system retrofitting start stop
Retrofitting stop/start system
Can you retrofit the stop/start system on Astra j with 1.7 cdti ?
You could but the cost would far out weigh any benefit.
There are so many up-rated parts for S/S and then loads of extra wiring.
That's before you even get on to programming (which would be the stumbling block as GM wouldn't support it).
(13:th-Apr-2020, 07:26:02)Rusty2009 Wrote: You could but the cost would far out weigh any benefit.
Thank you Rusty
Not sure why you would want to retrofit Stop/Start. Just be glad you don't have it. I have it disabled in my current car.
Past 2008 Civic 1.8 Type S
  Uneven idle and hunting on initial start up Jpbroad1970 2 5,190 24:th-Aug-2021, 09:34:41
  Intermittent start, stalls after clock sweep no throttle response Jump to Latest Brendonm9477 5 8,316 5:th-Jan-2021, 13:55:10
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 54,003 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  astra j 2.0 start up cornwall37 2 5,217 10:th-Apr-2020, 13:47:56
Last Post: Kiel0777
  New Fuel filter. Wont start SALMHAGE 1 4,276 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  Start up issue... only once daveloz12 4 7,163 22:nd-Mar-2019, 10:02:26
Last Post: daveloz12
  What would cause stop/start to not work? Vx-Mad-G 12 26,460 1:st-Jan-2019, 10:15:22
  Service Theft Deterrent System mw2299 9 59,420 10:th-Dec-2018, 10:43:59
Last Post: Collster
Astra J, turns but will not start randilio1 6 8,295 2:nd-Dec-2018, 19:01:23
  SCR System retrofit MrLocke 3 5,441 8:th-Aug-2018, 07:31:38
