posted by: Kiel0777 - 12:th-Apr-2020, 14:04:31 - Forum: Astra-J/GTC
- Replies (16)
Probably been said somewhere else but I can't seem to find it I have a 63 plate astra j 2.0 cdti and was wondering which version of op-com I need?
| Has my car been mapped |
Posted by: Kiel0777 - 12:th-Apr-2020, 09:38:39 - Forum: Astra-J/GTC
- Replies (6)
Hi all had my car for around 4 months and as far as I'm aware it hasn't done a single regen.
With it being mapped and possible dpf deleted may have caused this but how will I know?
| Which will sound better |
Posted by: Kiel0777 - 11:th-Apr-2020, 12:02:48 - Forum: Mechanical
- Replies (9)
Hi guys really want to improve/enhance the sound of the turbo?
Which would do this better a K&n panel filter or a js performance Induction hose?
