» Members: 12,337
» Latest member: PhantomX64
» Forum threads: 4,563
» Forum posts: 49,693
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
  How to front and rear brake pads removal 5Door
Posted by: Rusty2009 - 21:st-Feb-2014, 14:02:19 - Forum: Mechanical How-to's - Replies (39)
[Image: vx.o.c.jpeg]
How to front and rear brake pads removal.
Just thought I'd put this up as we don't have one yet.
Jack up and remove wheel from the car to gain access to brake.
[Image: 1.JPG]
Next take out the guide bolt from the bottom 10mm
[Image: 2.JPG]
you may need to slacken the top guide bolt no need to fully remove it
[Image: 3.JPG]
then pull the housing out and up
[Image: 4.JPG]
[Image: 5.JPG]
Tie the housing to something (although I didn't)
To remove the brake pad just pull it out towards you the back one pulls out away from you
[Image: 6.JPG]
remove the brake pad retaining springs they just pull down or up (give them a clean).
[Image: 7.JPG]
Refitting is the reversal of removal the guide bolts need to be torqued up to 28 N.M (21 lb ft).
If you need to push the piston back in Vauxhall use tool CH-6007-B but I find a couple of bits of wood and a G clamp is just as good.
Now for the rear
again jack up and remove wheel
[Image: 8.JPG]
fully remove the calliper vibration dampener 13mm spanner
[Image: 9.JPG]
[Image: 10.JPG]
again pull the housing out and up
[Image: 11.JPG]
[Image: 12.JPG]
there is not a lot of room here hence no pics but the pads pull out the same as the front as do the retaining springs.
Again clean the retaining springs
refitting is the reversal of removal the guide bolt and calliper vibration dampener need to be torqued up to 28 N.M (21 lb ft). Not having a torque spanner I just did the calliper vibration dampener up nice and tight.
If you need to push the piston back in Vauxhall use tool CH-6007-B with CH-6007-50 adapter these are wind back at the rear so you will need to wind them.
Thanks to JohnL for supplying the following pics on rewinding the pistons on the rear.
[Image: IMG_20140908_105438.jpg]
[Image: IMG_20140908_105432.jpg]
Not sure if you can see from the picture but I bolted the top of the calliper back up which held everything in place and allowed me to concentrate on turning the rewind tool. and not worry out holding the calliper and looking out for the brake pipe.
Total job took no more than 30 minutes complete.
Number 7 was used on the rewind tool.
Here is list for Pads and Discs and GM Part numbers and Disc and PCD sizes.
Astra J GTC, DISCS AND PADS, PCD 5x115 ALL ENGINE SIZES
FRONT DISC, 321MM 13502826
FRONT PADS, 13137751
REAR DISCS, 292MM 13502138
REAR PADS, 13300867
ASTRA J 5 DOOR, DISCS AND PADS, PCD 5x105 engine size 1.4 VVT 1.6 VVT 1.3 CDTI
FRONT DISC, 276MM 13502044
FRONT PADS, 13301207
REAR DISC, 268MM 13502134
PADS SET, REAR 13300867
ASTRA J 5 DOOR DISCS AND PADS 5x115 1.6 TURBO 1.7 CDTI 2.0 CDTI
FRONT DISCS, 300mm 13502051
FRONT PADS, 13301234
REAR DISCS, 292mm 13502137
REAR PADS, 13319294
Astra J VXR, DISCS AND PADS, PCD 5+115
FRONT DISCS 355mm 13370436
FRONT PADS 13411116
REAR DISCS 314mm 13371163 or 13429575
REAR PADS 13417473
Electronic Parking Brake Control Module
Note: Verify the rear brakes are clear of any obstacles before starting the calibration procedure. During the procedure the rear brakes will cycle several times, stay clear of all moving parts until the process is complete.
Perform the Parking Brake Calibration procedure in Module Setup.
Calibration without Scan Tool
1.Ignition ON, apply and hold the brake pedal.
2.Push and hold the electric parking brake switch down for 5-6 seconds.
3.Release the electric parking brake switch.
4.Momentarily push the electric parking brake switch down.
5.Remove the EPB MODULE fuse and reinstall. (Engine fuse-board fuse 29 30A K83 Parking Brake Control Module (J71))
6.Apply the electric parking brake.
7.Release the electric parking brake
Here is a Thread on How to Grease the Slider Pins and Shims and Pads to stop Brake Squeal
http://www.vxoc.org.uk/forum/Thread-How-...al-Astra-J
Posted by: Rusty2009 - 21:st-Feb-2014, 11:56:40 - Forum: Lighting - Replies (71)
[Image: 9nd4_zpsea5fce57.jpg]
===ASTRA J:===
===Exterior:===
Astra J =Dipped Beam Headlight bulb:=(55W H7) (477).
(This is on canbus).
There are so many to choose from and people have there own opinion over which is better so it's down to your self to find ones that you are happy with.
Astra J=Main Beam Headlight Bulb:=(55W H7) (477).
(This is not on the canbus).
As the H7 Main Beam is not on the canbus you can install any H7 LED bulb in here with no load resistors being needed.
Astra J=Sidelight and DRL Bulb combined: =(W21/5W) (580)
(This is on canbus)
There are a few options here, PIAA or you can upgrade to LED's with Load resistors Please see how-to
Astra J=AFL cornering bulb:=(H11 55W)
(Not on the canbus BUT STILL MONITORED VIA THE AFL SYSTEM)
As the (H11) Corner Light is monitored via the AFL system you can't install any (H11 LED) bulb.
Astra J=(MY10-MY12)=Front Fog Light Bulb:=(H10-45W).
These are not on the Canbus so any will do as long as your happy.
As the (H10) Fog Light is not on the canbus you can install any (H10 LED) bulb in here with no load resistors being needed.
Astra J=(facelift MY13-)=front fog light bulb:=(H11 55W).
As the (H11) Fog Light is not on the canbus you can install any (H11) LED bulb in here with no load resistors being needed.
Astra J=front indicator bulb:=(PSY24W) (amber)
(this is on canbus)
Lush lighting sales them for £9.00 each there is a How-to here
Astra J=Side Repeater Bulb:=(W5WY) (501A).
(this is on canbus).
You might want to match the slivertech look in the side repeater with these
Astra J=Rear Indicator Bulb:=(W16W) (955).
(this is on canbus)
Astra J=Tail Light Bulb:=(W5W) (501).
(not on canbus).
Astra J=Number Plate Bulb:=(W5W) (501).
These are by far the best How-to here
Astra J=Brake Light Bulb:=(W16W) (955).
(this is on cambus).
Astra J=Reverse Light Bulb:=(H21W) (435).
(not on canbus)
bulb How-to here
Astra J=rear fog light bulb:=(H21W) (435).
(not on cambus)
bulb How-to is the same as reverse light just on the other side.
===Interior:===
Astra J=front courtesy light bulb:=(W5W) (501)
Astra J=front map reading lights:=(W5W) (501)
Astra J=rear courtesy lights:=(W5W) (501)
Astra J=glove box light:=(W5W) (501)
Astra J=vanity mirror lights:=(6615F)
Astra J=boot compartment light:=(W5W) (501)
Astra-J=Window Switch (LED's)=(0805)=See @cornishtaz's How-to here
Astra-J=Gear Surround=(LED's 4040)=See @cornishtaz's How-to here
Astra-J=Mirror Switch=(LED's PLCC-2)=(Awaiting confirmation)
Astra-J=Dash=(LED's PLCC-2)=(Awaiting confirmation)
****Note I offer an LED conversion service****
===ASTRA GTC:===
Astra GTC.=headlight bulb:=(9012) (55W.
Astra GTC.=sidelight and DRL=bulb combined:=W21/5W) (580).
Astra GTC.=front indicator bulb:=(581).
Astra GTC.=side repeater bulb:=(W5W) (501).
Astra GTC.=front fog light bulb:=(H10-45W).
Astra GTC.=brake and tail light bulb=(outer):(P21/5W).
Astra GTC.=rear indicator bulb:=(WY21W).
Astra GTC.=reverse bulb:=(W16W).
Astra GTC.=tail light bulb=(inner, on tailgate): (W5W) (501).
Astra GTC.=rear fog light bulb:=(PSX24W).
Astra GTC.=number plate bulb:=
Full canbus list can be found here.
http://www.vxoc.org.uk/forum/Thread-Canbus-check-list
  Fault Codes
Posted by: Rusty2009 - 21:st-Feb-2014, 11:48:56 - Forum: Vauxhall General - Replies (11)
Fault Codes
Diagnostic Trouble Code (DTC) List - Vehicle
This master DTC list includes all applicable (B) DTCs in alphanumeric order with descriptors.
[TR]
[TD]DTC[/TD]
[TD]DTC Descriptor[/TD]
[TD]Diagnostic Procedure[/TD]
[/TR]
[TR]
[TD]B0000[/TD]
[TD]Vehicle Speed Information Circuit Invalid Data.........Vehicle Speed Information Circuit Not Plausible[/TD]
[TD]Headlamp Control Module - DTC B0000, C0055, C0246, C1207-C1210, C1221-C1228,
or C1232-C1235
or Radio - DTC B0000[/TD]
[/TR]
[TR]
[TD]B0012[/TD]
[TD]Driver Frontal Deployment Loop Stage *1[/TD]
[TD]DTC B0012[/TD]
[/TR]
[TR]
[TD]B0013[/TD]
[TD]Driver Frontal Deployment Loop Stage *2[/TD]
[TD]DTC B0013[/TD]
[/TR]
[TR]
[TD]                         B0014
B0015
B0016
B0019[/TD]
[TD]Driver Side Deployment Loop
Driver Seat Belt Pretensioner Deployment Loop
Left Roof Rail Deployment Loop*1
Passenger Frontal Deployment Loop Stage*1[/TD]
[TD]
DTC B0014-B0045[/TD]
[/TR]
[TR]
[TD]B001A[/TD]
[TD]Driver Seat Belt Pretensioner Deployment Loop[/TD]
[TD]DTC B001A[/TD]
[/TR]
[TR]
[TD]B001B[/TD]
[TD]Passenger Seat Belt Pretensioner Deployment Loop[/TD]
[TD]DTC B001B[/TD]
[/TR]
[TR]
[TD]B0020
B0021
B0022
B0023
B0031
B0038[/TD]
[TD]Passenger Frontal Deployment Loop Stage*2
Passenger Side Deployment Loop
Right Roof Rail Deployment Loop*1
Left Rear Side Deployment Loop
Right Rear Side Deployment Loop[/TD]
[TD]
[/TR]
[TR]
[TD]B0051[/TD]
[TD]Battery Cut-Off Deployment Loop[/TD]
[TD]DTC B0051[/TD]
[/TR]
[TR]
[TD]B0052[/TD]
[TD]Deployment Commanded[/TD]
[TD]DTC B0052[/TD]
[/TR]
[TR]
[TD]B0082[/TD]
[TD]Seat Belt Reminder Sensor[/TD]
[TD]DTC B0082[/TD]
[/TR]
[TR]
[TD]B0083
B0084
B0085
B0086[/TD]
[TD]Left Front Impact Sensor
Right Front Impact Sensor
Left Front Side Impact Sensor
Right Front Side Impact Sensor[/TD]
[TD]
DTC B0083-B0088[/TD]
[/TR]
[TR]
[TD]B0158[/TD]
[TD]Ambient Air Temperature Sensor Circuit[/TD]
[TD]DTC B0158[/TD]
[/TR]
[TR]
[TD]B0163[/TD]
[TD]Passenger Compartment Temperature Sensor Circuit[/TD]
[TD]DTC B0163, B0183 or B1405[/TD]
[/TR]
[TR]
[TD]B0173[/TD]
[TD]Upper Left Duct Air Temperature Sensor Circuit[/TD]
[TD]DTC B0173, B0178, B0509, B0514 or B3933[/TD]
[/TR]
[TR]
[TD]B0178[/TD]
[TD]Lower Left Duct Air Temperature Sensor Circuit[/TD]
[/TR]
[TR]
[TD]B0183[/TD]
[TD]Solar Load Sensor Circuit[/TD]
[/TR]
[TR]
[TD]B018A[/TD]
[TD]Windscreen Temperature Sensor Circuit[/TD]
[TD]DTC B018A, B048C, B048F, or B1395[/TD]
[/TR]
[TR]
[TD]B018B[/TD]
[TD]HVAC Condenser Air Deflector Circuit[/TD]
[TD]HVAC Automatic - DTC B018B
or
HVAC Manual - DTC B018B[/TD]
[/TR]
[TR]
[TD]B0193[/TD]
[TD]Front Blower Motor Speed Circuit[/TD]
[TD]HVAC Automatic - DTC B0193
or
HVAC Manual - DTC B0193[/TD]
[/TR]
[TR]
[TD]B0223[/TD]
[TD]Recirculate Position Command*1 Circuit[/TD]
[TD]HVAC Automatic - DTC B0223, B022A, B0233, B023A, B0408, or B0418
or
HVAC Manual - DTC B0223, B0233, B023A, or B0418[/TD]
[/TR]
[TR]
[TD]B022A[/TD]
[TD]Recirculate Position Command*2 Circuit[/TD]
[TD]DTC B0223, B022A, B0233, B023A, B0408, or B0418[/TD]
[/TR]
[TR]
[TD]B0233
B023A[/TD]
[TD]Air Flow Control Circuit
HVAC Actuators Supply Voltage[/TD]
or
[/TR]
[TR]
[TD]B0283[/TD]
[TD]Electric Rear Defrost Circuit[/TD]
[TD]DTC B0283[/TD]
[/TR]
[TR]
[TD]B0408[/TD]
[TD]Main Temperature Control Circuit[/TD]
[/TR]
[TR]
[TD]B0418[/TD]
[TD]Right Temperature Control Circuit.........Main Temperature Control Circuit[/TD]
or
[/TR]
[TR]
[TD]B0468
B0470
B0471
B0472[/TD]
[TD]Auxiliary Heater Coolant Pump Circuit
Auxiliary Heater Coolant Pump Relay Circuit Low Voltage
Auxiliary Heater Coolant Pump Relay Circuit High Voltage
Auxiliary Heater Coolant Pump Relay Circuit Open[/TD]
[TD]HVAC Automatic - DTC B0468 or B0470-B0472
or
HVAC Manual - DTC B0468 or B0470-B0472[/TD]
[/TR]
[TR]
[TD]B048C[/TD]
[TD]Humidity Sensor Humidity Circuit[/TD]
[/TR]
[TR]
[TD]B048D
B048E[/TD]
[TD]Auxiliary Heater Temperature Command Circuit
Auxiliary Heater System Malfunction[/TD]
[TD]HVAC Automatic - DTC B048D or B048E
or
HVAC Manual - DTC B048D or B048E[/TD]
[/TR]
[TR]
[TD]B048F[/TD]
[TD]Humidity Sensor Temperature Circuit[/TD]
[/TR]
[TR]
[TD]B0509
B0514[/TD]
[TD]Upper Right Duct Air Temperature Sensor Circuit
Lower Right Duct Air Temperature Sensor Circuit[/TD]
[/TR]
[TR]
[TD]B0550[/TD]
[TD]Odometer Circuit[/TD]
[TD]DTC B0550[/TD]
[/TR]
[TR]
[TD]B0655[/TD]
[TD]Brake Lamp Switch Circuit[/TD]
[TD]DTC B0655[/TD]
[/TR]
[TR]
[TD]B0685[/TD]
[TD]Security System Indicator Circuit[/TD]
[TD]DTC B0685[/TD]
[/TR]
[TR]
[TD]B071F[/TD]
[TD]Transmission Range Indicator[/TD]
[TD]DTC B071F[/TD]
[/TR]
[TR]
[TD]B0954
B0955
B0956
B0957[/TD]
[TD]Parking Aid Front Sensor Left Corner Circuit
Parking Aid Front Sensor Left Middle Circuit
Parking Aid Front Sensor Right Middle Circuit
Parking Aid Front Sensor Right Corner Circuit[/TD]
[TD]
DTC B0954, B0955, B0956, or B0957[/TD]
[/TR]
[TR]
[TD]B0958
B0959
B0960
B0961[/TD]
[TD]Parking Aid Rear Sensor Left Corner Circuit
Parking Aid Rear Sensor Left Middle Circuit
Parking Aid Rear Sensor Right Middle Circuit
Parking Aid Rear Sensor Right Corner Circuit[/TD]
[TD]
DTC B0958, B0959, B0960, or B0961[/TD]
[/TR]
[TR]
[TD]B0967
B0968[/TD]
[TD]Parking Aid On/Off Switch Circuit
Parking Aid On/Off Switch Indicator Circuit[/TD]
[TD]DTC B0967 or B0968[/TD]
[/TR]
[TR]
[TD]B096A[/TD]
[TD]Hazard Lamps Switch Backlight Circuit Short to Ground[/TD]
[TD]DTC B096A[/TD]
[/TR]
[TR]
[TD]B097D[/TD]
[TD]Transmission Sport Mode Indicator Circuit[/TD]
[TD]DTC B097D[/TD]
[/TR]
[TR]
[TD]B097F[/TD]
[TD]Transmission Tow Mode Indicator Circuit[/TD]
[TD]DTC B097F[/TD]
[/TR]
[TR]
[TD]B0984
B0985[/TD]
[TD]Left Headlamp Light Distribution Shutter Control Circuit
Right Headlamp Light Distribution Shutter Control Circuit[/TD]
[TD]DTC B0984 or B0985[/TD]
[/TR]
[TR]
[TD]B0987[/TD]
[TD]Vehicle Direction Camera Indicator Circuit[/TD]
[TD]DTC B0987[/TD]
[/TR]
[TR]
[TD]B0988[/TD]
[TD]Vehicle Direction Camera Control Module Malfunction[/TD]
[TD]DTC B0988[/TD]
[/TR]
[TR]
[TD]B1000[/TD]
[TD]Electronic Control Module[/TD]
[TD]DTC B1000[/TD]
[/TR]
[TR]
[TD]B1001[/TD]
[TD]Option Configuration.........SDM Option Configuration Error[/TD]
[TD]DTC B1001
or
Inflatable Restraint Sensing and Diagnostic Module (SDM) - DTC B1001[/TD]
[/TR]
[TR]
[TD]B1015[/TD]
[TD]Vehicle Identification Number Information Malfunction[/TD]
[TD]DTC B1015[/TD]
[/TR]
[TR]
[TD]B1019[/TD]
[TD]System Configuration Error[/TD]
[TD]DTC B1019[/TD]
[/TR]
[TR]
[TD]B101D[/TD]
[TD]Electronic Control Module Hardware[/TD]
[TD]DTC B101D[/TD]
[/TR]
[TR]
[TD]B101E[/TD]
[TD]Electronic Control Module Software[/TD]
[TD]DTC B101E[/TD]
[/TR]
[TR]
[TD]B1020[/TD]
[TD]Auxiliary Electronic Control Module Performance[/TD]
[TD]DTC B1020[/TD]
[/TR]
[TR]
[TD]B1023[/TD]
[TD]Integral Switch Malfunction[/TD]
[TD]NO DTC Info at this time[/TD]
[/TR]
[TR]
[TD]B1025
B1035
B1045
B1055[/TD]
[TD]Left Front Audio Output Circuit
Right Front Audio Output Circuit
Left Rear Audio Output Circuit
Right Rear Audio Output Circuit[/TD]
[TD]
DTC B1025, B1035, B1045, or B1055[/TD]
[/TR]
[TR]
[TD]B1259[/TD]
[TD]Aerial Ground Circuit[/TD]
[TD]DTC B1259[/TD]
[/TR]
[TR]
[TD]B125A[/TD]
[TD]Antenna Signal Circuit Short to Ground
Antenna Signal Circuit Open[/TD]
[TD]DTC B125A[/TD]
[/TR]
[TR]
[TD]B1265[/TD]
[TD]Switched 14V[/TD]
[TD]DTC B1265[/TD]
[/TR]
[TR]
[TD]B1271[/TD]
[TD]Theft Protection Active[/TD]
[TD]DTC B1271[/TD]
[/TR]
[TR]
[TD]B1278
B1279[/TD]
[TD]Left Auxiliary Input Signal Circuit
Right Auxiliary Input Signal Circuit[/TD]
[TD]DTC B1278 or B1279[/TD]
[/TR]
[TR]
[TD]B1287[/TD]
[TD]Amplifier Control Signal Circuit[/TD]
[TD]DTC B1287[/TD]
[/TR]
[TR]
[TD]B1295[/TD]
[TD]Steering Wheel Controls Group 2 Signal Circuit High Voltage[/TD]
[TD]DTC B1295[/TD]
[/TR]
[TR]
[TD]B1325[/TD]
[TD]Device Power Circuit[/TD]
[TD]DTC B1325[/TD]
[/TR]
[TR]
[TD]B1370
B1380[/TD]
[TD]Control Module Ignition On and Start Circuit
Control Module Ignition Accessory Circuit[/TD]
[TD]DTC B1370-B1379, B1380-B1389, or B1440-B1443[/TD]
[/TR]
[TR]
[TD]B1395[/TD]
[TD]Control Module Voltage Reference Output Circuit[/TD]
[/TR]
[TR]
[TD]B1405[/TD]
[TD]Control Module Voltage Reference Output*2 Circuit[/TD]
[TD]HVAC Control Module - DTC B0163, B0183, or B1405
DTC B1405
Parking Assist Control Module - DTC B1405[/TD]
[/TR]
[TR]
[TD]B1441[/TD]
[TD]Control Module Ignition Off, Run and Start Circuit[/TD]
[/TR]
[TR]
[TD]B1445[/TD]
[TD]Control Module Voltage Output Circuit[/TD]
[TD]DTC B1445[/TD]
[/TR]
[TR]
[TD]B144A[/TD]
[TD]RUN Power Relay Circuit[/TD]
[TD]DTC B144A[/TD]
[/TR]
[TR]
[TD]B144B[/TD]
[TD]Run/Crank Power Relay Circuit[/TD]
[TD]DTC B144B[/TD]
[/TR]
[TR]
[TD]B1461
B1462[/TD]
[TD]Left Headlamp Horizontal Motor Circuit
Right Headlamp Horizontal Motor Circuit[/TD]
[TD]DTC B1461 or B1462[/TD]
[/TR]
[TR]
[TD]B1480[/TD]
[TD]Battery Rundown Protection Circuit[/TD]
[TD]DTC B1480[/TD]
[/TR]
[TR]
[TD]B1516[/TD]
[TD]Battery Current Sensor[/TD]
[TD]DTC B1516[/TD]
[/TR]
[TR]
[TD]B1517[/TD]
[TD]Battery Voltage[/TD]
[TD]DTC B1517[/TD]
[/TR]
[TR]
[TD]B151A[/TD]
[TD]Low Battery Capacity Detected[/TD]
[TD]DTC B151A[/TD]
[/TR]
[TR]
[TD]B151D[/TD]
[TD][/TD]
[TD]DTC B151D[/TD]
[/TR]
[TR]
[TD]B1527[/TD]
[TD]High Parasitic Load Detected[/TD]
[TD]DTC B1527[/TD]
[/TR]
[TR]
[TD]B1529[/TD]
[TD]Control Module Voltage Reference Output*5 Circuit[/TD]
[TD]DTC B1529[/TD]
[/TR]
[TR]
[TD]B1925
B2170[/TD]
[TD]Driver Seat Cushion Heater Sensor Circuit
Passenger Seat Cushion Heater Sensor Circuit[/TD]
[TD]DTC B1925 or B2170[/TD]
[/TR]
[TR]
[TD]B2345[/TD]
[TD]Seat Heater Disable Circuit[/TD]
[TD]DTC B2345[/TD]
[/TR]
[TR]
[TD]B2425[/TD]
[TD]Driver Seat Cushion Heater Circuit[/TD]
[TD]DTC B2425 or B2430[/TD]
[/TR]
[TR]
[TD]B242A[/TD]
[TD]Seat Heaters Common Circuit[/TD]
[TD]DTC B242A[/TD]
[/TR]
[TR]
[TD]B2430[/TD]
[TD]Passenger Seat Cushion Heater Circuit[/TD]
[/TR]
[TR]
[TD]B2462[/TD]
[TD]Global Position System Signal[/TD]
[TD]DTC B2462[/TD]
[/TR]
[TR]
[TD]B2470[/TD]
[TD]Mobile Phone Aerial Circuit[/TD]
[TD]DTC B2470[/TD]
[/TR]
[TR]
[TD]B2485[/TD]
[TD]Wireless Communication Aerial[/TD]
[TD]DTC B2485[/TD]
[/TR]
[TR]
[TD]B2501[/TD]
[TD]Horn Switch Stuck[/TD]
[TD]DTC B2501[/TD]
[/TR]
[TR]
[TD]B2515[/TD]
[TD]Steering Column Lock Motor Feedback Circuit[/TD]
[TD]DTC B2515[/TD]
[/TR]
[TR]
[TD]B2530[/TD]
[TD]Front Fog Lamps Control Circuit[/TD]
[TD]DTC B2530[/TD]
[/TR]
[TR]
[TD]B2540[/TD]
[TD]Rear Fog Lamps Control Circuit[/TD]
[TD]DTC B2540[/TD]
[/TR]
[TR]
[TD]B2545[/TD]
[TD]Reverse Lamps Control Circuit[/TD]
[TD]DTC B2545[/TD]
[/TR]
[TR]
[TD]B255F[/TD]
[TD]Interior Door Handle Backlight Circuit[/TD]
[TD]DTC B255F[/TD]
[/TR]
[TR]
[TD]B2570[/TD]
[TD]Trunk Lamp Control Circuit Short to Ground[/TD]
[TD]DTC B2570[/TD]
[/TR]
[TR]
[TD]B2575[/TD]
[TD]Left Headlamp Control Circuit[/TD]
[TD]DTC B2575 or B2699[/TD]
[/TR]
[TR]
[TD]B257A[/TD]
[TD]Headlamp Switch Input Signals[/TD]
[TD]DTC B257A[/TD]
[/TR]
[TR]
[TD]B257B[/TD]
[TD]Lighting Control Switch Signal[/TD]
[TD]DTC B257B[/TD]
[/TR]
[TR]
[TD]B2580[/TD]
[TD]Main Beam Control Circuit[/TD]
[TD]DTC B2580[/TD]
[/TR]
[TR]
[TD]B2585[/TD]
[TD]Park Lamps Control Circuit[/TD]
[TD]DTC B2585 or B3867[/TD]
[/TR]
[TR]
[TD]B258A[/TD]
[TD]Low Beam Control Circuit[/TD]
[TD]DTC B258A[/TD]
[/TR]
[TR]
[TD]B2590
B2595[/TD]
[TD]Low Cornering Lamp Circuit
Right Cornering Lamp Circuit[/TD]
[TD]DTC B2590 or B2595[/TD]
[/TR]
[TR]
[TD]B259A
B259B[/TD]
[TD]Left Cornering Lamp Relay Control Circuit
Right Cornering Lamp Relay Control Circuit[/TD]
[TD]DTC B259A or B259B[/TD]
[/TR]
[TR]
[TD]B260B
B260C[/TD]
[TD]Left Daytime Running Lamp Relay Control Circuit
Right Daytime Running Lamp Relay Control Circuit[/TD]
[TD]DTC B260B or B260C[/TD]
[/TR]
[TR]
[TD]B260D
B260E[/TD]
[TD]Left Daytime Running Lamp and Front Park Lamp Control Circuit Short to Ground
Right Daytime Running Lamp and Front Park Lamp Control Circuit Short to Ground[/TD]
[TD]DTC B260D or B260E[/TD]
[/TR]
[TR]
[TD]B2610[/TD]
[TD]Passenger Compartment Dimming*1 Circuit[/TD]
[TD]DTC B2610[/TD]
[/TR]
[TR]
[TD]B2615[/TD]
[TD]Passenger Compartment Dimming*2 Circuit[/TD]
[TD]DTC B2615[/TD]
[/TR]
[TR]
[TD]B2625[/TD]
[TD]Display Dimming Pulse Width Modulation Output Circuit[/TD]
[TD]DTC B2625[/TD]
[/TR]
[TR]
[TD]B2652[/TD]
[TD]Passenger Compartment Dimming 3 Circuit Short to Ground[/TD]
[TD]DTC B2652[/TD]
[/TR]
[TR]
[TD]B2699[/TD]
[TD]Right Headlamp Control Circuit[/TD]
[/TR]
[TR]
[TD]B270A[/TD]
[TD]Park Lock Solenoid Control Circuit[/TD]
[TD]DTC B270A[/TD]
[/TR]
[TR]
[TD]B2745[/TD]
[TD]Traction Control Switch Circuit[/TD]
[TD]DTC B2745[/TD]
[/TR]
[TR]
[TD]B2897[/TD]
[TD]Steering Column Lock Motor Lock Circuit[/TD]
[TD]DTC B2897[/TD]
[/TR]
[TR]
[TD]B2910[/TD]
[TD]Steering Column Lock Password Incorrect[/TD]
[TD]DTC B2910[/TD]
[/TR]
[TR]
[TD]B291B[/TD]
[TD]Content Theft Deterrent Sensor[/TD]
[TD]DTC B291B[/TD]
[/TR]
[TR]
[TD]B2955[/TD]
[TD]Security Sensor Data Circuit Malfunction[/TD]
[TD]DTC B2955[/TD]
[/TR]
[TR]
[TD]B3006[/TD]
[TD]Bonnet Ajar Circuit[/TD]
[TD]DTC B3006[/TD]
[/TR]
[TR]
[TD]B3031[/TD]
[TD]Security Controller In Learn Mode Malfunction[/TD]
[TD]DTC B3031[/TD]
[/TR]
[TR]
[TD]B3055[/TD]
[TD]No Transponder Modulation or No Transponder Malfunction[/TD]
[TD]DTC B3055[/TD]
[/TR]
[TR]
[TD]B305A[/TD]
[TD]No Response From Steering Column Lock Received[/TD]
[TD]DTC B305A[/TD]
[/TR]
[TR]
[TD]B3060[/TD]
[TD]Unprogrammed Transponder Identification Code Received Malfunction[/TD]
[TD]DTC B3060[/TD]
[/TR]
[TR]
[TD]B3101[/TD]
[TD]Keyless Entry Data Link Circuit[/TD]
[TD]DTC B3101[/TD]
[/TR]
[TR]
[TD]B3105[/TD]
[TD]Keyless Entry System Key Fobs[/TD]
[TD]DTC B3105[/TD]
[/TR]
[TR]
[TD]B3106[/TD]
[TD]Keyless Entry Data Link[/TD]
[TD]DTC B3106[/TD]
[/TR]
[TR]
[TD]B3109[/TD]
[TD]Keyless Entry Transmitter*1 Low Battery[/TD]
[TD]DTC B3109-B3113[/TD]
[/TR]
[TR]
[TD]B310D
B310E
B310F[/TD]
[TD]Keyless Entry Transmitter*6 Low Battery
Keyless Entry Transmitter*7 Low Battery
Keyless Entry Transmitter*8 Low Battery[/TD]
[TD]DTC B310D-B310F[/TD]
[/TR]
[TR]
[TD]B3110
B3111
B3112
B3113[/TD]
[TD]Keyless Entry Transmitter*2 Low Battery
Keyless Entry Transmitter*3 Low Battery
Keyless Entry Transmitter*4 Low Battery
Keyless Entry Transmitter*5 Low Battery[/TD]
[TD]
[/TR]
[TR]
[TD]B3125
B3130
B3135[/TD]
[TD]Driver Door Only Unlock Circuit
All Doors Unlock Circuit
All Doors Lock Circuit[/TD]
[TD]DTC B3125, B3130, or B3135[/TD]
[/TR]
[TR]
[TD]B3140
B3150[/TD]
[TD]Driver Door Unlock Switch Circuit
Left Front Door Lock Switch Circuit[/TD]
[TD]DTC B3140 or B3150[/TD]
[/TR]
[TR]
[TD]B316B
B317A
B318A
B319A[/TD]
[TD]Driver Window Switch
Passenger Window Switch
Left Rear Window Switch
Right Rear Window Switch[/TD]
[TD]
DTC B316B, B317A, B318A, or B319A[/TD]
[/TR]
[TR]
[TD]B3205
B3210
B3215
B3220[/TD]
[TD]Driver Window Motor Circuit
Right Front/Passenger Window Motor Circuit
Left Rear Window Motor Circuit
Right Rear Window Motor Circuit[/TD]
[TD]
DTC B3205, B3210, B3215, or B3220[/TD]
[/TR]
[TR]
[TD]B3265[/TD]
[TD]Boot Lid Unlatch Output Circuit[/TD]
[TD]DTC B3265[/TD]
[/TR]
[TR]
[TD]B3410[/TD]
[TD]Automatic Headlamp Levelling Control Module Front Axle Sensor Signal Circuit[/TD]
[TD]DTC B3410 or B3420[/TD]
[/TR]
[TR]
[TD]B3415[/TD]
[TD]Automatic Headlamp Levelling Control Module Axle Sensor Supply Circuit[/TD]
[TD]DTC B3415[/TD]
[/TR]
[TR]
[TD]B3420[/TD]
[TD]Automatic Headlamp Levelling Control Module Rear Axle Sensor Signal Circuit[/TD]
[/TR]
[TR]
[TD]B3435
B3440[/TD]
[TD]Automatic Headlamp Levelling Control Module Left Servo Driver*1 or*2 Circuit
Automatic Headlamp Levelling Control Module Right Servo Driver*1 or*2 Circuit[/TD]
[TD]DTC B3435 or B3440[/TD]
[/TR]
[TR]
[TD]B3567[/TD]
[TD]Info Display Select Switch Circuit[/TD]
[TD]DTC B3567[/TD]
[/TR]
[TR]
[TD]B356A[/TD]
[TD]Vehicle Direction Warning Switch Circuit[/TD]
[TD]DTC B356A[/TD]
[/TR]
[TR]
[TD]B3588[/TD]
[TD]Rear Fog Lamp Switch Circuit[/TD]
[TD]DTC B3588[/TD]
[/TR]
[TR]
[TD]B3596[/TD]
[TD]Hazard Warning Request Circuit[/TD]
[TD]DTC B3596[/TD]
[/TR]
[TR]
[TD]B3618[/TD]
[TD]Exterior Tailgate Unlatch Switch Circuit[/TD]
[TD]DTC B3618[/TD]
[/TR]
[TR]
[TD]B3622[/TD]
[TD]Steering Wheel Controls Signal Circuit[/TD]
[TD]DTC B3622[/TD]
[/TR]
[TR]
[TD]B3650[/TD]
[TD]Main Beam Request Signal Circuit[/TD]
[TD]DTC B3650[/TD]
[/TR]
[TR]
[TD]B3664[/TD]
[TD]Sunroof Position Select Switch High Signal Circuit[/TD]
[TD]DTC B3664[/TD]
[/TR]
[TR]
[TD]B3697[/TD]
[TD]Sunroof Actuator[/TD]
[TD]DTC B3697[/TD]
[/TR]
[TR]
[TD]B369C[/TD]
[TD]Sunroof Tilt Position Select Switch Circuit[/TD]
[TD]DTC B369C[/TD]
[/TR]
[TR]
[TD]B369D[/TD]
[TD]Sunroof Sunshade Actuator[/TD]
[TD]DTC B369D[/TD]
[/TR]
[TR]
[TD]B370A[/TD]
[TD]Rain Sensor[/TD]
[TD]DTC B370A[/TD]
[/TR]
[TR]
[TD]B370B[/TD]
[TD]Rear Wiper Function Control Circuit[/TD]
[TD]DTC B370B[/TD]
[/TR]
[TR]
[TD]B3715[/TD]
[TD] Windscreen Wiper Relay Circuit[/TD]
[TD]DTC B3715[/TD]
[/TR]
[TR]
[TD]B371A[/TD]
[TD]Windscreen Wiper Motor[/TD]
[TD]DTC B371A[/TD]
[/TR]
[TR]
[TD]B3794[/TD]
[TD]Cruise Control Function Request Circuit[/TD]
[TD]DTC B3794[/TD]
[/TR]
[TR]
[TD]B3797[/TD]
[TD]All Door Dead Lock Circuit[/TD]
[TD]DTC B3797[/TD]
[/TR]
[TR]
[TD]B3806[/TD]
[TD]High Beam and Headlamp Flash Select Circuit[/TD]
[TD]DTC B3806[/TD]
[/TR]
[TR]
[TD]B3810[/TD]
[TD]Headlamp Washer Relay Circuit[/TD]
[TD]DTC B3810[/TD]
[/TR]
[TR]
[TD]B3811[/TD]
[TD]Rear Washer Relay Circuit[/TD]
[TD]DTC B3811[/TD]
[/TR]
[TR]
[TD]B3843[/TD]
[TD]Outside Air Quality Sensor Circuit[/TD]
[TD]DTC B3843[/TD]
[/TR]
[TR]
[TD]B3867[/TD]
[TD]Right Park Lamp Control Circuit[/TD]
[TD]DTC B3867[/TD]
[/TR]
[TR]
[TD]B3873[/TD]
[TD]Front Washer Relay Circuit[/TD]
[TD]DTC B3873[/TD]
[/TR]
[TR]
[TD]B3881
B3882[/TD]
[TD]Tail Lamp Circuit
Right Tail Lamp Circuit[/TD]
[TD]DTC B3881 or B3882[/TD]
[/TR]
[TR]
[TD]B3883[/TD]
[TD]Number Plate Lamp Circuit[/TD]
[TD]DTC B3883[/TD]
[/TR]
[TR]
[TD]B3884[/TD]
[TD]Centre High Mounted Brake Lamp Circuit Short to Ground[/TD]
[TD]DTC B3884[/TD]
[/TR]
[TR]
[TD]B3885
B3886[/TD]
[TD]Trailer Left Tail Lamp Circuit
Trailer Right Tail Lamp Circuit[/TD]
[TD]DTC B3885 or B3886[/TD]
[/TR]
[TR]
[TD]B3887
B3888[/TD]
[TD]Trailer Left Turn Signal Circuit
Trailer Right Turn Signal Circuit[/TD]
[TD]DTC B3887 or B3888[/TD]
[/TR]
[TR]
[TD]B3889[/TD]
[TD]Trailer Brake Lamps Circuit[/TD]
[TD]DTC B3889[/TD]
[/TR]
[TR]
[TD]B388B
B388C[/TD]
[TD]Secondary Left Tail and Brake Lamp Circuit
Secondary Right Tail and Brake Lamp Circuit[/TD]
[TD]DTC B388B or B388C[/TD]
[/TR]
[TR]
[TD]B3890[/TD]
[TD]Trailer Backup Lamps Circuit[/TD]
[TD]DTC B3890[/TD]
[/TR]
[TR]
[TD]B3891[/TD]
[TD]Trailer Fog Lamps Circuit[/TD]
[TD]DTC B3891[/TD]
[/TR]
[TR]
[TD]B389A[/TD]
[TD]Environment Identification Malfunction - Received by BCM[/TD]
[TD]DTC B389A[/TD]
[/TR]
[TR]
[TD]B3902[/TD]
[TD]Incorrect Immobiliser Identifier Received[/TD]
[TD]DTC B3902[/TD]
[/TR]
[TR]
[TD]B3933[/TD]
[TD]Air Conditioning Evaporator Temperature Sensor Circuit[/TD]
[TD]HVAC Automatic - DTC B0173, B0178, B0509, B0514 or B3933
or
HVAC Manual - DTC B3933[/TD]
[/TR]
[TR]
[TD]B3938[/TD]
[TD]Fuel Door Actuator Lock Circuit[/TD]
[TD]DTC B3938[/TD]
[/TR]
[TR]
[TD]B393B[/TD]
[TD]Air Conditioning Compressor Valve Control Circuit[/TD]
[TD]HVAC Automatic - DTC B393B
or
HVAC Manual - DTC B393B[/TD]
[/TR]
[TR]
[TD]B3948
B3949[/TD]
[TD]Left Front Indicator Circuit
Right Front Indicator Circuit[/TD]
[TD]DTC B3948 or B3949[/TD]
[/TR]
[TR]
[TD]B3950
B3951[/TD]
[TD]Left Rear Turn Indicator Circuit
Right Rear Indicator Circuit[/TD]
[TD]DTC B3950 or B3951[/TD]
[/TR]
[TR]
[TD]B3984[/TD]
[TD]Device*1 Environment Identifier Not Programmable[/TD]
[TD]DTC B3984[/TD]
[/TR]
  VIN Decode
Posted by: Rusty2009 - 21:st-Feb-2014, 11:44:39 - Forum: Vauxhall General - Replies (1)
VIN Decode
Example    W0LPE6ED5A8123456
Digit(s)
1st – 3rd World Manufacturers Code
•    W0L = Adam Opel AG / Ltd
•    W0L = Vauxhall Motors Limited
•    WJR = Irmscher GmbH
•    W0SV = opel Special Vehicles GmnH
• XUF = GM Auto LLC (only for Russia)
• XWF = Avtotor (only for Russia)
4th     Platform
•    G = Insignia
•    P = Astra J
•    S = Meriva-B
•    W = Cascada
5th     Body Trim Level
•    C = Expression
•    D = Exclusiv
•    E = SE/Elite
•    F = Sri
6th Body Shape
•    2 = 2-door Sedan, Hatchback (GM code 08)
•    5 = 4-door Saloon (GM code 69)
•    6 = 4-door Sedan, Hatchback (GM code 68)
•    8 = 4-door combination, Estate (GM code 35)
7th     Restraint system
•    C = Front airbags
•    D = Seatbelts with pretensioners, front and side airbags (front)
•    E = Seatbelts with pretensioners, airbags front, side (front) and roof
8th     Engine (not all variants are available)
•    A = A13DTE (LSF)
•    B = A14XEL (LDD)
•    C = A14NEL (LUJ)
•    D = A16XER (LDE)
•    E = Z16XNT (LGE)
•    F = A17DTR (LPL)
•    G = A17DTJ (LPV)
•    H = A17DTS (LUD)
•    J = A16LET (LLU)
•    K = A17DTC (LUE)
•    L = A20DTL (LBQ)
•    M = A20DT (LBR)
•    N = A20DTH (LBS)
•    P = Y/Z20DTJ (LBX)
•    R = A20DTR (LBY)
•    S = A20NFT (LHU)
•    T = A14XEL (LDD)
•    U = A14NEL (LUJ)
•    V = A17DTL (LPV)
•    W = A17DTE (LKR)
•    X = A17DTE (LKR)
• Y = A17DTN (LUE)
• Z = A16XHT (LVP)
• 1 = A18XER (2H0)
• 2 = A18XEL (2H0)
• 3 = B16DTH (LVL)
• 4 = 2.0 petrol (LHU)
• 5 = A16SHT (LWC)
• 6 = B16DTL (LVM)
9th     Check digit (after calculation scheme)
10th Model Year (MY)
•    A = 2010
•    B = 2011
•    C = 2012
•    D = 2013
•    E = 2014
•    F = 2015
•    G = 2016
•    H = 2017
11th Factory, place of build
•    1 = Rüsselsheim, Germany
•    2 = Bochum, Germany
•    3 = St. Petersburg, Russia
•    8 = Ellesmere Port, United Kingdom
•    G = Gliwice, Poland
12th – 17th    Ongoing vehicle number (any model year, beginning 000001)
  Option / Equipment Codes
Posted by: Rusty2009 - 21:st-Feb-2014, 11:27:40 - Forum: Vauxhall General - Replies (1)
RPO - Description
UDB - DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (SEGMENTED)
UDC - DISPLAY INSTRUMENT - DRIVER INFO ENHANCED (ONE COLOUR GRAPHIC)
UDK - INFOTAINMENT DISPLAY - COLOUR INFO DISPLAY (CID) 7", QVGA
UEC - SENSOR INDICATOR - AUTOMATIC AIR RECIRCULATION
UFD - INFOTAINMENT DISPLAY - TIME, EXTERNAL TEMP, RADIO
UH0 - INDICATOR - SEAT BELT WARNING , LH
UH1 - INDICATOR - SEAT BELT WARNING , RH
UJN - TYRE PRESS INDICATOR - AUTO LEARN
UL5 - RADIO - (NONE)
ULS - LOCK CONTROL - STEERING COLUMN
UMN - SPEEDOMETER - INST, MILES & KILO, MILES ODOMETER
UPH - WIRELESS INTERFACE - SHORT RANGE, VOICE REC, SMS
UPI - WIRELESS INTERFACE - SHORT RANGE, VOICE REC, LOW SPEED, GMLAN
UPJ - WIRELESS INTERFACE - SHORT RANGE, VOICE REC, SMS, EMBEDDED PHONE
UQ9 - SPEAKER SYSTEM - (- DELETE)
UQA - SPEAKER SYSTEM - PREMIUM AUDIO BRANDED WITH AMPLIFIER
URC - SWITCH - FLEXRIDE MODE SYSTEM
US3 - ANTENNA - DIVERSITY
UTJ - THEFT DETERENT - ELECTRICAL, UNAUTHORIZED ENTRY
UTR - ALARM, HORN - CONTENT THEFT DETERENT, SELF POWERED
UTT - THEFT DETERENT - BODY SECURITY CONTENT
UTU - SENSOR, VEHICLE - INCLINATION
UTV - SENSOR, VEHICLE - INTERIOR MOVEMENT
UVD - SWITCH - STEERING WHEEL, HEATED
UVT - CAMERA - LANE DEPARTURE WARNING, TRAFFIC SIGN RECOGNITION
UW4 - SPEAKER SYSTEM - 4, CUSTOM
UWI - TELEPHONE - MOBILE, CRADLE, ANTENNA & RECHARGE, FLOOR CONSOLE
UYB - RADIO - AM/FM STEREO, CD-ROM, CAF, RSA (GME/ME/TAIWAN VERSION)
UYI - RADIO - AM/FM STEREO, CDX-ROM, CAF, RSA, MUSIC NAVIGATOR (GME/ME/TAIWAN VERSION)
UZZ - RADIO - AM/FM STEREO, CD-ROM, CAF, RSA, MUSIC NAVIGATOR (GME/ME/TAIWAN VERSION)
V2O - PANEL CENTRE - ONE LAYER PAINT DARK PEARL
V3X - PANEL CENTRE - DUAL LAYER PAINT SILVER DUST
V4L - PANEL CENTRE - DUAL FOIL LIQUID PALLADIUM/DARK MATRIX
V5U - PANEL CENTRE - DUAL FOIL PIANO BLACK & LIQUID PALLADIUM
VFB - PROTECTOR - BODY, QTR OUTER PANEL DAMAGE
VGC - PROTECTOR - FILM, PAINT ETCH PREVENTIVE
VHY - PROTECTOR - BODY SHEET METAL, HIGH CORROSION PREVENTIVE
VK8 - HOLDER - EYEGLASSES
VNF - ISOLATOR - BATTERY
VPQ - VEHICLE PREPARATION - REMOVER, PROTECTIVE SHIPPING WAX
VQ9 - TRAILER HITCH - REMOVABLE HOOK, HEAVY DUTY
VY7 - KNOB - TRANS CONT LEVER, LEATHER
W72 - SALES PACKAGE - DRIVING SCHOOL
W2E - SEAT - FRT BKT, RECARO
W2V - ORNAMENTATION - LETTERING, VAR - DELETE
WBP - SALES PACKAGE - APPEARANCE
WTC - TYRE & WHEEL - INFLATOR KIT (DO NOT USE AFTER M.Y. 2011)
QVF - TYRE ALL - 205/60R16-92H BW R/ST TL HW3 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QXX - TYRE ALL - 235/40R19-92W BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QYA - TYRE ALL - 225/50R17-94V BW R/ST TL AL3 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QZQ - TYRE ALL - 215/60R16-95H BW R/ST TL HW3 (LOW ROLL RESISTANCE) (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QZZ - TYRE ALL - 225/50R17-94V BW R/ST TL HW4 (LOW ROLL RESISTANCE) (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
RHD - VEHICLE DRIVE - RIGHTHAND DRIVE
RT4 - WHEEL - 18 X 8.0, J, ALUMINIUM, DESIGN 1
SF4 - ACCESSORY - WHEEL COVERS - ALTERNATE DESIGN
SFE - ACCESSORY - WHEEL LOCKS
SFO - ACCESSORY - WINTER WHEEL PACKAGE, 16" STEEL
T39 - LAMP - INDICATOR, AUX
T3N - LAMP SYSTEM - DAYTIME RUNNING, SEPARATE CAVITY
T3U - LAMP - FRT FOG
T43 - SPOILER - RR
T4A - HEADLAMPS - HALOGEN
T4F - HEADLAMPS - HIGH INTENSITY DISCHARGE
T74 - HEADLAMPS CONTROL - AUTOMATIC, DELAY
T79 - LAMP - FOG, RR
T94 - HEADLAMPS CONTROL - LH RULE OF THE ROAD
T95 - HEADLAMP CONTROL - BEAM, DIRECTIONAL (AFL)
TBT - PLANT CODE - ST.PETERSBURG, RUSSIA
TQ5 - SENSOR - HEADLAMP HIGH BEAM AUTO CONTROL
TR0 - LAMP - INTR, ROOF, RR, COURTESY & DUAL READING
TR6 - HEADLAMPS CONTROL - LEVELING SYSTEM, MANUAL
TR7 - HEADLAMP CONTROL - LEVELLING SYSTEM, AUTOMATIC, STATIC
TS6 - LAMP - STOP, HIGH LEVEL
TTW - HEADLAMPS CONTROL - AUTOMATIC ON-OFF, TUNNEL DETECTION
TTX - RADIO EQUIPMENT - AUX CONNECTOR (LINE IN)
U04 - HORN - SINGLE NOTE
U07 - HORN - FANFARE
U18 - SPEEDOMETER - INST, KILO
U65 - SPEAKER SYSTEM - 7, PREMIUM
U66 - SPEAKER SYSTEM - 7, CUSTOM
U68 - DISPLAY - DRIVER INFO CENTRE
U74 - ANTENNA - RADIO - NONE
U91 - AERIAL - SHORT, ROOF, RADIO
UAG - INFOTAINMENT DISPLAY - GRAPHIC INFO DISPLAY (GID), VAR 1
UBT - DIGITAL AUDIO SYSTEM - BROADCAST, TEXT
UC3 - CONTROL - STEERING WHEEL, RADIO & PHONE, REDUNDANT CONTROLS
UCU - RADIO - AM/FM STEREO, SD NAV, CD-ROM, CAF, USB, RSA, TMC (GME VERSION)
UCW - RADIO - AM/FM STEREO, SD NAV, CD-ROM, CAF, USB, RSA, VOICE REC (GME VERSION)
UD5 - SENSOR INDICATOR - PARKING ASSIST
UD7 - SENSOR INDICATOR - REAR PARKING ASSIST
GOL - PRIMARY COLOUR - EXTERIOR, FRESKO, MET (G)
GSI - MODEL CONVERSION - SPORT GSI
GWP - PLANT CODE - GLIWICE, POLAND
GZ3 - FUEL TANK FILLER - NECK, UNRESTRICTED
HCZ - PARTS PKG - MISCELLANEOUS CHASSIS
HLE - MERCHANDISED PKG - PERFORMANCE CONVERSION
IK9 - CAMPAIGN PKG - CAMPAIGN "ECOFLEX"
J60 - BRAKE SYSTEM - POWER, FRT & RR DISC, ABS, 16"
J67 - BRAKE SYSTEM - POWER, FRT & RR DISC, ABS, 15"
J71 - BRAKE PARKING - POWER OPERATED
JF5 - PEDALS - SPORTY, ALLOY
JP2 - PEDALS - DOUBLE, DRIVING SCHOOL
K07 - HEATER - RADIATOR, COOLANT, FUEL FIRED, TIMER
K34 - CRUISE CONTROL - AUTOMATIC, ELECTRONIC
K3K - BATTERY - LBN1, FLA, 12V, 50AH, 375 ENCCA
K3L - BATTERY - LBN2, FLA, 12V, 60AH, 438 ENCCA
K3N - BATTERY - LBN3, FLA, 12V, 70AH, 512 ENCCA
K3S - BATTERY - LBN4, FLA, 12V, 75AH, 720 ENCCA
K48 - EQUIPMENT - PACKAGE, EXTREME DUST
K60 - ALTERNATOR - 100 AMP
KA1 - HEATER - SEAT, FRT
KB5 - CONTROL - ECM GRADE BRAKING
KC5 - RECEPTACLE - ELECTRICAL, ACCESSORY
KC7 - RECEPTACLE - ELECTRICAL, RR SEAT
KCL - HEATER - DUCT, RR PASS (2ND POSN)
KG8 - GENERATOR - 130 AMP
KG9 - ALTERNATOR - 140 AMP
KL9 - ENG CONTROL - STOP/START SYS
KRP - PROVISIONS - INFOTAINMENT UNIT DELETE
KTA - AUDIO INTERFACE
KTM - KEY - PRIMARY FOLDABLE, ADDITIONAL RIGID
LBS - ENGINE - DIESEL, 4 CYL, 2.0L, L4, CPI, TURBO, HO, DOHC, 121KW
LBY - ENGINE - DIESEL, 4 CYL, 2.0L, L4, CRI, TWIN TURBO, DOHC, 140 KW,
LDD - ENGINE - PETROL, 4 CYL, 1.4L, MFI, DOHC, VARIABLE CAMSHAFT PHASING, FAM 0
LDE - ENGINE - PETROL, 4 CYL, 1.6L, MFI, DOHC, VVT, VARIABLE CAMSHAFT PHASING, VARIABLE INTAKE MODULE (VIM)
LHD - VEHICLE DRIVE - LEFTHAND DRIVE
LLU - ENGINE - PETROL, 4 CYL, 1.6L, MFI, DOHC, TURBO, PT-JV, 132KW
LPL - ENGINE - DIESEL, 4 CYL, 1.7L, L4, CRI, TURBO-HIGH, HO, DOHC
LPV - ENGINE - DIESEL, 4 CYL, 1.7L, L4, CRI, TURBO-HIGH, HO, DOHC81KW
LSF - ENGINE - DIESEL, 4 CYL, 1.3L, CRI, DOHC, TURBO-VGT
LUJ - ENGINE - PETROL, 4 CYL, L4, 1.4L, MFI, DOHC, TURBO HO, ALUM, GME
M26 - GEARBOX - MAN 5 SPD, OPEL, 65 MM, 1.96 2ND, 1.323 3RD, 0.946 4TH, 0.756 5TH, F17 (WR)
M36 - TRANSMISSION - AUTO 6 SPD, AISIN-WARNER, A6-F40, ELECTRONIC (ACTIVE SELECT)
M7Q - GEARBOX - MAN 5 SPD, 65 MM, 3.727 1ST, 2.136 2ND, 1.323 3RD, 0,892 4TH ,0.674 5TH, (F17 ER)
MDB - MOULDING B/S UPPER - BLACK
MDE - MOULDING B/S UPPER - BRIGHT, WINDOW ALL AROUND
MDG - GEARBOX - MAN 5 SPD, 180MM, 3.909 1ST, 0.892 5TH, F17
MDK - TRANSMISSION - AUTO 6 SPD, AISIN-WARNER, A6-AF40, ELECTRONIC, GEN2
MH7 - TRANSMISSION - AUTO 6 SPD, HMD, X23FHD
MH8 - TRANSMISSION - AUTO 6 SPD, HMD, X23F
MYJ - GEARBOX - MAN 6 SPD, (F40-6, FWD) 1ST 4.167, SIXTH 0.623
MZ0 - GEARBOX - MAN 6 SPD, OPEL, 76.5 MM, 3.82 1ST, 0.74 6TH, (M32 WR)
MZ4 - GEARBOX - MAN 6 SPD, OPEL, 76.5 MM, 3.82 1ST, 0.615 6TH, (M32 WR)
N34 - STEERING WHEEL - LEATHER, 3 SPOKES
N35 - STEERING WHEEL - LEATHER, 3 SPOKES, SPORT
N37 - STEERING COLUMN - TILT, TELESCOPING
N40 - STEERING - POWER, NON-VARIABLE RATIO
N45 - STEERING WHEEL - 3 SPOKES
N52 - STEERING WHEEL - 3 SPOKES, DELUXE
N55 - STEERING WHEEL - LEATHER, 3 SPOKES, SPORT, ERGONOMIC
NE9 - EMISSION SYSTEM - EEC 09
NJ0 - STEERING - POWER, NON-VARIABLE RATIO, ELECTRIC, REDUCED RACK TRAVEL
NJ1 - STEERING - POWER, NON-VARIABLE RATIO, ELECTRIC
P76 - TYRE & WHEEL - SPARE, SPACE SAVER, STEEL 16" (DO NOT USE AFTER M.Y. 2011)
PGQ - WHEEL - 17 X 7, ALUMINIUM, DESIGN 14 (TBD) GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWM - WHEEL - 16 X 6.5, STEEL, DESIGN2 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWP - WHEEL - 17 X 7, STEEL, DESIGN3 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWT - WHEEL - 17 X 7, STEEL, DESIGN5 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PWX - WHEEL - 17 X 7, ALUMINIUM, DESIGN8 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PXS - WHEEL - 17 X 7, ALUMINIUM, DESIGN T.B.D, CAMPAIGN MY11 (DO NOT USE AFTER M.Y. 2011)
PZ4 - WHEEL - 18 X 7.5, J, ALUMINUM, POLISHED (DO NOT USE AFTER M.Y. 2011)
PZJ - WHEEL - 18 X 8, ALUMINIUM, DESIGN9 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZK - WHEEL - 18 X 8, ALUMINIUM, DESIGN10 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZS - WHEEL - 19 X 8, ALUMINIUM, DESIGN 12 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZT - WHEEL - 19 X 8, ALUMINIUM, DESIGN13 TBD GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZV - WHEEL - 18 X 7.5, ALUMINIUM, DESIGN15 (TBD), GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
PZW - WHEEL - 18 X 7.5, ALUMINIUM, DESIGN16 (TBD), GLOBAL DELTA (DO NOT USE AFTER M.Y. 2011)
Q1X - TYRE ALL - 205/55R16 SL 91H BW HW3
Q5Q - TYRE ALL - 225/45R17 SL 91V BW HW3
QAJ - TYRE ALL - 215/50R17-91V BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QDR - TYRE ALL - 225/45R18-91V BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGRAMS)
QOG - TYRE ALL - 205/60R16-92H BW R/ST TL AL3 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QQ5 - TYRE & WHEEL - SPARE, FULL SIZE, STEEL - (DO NOT USE AFTER MY 2011)
QQI - TYRE ALL - 215/60R16 SL 95V BW HW3
QQT - TYRE ALL - 215/60R16 SL 95H BW AL3
QRO - TYRE ALL - 235/45R18-94W BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
QUH - TYRE ALL - 225/50R17-94V BW R/ST TL HW4 (DO NOT USE AFTER 2011 ON NEW/MAJOR PROGS)
DVA - CLUSTER COLOUR - INST, BLACK, BLACK RINGS W/SILVER TOP
DVN - CLUSTER COLOUR - INST, BLACK, TRANSLUCENT RINGS
DWE - MIRROR O/S - LH & RH, RC, ELEC, HEAT, AUX WFOV/DRVR, MANFOLD, CNVX/PASS
DWF - MIRROR O/S - LH & RH, RC, ELEC, HEAT, AUX WFOV/DRVR, PWRFOLD, CNVX/PASS
E17 - BUMPER - 2.5 MPH
E3C - COVER - EXHAUST, REAR PIPE
E6F - COUNTRY - GEORGIA
E6H - COUNTRY - OMAN
E6R - COUNTRY - GREENLAND
E7C - COUNTRY - LIBYA
E7E - COUNTRY - MADAGASCAR
E7J - COUNTRY - MAURITIUS
E7M - COUNTRY - MONTENEGRO
EA1 - POCKET - FRONT SEAT BACK, LH
EA2 - POCKET - FRONT SEAT BACK, RH
EBW - TRIM SEAT - CLOTH, CORDOBA
EBX - TRIM SEAT - CLOTH, SCENE MODIFIED
EBY - TRIM SEAT - CLOTH, LACE
EBZ - TRIM SEAT - CLOTH, RIBBON
ECC - TRIM SEAT - LEATHER, PERFORATED MONDIAL
ELL - PLANT CODE - ELLESMERE PORT, ENGLAND
EMB - TRIM SEAT - CLOTH, TRACK
F45 - CHASSIS - CONTINUOUSLY VARIABLE REAL TIME DAMPING
F82 - RATIO - TRANSAXLE FINAL DRIVE 3.23
FBD - TRIM DOOR - CLOTH, ATLANTIS
FCS - TRIM DOOR - URETHANE, MONDIAL
FM9 - RATIO - TRANSAXLE FINAL DRIVE 3.20
FP9 - RATIO - TRANSAXLE FINAL DRIVE 3.55
FV1 - RATIO - TRANSAXLE FINAL DRIVE 3.72
FV2 - RATIO - TRANSAXLE FINAL DRIVE 4.18
FV5 - RATIO - TRANSAXLE FINAL DRIVE 4.19
FW6 - RATIO - TRANSAXLE FINAL DRIVE 3.42
FX1 - RATIO - TRANSAXLE FINAL DRIVE 3.94
FX3 - RIDE AND HANDLING - AUTOMATIC ELECTRONIC CONTROLLED
FX6 - RATIO - TRANSAXLE FINAL DRIVE 3.87
FXB - RATIO - TRANSAXLE FINAL DRIVE 3.65
FXH - RATIO - TRANSAXLE FINAL DRIVE 3.53
GAL - PRIMARY COLOUR - EXTERIOR, TECHNICAL GREY, MET.2
GAZ - PRIMARY COLOUR - EXTERIOR, OLYMPIC WHITE (G) 8624
GBG - PRIMARY COLOUR - EXTERIOR, BLACK SAPPHIRE, MICA (G)
GCS - PRIMARY COLOUR - EXTERIOR, VELVET RED MET (G)
GCW - PRIMARY COLOUR - EXTERIOR, MISTY LAKE MET (G)
GEK - PRIMARY COLOUR - EXTERIOR, ROYAL BLUE (G)
GEU - PRIMARY COLOUR - EXTERIOR, WATERWORLD BLUE MET (G)
GKE - PRIMARY COLOUR - LINEN BEIGE MET
GNA - CHASSIS EQUIP FRONT - STRUT ASM
GNG - CHASSIS EQUIP REAR - REAR AXLE, COMPOUND CRANK, ADDITIONAL WATT AGE
GOK - PRIMARY COLOUR - EXTERIOR, SILKY SHADOW, MET (G)
CT9 - COUNTRY - SPAIN
CU0 - COUNTRY - UKRAINE
CU1 - COUNTRY - NORWAY
CU2 - COUNTRY - FINLAND
CU3 - COUNTRY - FRANCE
CU4 - COUNTRY - SWEDEN
CU5 - COUNTRY - SWITZERLAND
CU6 - COUNTRY - TAIWAN
CU9 - COUNTRY - UNITED KINGDOM
CV0 - COUNTRY - ALBANIA
CV1 - COUNTRY - ICELAND
CV4 - COUNTRY - ISRAEL
CV9 - COUNTRY - TURKEY
CW0 - COUNTRY - ARMENIA
CX0 - COUNTRY - AZERBAIJAN
CX9 - COUNTRY - LEBANON
CY2 - COUNTRY - JORDAN
CY5 - COUNTRY - SERBIA
CY9 - COUNTRY - ESTONIA
CZ3 - COUNTRY - RUSSIA
CZ5 - COUNTRY - SOUTH AFRICA
CZ6 - COUNTRY - KAZAKHSTAN
CZ8 - COUNTRY - MACEDONIA
D2G - COUNTRY - ALGERIA
D2I - COUNTRY - LITHUANIA
D2S - COUNTRY - KYRGYZSTAN
D31 - MIRROR I/S R/V - TILT
D3C - COUNTRY - BOSNIA-HERZEGOVINA
D3G - COUNTRY - CAPE VERDE ISLANDS
D3H - COUNTRY - BELARUS
D3N - COUNTRY - YUGOSLAVIA
D3O - COUNTRY - MOLDOVA
D3S - COUNTRY - QATAR
D3T - COUNTRY - TURKMENISTAN
D3Z - COUNTRY - ANDORRA
D4A - COUNTRY - LATVIA
D4C - COUNTRY - BAHRAIN
D5M - COUNTRY - TAJIKISTAN
D6I - MIRROR I/S FRT VAN - SUNSHADE, DRIVER, W/MIRROR, COVER, ILLUM, PASS, W/MIRROR, COVER, ILLUM
D75 - HANDLE O/S DOOR - BODY COLOUR
D8G - CARRIER PKG - RR MOUNTED, 2 PLACE BICYCLE
DA2 - ARM REST - RR SEAT, STORAGE, PASS THROUGH
DBU - CONSOLE - FRT COMPT, FLOOR, ARM REST SLIDING
DD8 - MIRROR I/S R/V - LT SENSITIVE
DLU - MIRROR I/S FRT VAN - SUNSHADE, DRIVER, W/O MIRROR, PASS, W/MIRROR & COVER
DP6 - MIRROR PROVISIONS - HOUSING, PAINTED
DT4 - ASHTRAY - CIGARETTE LIGHTER
01A - TRIM COLOUR SEAT - JET BLACK
01W - TRIM COLOUR SEAT - OCEAN
01Y - TRIM COLOUR SEAT - SONIC BLUE
1AB - TRIM COLOUR DR PANEL - JET BLACK
1AW - TRIM COLOUR DR PANEL - OCEAN
1AX - TRIM COLOUR DR PANEL - SPICE RED
2BP - MOULDING DOOR INTR - ONE LAYER PAINT DARK PEARL
2BQ - MOULDING DOOR INTR - DUAL LAYER PAINT SILVER DUST
2CG - MOULDING DOOR INTR - DUAL FOIL LIQUID PALLADIUM/DARK MATRIX
2CL - MOULDING DOOR INTR - DUAL FOIL PIANO BLACK & LIQUID PALLADIUM
4A0 - INTERIOR TRIM - JET BLACK/SPICE RED
4AA - INTERIOR TRIM - JET BLACK
4AZ - INTERIOR TRIM - JET BLACK/OCEAN
9C1 - SALES PACKAGE - POLICE VEHICLE
A51 - SEAT - FRT BKT, CUSTOM
A53 - ADJUSTER PASS ST - MANUAL, 6 WAY
A64 - SEAT RR - SPLIT, FOLDING, 40/60
A69 - RESTRAINT - SEAT BELT TENSIONER, FRT, VAR. 2
ADL - RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS, SINGLE STAGE
AE4 - SEAT - FRT BKT, SPORT
AEF - WINDOW - POWER OPERATED, PASSENGER, EXPRESS UP/DOWN
AER - WINDOW - POWER OPERATED, RR DRS, EXPRESS UP/DOWN
AF8 - LOCK CONTROL - SIDE DOOR, ANTI THEFT PROTECTION
AFA - INTERIOR TRIM CONFIG - #1
AG5 - ADJUSTER PASS ST - MANUAL, 2 WAY
AH3 - ADJUSTER FRT ST - MANUAL, 4 WAY, DRIVER
AH4 - ADJUSTER FRT ST - MANUAL, 6 WAY, DRIVER
AHC - CONTROL - SEAT, MANUAL CUSHION EXTN, DRIVER
AHF - CONTROL - SEAT, MANUAL CUSHION EXTN, PASS
AHN - RESTRAINT PROVISIONS - CATCH
AHS - RESTRAINT - HEAD, FRT SEAT, UP/DOWN, FORE/AFT ADJUSTMENT, ACTIVE
AJC - RESTRAINT - HEAD, FRT SEAT, UP/DOWN ADJUSTMENT
AJF - RESTRAINT - HEAD, FRT SEAT, UP/DOWN ADJUSTMENT, ACTIVE
AJG - RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS, FRT & SEAT SIDE, SINGLE STAGE
AKN - WINDOW TYPE - TINTED
AKO - WINDOW TYPE - PRIVACY
AKW - WINDSCREEN TYPE - TINTED
AL9 - CONTROL - SEAT, POWER LUMBAR, DRIVER
AQP - RESTRAINT - HEAD, RR SEAT, CENTRE
ASV - EQUIPMENT - SENSOR AIR MOISTURE & W/S TEMP
AT9 - CONTROL - SEAT, POWER LUMBAR, PASS
AWO - RESTRAINT SYSTEM RR - SEAT BELT, REAR, 3 POINT, CTR
AXG - WINDOW - POWER OPERATED-EXPRESS DRIVER UP/DOWN
AXJ - VEHICLE TYPE - PASSENGER CAR
AYC - RESTRAINT SYSTEM - SEAT, INFLATABLE, DRIVER & PASS FRT, SEAT SIDE, ROOF SIDE, SINGLE STAGE
B6U - FLOOR - LUGGAGE, ADJUSTABLE
B50 - COVERING - FLOOR MAT, FRT & RR, AUX – DELUXE
B72 - PLATE - DOOR SILL CVR
B75 - TRIM EQUIPMENT - LUGG COMPT LINING
BA8 - COMPARTMENT - STOWAGE, FRT SEAT, PASS
BAH - EQUIPMENT - SECURITY SYSTEM, IMMOBILIZATION, STEP TWO
BF7 - COMPARTMENT - STOWAGE, FRT SEAT, LEFT
BFG - SEO COLOR CODE #2 - NEUTRAL WA5236
C1R - ORNAMENTATION INTR - I/P PAD, JET BLACK
C1S - ORNAMENTATION INTR - I/P PAD, SPICE RED
C1T - ORNAMENTATION INTR - I/P PAD, OCEAN
C25 - WIPER SYSTEM - RR WINDOW, INTERMITTENT
C32 - HEATER - HEATING/DEFROSTER SYSTEM, REINFORCED, ELECTRIC
C42 - HVAC SYSTEM - HEATER, OUTSIDE AIR, DELUXE
C49 - DEFOGGER - RR WINDOW, ELECTRIC
C67 - HVAC SYSTEM - AIR CONDITIONER FRT, ELECTRONIC CONTROLS
C95 - LAMP - INTR, ROOF, COURTESY & DUAL READING
C99 - SWITCH - INFL RST I/P MDL MAN SUPPRESSION
C9B - LAMP - INTR, AMBIENT, DOOR
C9D - LAMP - INTR, AMBIENT, CONSOLE
CE1 - WIPER SYSTEM - WINDSCREEN, PULSE, MOISTURE SENSITIVE
CE4 - WASHER - HEADLAMP, HIGH PRESSURE
CF5 - ROOF - SUN, GLASS, SLIDING, ELEC
CJ2 - HVAC SYSTEM - AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
CJ6 - COUNTRY - IRELAND
CJ8 - COUNTRY - BULGARIA
CJ9 - COUNTRY - ROMANIA
CK2 - COUNTRY - YEMEN
CK4 - COUNTRY - GREECE
CK7 - COUNTRY - SINGAPORE
CL4 - COUNTRY - UZBEKISTAN
CL9 - COUNTRY - HONG KONG
CR2 - COUNTRY - SLOVENIA
CR4 - COUNTRY - DUBAI
CR5 - COUNTRY - CROATIA
CR6 - COUNTRY - POLAND
CR7 - COUNTRY - HUNGARY
CR8 - COUNTRY - EGYPT
CR9 - COUNTRY - MOROCCO
CS0 - COUNTRY - CZECH REPUBLIC
CS1 - COUNTRY - TUNISIA
CT0 - COUNTRY - SLOVAKIA
CT1 - COUNTRY - BELGIUM
CT2 - COUNTRY - AUSTRIA
CT3 - COUNTRY - GERMANY
CT4 - COUNTRY - LUXEMBOURG
CT5 - COUNTRY - NETHERLANDS
CT6 - COUNTRY - ITALY
CT7 - COUNTRY - DENMARK
CT8 - COUNTRY - PORTUGAL
XFE - FUEL ECONOMY - EXTRA FUEL ECONOMY
XJ2 - CHASSIS - SPORT, LOWERED
XJ3 - CHASSIS - SPORT, LOWERED, MODIFIED
XL4 - CHASSIS - PROTECTION KIT, ENGINE COMPARTMENT
XL8 - FREQUENCIES RATING - 433 MHZ
XQ2 - EQUIPMENT - VAUXHALL
Y67 - DISPLAY - REMINDER PACKAGE
Z1V - EQUIPMENT - ADDITIONAL KEY
Z3S - CONVERSION NAME PLT - "ELITE"
ZP7 - SEATING ARRANGEMENT - 7 PASS
  Paint Codes
Posted by: Rusty2009 - 21:st-Feb-2014, 11:21:48 - Forum: Vauxhall General - Replies (2)
paint name,....... paint type,..... paint code.
BLACK PEARL.... PREAL... TACW
myth green,.... Pearl,..... 30/GAY.
METRO BLUE,.... Met,........ 168/GBI.
Flaming Yellow,....... Brilliant,....... 40Q/AJU.
TECHNICAL GRAY,....... Met,.... 177/GAL.
Fresh Mint,....... Met,..... 30Q/GOK.
Iceberg,...... Pearl,..... 21Y/GEP.
CARBON FLASH,...... Met,..... 22C/GAR.
BLACK SAPPHIRE,...... Pearl,..... 20/GAR.
ROYAL BLUE,..... Solid,..... 20Z/GEV.
WATER WORLD,...... Pearl,...... 22A/GEU.
Power Red,....... Solid,..... 50B/GBH.
OLYMPIC WHITE,..... Solid,..... 40R/GAZ.
Silver Lake,..........Met,........179/GEV.
Sovereign Silver,..... Met,...... 176/GAN.
FRESCO,....... Met,...... 22M/GOL.
PANNACOTTA,...... PEARL,..... 167/GBF.
SUMMIT WHITE ....... ?........ ?
  Fuses
Posted by: Rusty2009 - 21:st-Feb-2014, 11:18:42 - Forum: Electrical - Replies (11)
PLEASE NOTE THAT FUSE RATINGS VARIES ACROSS THE RANGE IT IS YOUR RESPONSIBILITY TO CHECK THE RATING AND REPLACE LIKE FOR LIKE
VXOC WILL NOT BE HELD ACCOUNTABLE FOR ANY DAMAGE CAUSED TO YOUR VEHICLE.
Fuses
Engine Compartment Fuse box:
1 Engine control module = 20 A
2 Lambda probe = 10 A
3 Fuel injection, ignition system = 15 A
4 Fuel injection, ignition system = 15 A
5 –
6 Mirror heating = 7.5 A
7 Fan control = 7 A
8 Lambda probe, engine = 7.5 A
9 Rear window sensor = 7.5 A
10 Battery sensor = 5 A
11 Trunk release = 7.5 A
12 Adaptive forward lighting module = 5 A
13 – = 25 A
14 Rear window wiper = 20 A
15 Engine control module = 10 A
16 Starter = 30 A
17 Transmission control module = 10 A
18 Heated rear window = 30 A
19 Front power windows = 30 A
20 Rear power windows =30 A
21 ABS = 40 A
22 Left high beam (Halogen) = 10 A
23 Headlamp washer system = 25 A
24 Right low beam (Xenon) = 15 A
25 Left low beam (Xenon) = 15 A
26 Fog lights = 15 A
27 Diesel fuel heating = 30 A
28 – = 30 A
29 Electrical parking brake = 30 A
30 ABS = 60 A
31 – = 5 A
32 Airbag = 5 A
33 Adaptive forward lighting = 15 A
34 – = 7.5 A
35 Power windows = 7.5 A
36 – = 10 A
37 Canister vent solenoid
38 Vacuum pump
39 Fuel system control module
40 Windscreen washer, Rear window washer system = 10 A
41 Right high beam (Halogen) = 10 A
42 Radiator fan = 40 A
43 Windscreen wiper = 30 A
44 – = 30 A
45 Radiator fan =
46 –
47 Horn = 15 A
48 Radiator fan = 60 A
49 Fuel pump = 20 A
50 Headlamp levelling = 10 A
51 Air shutter = 5 A
52 Auxiliary heater, diesel engine = 7.5 A OR 10 A
53 Transmission control module, Engine control module = 7.5 A OR 10 A
54 Wiring monitoring = 7.5 A
Glovebox fuse panel:
1 Displays
2 Exterior lights
3 Exterior lights
4 Radio
5 Infotainment system, instrument
6 Power outlet front = 20 A
7 Power outlet rear seat = 20 A
8 Left low beam = 30 A
9 Right low beam = 30 A
10 Door locks
11 Interior fan
12 –
13 –
14 Diagnostic connector
15 Airbag
16 –
17 Air conditioning system / heater control panel 10 A
18 Prefuse: radio, Infotainment, displays
19 Brake lights, tail lights, interior lights
20 –
21 –
22 Ignition switch
23 Body control unit
24 Body control unit
25 –
26 Power outlet load compartment
Rear electrical centre:
1 Trailer module
2 Trailer outlet
3 Parking assist
4 –
5 –
6 –
7 10A Seat heating control module, seat lumbar control module - passenger
8 Anti-theft alarm system
9 –
10 –
11 Trailer module, Trailer socket
12 –
13 Trailer outlet
14 –
15 7.5A Inside rear view mirror, rain sensor, vehicle direction camera, Wing mirror movement.
16 5A Inside rear view mirror
17 20A Accessary power receptacle - cargo (Estate with rear body fuse block)
18 –
19 Steering wheel heating
20 Sunroof
21 Seat heating
22 –
23 –
24 –
25 –
26 30A Feed for fuses F3, F8 and F32
27 –
28 –
29 –
30 –
31 Amplifier, Subwoofer
32 Active damping system, Lane departure warning
Fuse Types
Fuse Types
[TR]
[TD]Current Rating Amperes[/TD]
[TD]Color[/TD]
[/TR]
[TR]
[TD]Auto Fuses, Mini Fuses[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]Gray[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]Violet[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]Tan[/TD]
[/TR]
[TR]
[TD]7.5[/TD]
[TD]Brown[/TD]
[/TR]
[TR]
[TD]10[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]15[/TD]
[TD]Blue[/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]Yellow[/TD]
[/TR]
[TR]
[TD]25[/TD]
[TD]White or Natural[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]Green[/TD]
[/TR]
[TR]
[TD]Maxi Fuses[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]Yellow[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]Light Green[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]Orange or Amber[/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]Blue[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]J-Case Fuses[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]20[/TD]
[TD]Blue[/TD]
[/TR]
[TR]
[TD]30[/TD]
[TD]Pink[/TD]
[/TR]
[TR]
[TD]40[/TD]
[TD]Green[/TD]
[/TR]
[TR]
[TD]50[/TD]
[TD]Red[/TD]
[/TR]
[TR]
[TD]60[/TD]
[TD]Yellow[/TD]
[/TR]
  Engine and Gearbox Combinations
Posted by: Rusty2009 - 21:st-Feb-2014, 11:05:58 - Forum: Mechanical - Replies (9)
[TR]
[TD]PETROL ENGINES[/TD]
[TD]ENGINE CODES[/TD]
[TD]ENGINE BUILD CODE[/TD]
[TD]GEAR BOX[/TD]
[TD]BHP[/TD]
[TD]MODEL[/TD]
[/TR]
[TR]
[TD]1.4 VVT[/TD]
[TD]A14XER[/TD]
[TD]LDD[/TD]
[TD]F17WR[/TD]
[TD]100 BHP[/TD]
[TD]J, ESTATE[/TD]
[/TR]
[TR]
[TD]1,4 VVT TURBO[/TD]
[TD]A14NET[/TD]
[TD]LUJ[/TD]
[TD]M32WR[/TD]
[TD]140BHP 125BHP[/TD]
[TD]GTC,J,ESTATE[/TD]
[/TR]
[TR]
[TD]1.4 VVT TURBO AUTO[/TD]
[TD]A14NET[/TD]
[TD]LUJ[/TD]
[TD]AF40[/TD]
[TD]140BHP[/TD]
[TD]GTC,J, ESTATE[/TD]
[/TR]
[TR]
[TD]1.6 VVT[/TD]
[TD]A16XER[/TD]
[TD]LDE[/TD]
[TD]F17CR[/TD]
[TD]115BHP[/TD]
[TD]GTC,J ,ESTATE[/TD]
[/TR]
[TR]
[TD]1.6 VVT TURBO[/TD]
[TD]A16LET
+A16XHT[/TD]
[TD]LLU LVP[/TD]
[TD]M32WR AUTO AF40[/TD]
[TD]180BHP[/TD]
[/TR]
[TR]
[TD]1.6 VVT AUTO[/TD]
[TD]A16XER[/TD]
[TD]LDE[/TD]
[TD]6T40[/TD]
[TD]115BHP[/TD]
[/TR]
[TR]
[TD]2.0 TURBO[/TD]
[TD]A20NFT[/TD]
[TD]LHU[/TD]
[TD]F40WR[/TD]
[TD]276BHP[/TD]
[TD]GTC ONLY[/TD]
[/TR]
[TR]
[TD]DIESEL ENGINES[/TD]
[TD]GEARBOX[/TD]
[TD]BHP[/TD]
[TD]MODEL[/TD]
[/TR]
[TR]
[TD]1.3 CDTI[/TD]
[TD]A13DTE[/TD]
[TD]LSF[/TD]
[TD]F17ER[/TD]
[TD]95BHP[/TD]
[TD]J,ESTATE[/TD]
[/TR]
[TR]
[TD]1.7 CDTI[/TD]
[TD]A17DTJ
+A17DTR+A17DTE[/TD]
[TD]LUE LPL LUD LKR[/TD]
[TD]M32WR[/TD]
[TD]110BHP
125BHP+130bhp[/TD]
[TD]GTC, J,ESTATE[/TD]
[/TR]
[TR]
[TD]2.0 CDTI[/TD]
[TD]A20DTH[/TD]
[TD]LBS,[/TD]
[TD]F40WR[/TD]
[TD]160BHP[/TD]
[/TR]
[TR]
[TD]2.0 CDTI AUTO[/TD]
[TD]A20DTH[/TD]
[TD]LBS[/TD]
[TD]AF40[/TD]
[TD]160BHP[/TD]
[/TR]
[TR]
[TD]2.0 BITURBO[/TD]
[TD]A20DTR[/TD]
[TD]LBY[/TD]
[TD]F40WR[/TD]
[TD]195BHP[/TD]
[/TR]
[TR]
[TD]1.6 CDTI[/TD]
[TD]B16DTH
+B16DTL[/TD]
[TD]LVM LVL[/TD]
[TD]M32WR[/TD]
[TD]135BHP 110BHP[/TD]
[/TR]
WR = Wide Ratio
CR = Close Ratio
ER = Economy Ratio
Thank-you to Tucpal for supplying all the above information
That has been sourced from vauxhall information sites.
Some more info relating to the gearbox's
Gearbox Specifications you can download below.
Word document
or
PDF document
  Wheels and tyres
Posted by: Rusty2009 - 21:st-Feb-2014, 11:03:50 - Forum: Mechanical - Replies (25)
Wheels and tyres
For Astra J 5-door hatchback and Sports Tourer with 1.4, 1.6, 1.4T and 1.3CDTi engines:
PCD 5x105, centre bore 56.6mm
16" wheels: 6½J x 16 offset 39, tyre 205/60R16
17" wheels: 7J x 17 offset 42, tyre 215/50R17
18" wheels: 7½J x 18 offset 42, tyre 225/45R18
19" wheels: 8J x 19 offset 46, tyre 235/40R19
Space-saver spare: 4J x 16 offset ?? (BNX), tyre 115/70R16
Standard winter wheels are 6½Jx16 offset 39, tyre 205/60R16, other options possible
Braking system J67.
For Astra J 5-door hatchback and Sports Tourer with 1.6T, 1.7CDTi and 2.0CDTi engines:
PCD 5x115, centre bore 70.1mm
16" wheels: 6½J x 16 offset 41, tyre 215/60R16
17" wheels: 7J x 17 offset 44, tyre 225/50R17 94V
18" wheels: 8J x 18 offset 46, tyre 235/45R18
Space-saver spare: 4J x 16 offset ?? (FTW), tyre 115/70R16
Standard winter wheels are 6½Jx16 offset 41, tyre 205/60R16, other options possible
Braking system J60
For Astra J GTC all engines:
18" wheels: 7½J x 18 offset 41, tyre 235/50R18
19" wheels: 8J x 19 offset 36, tyre 235/45R19
20" wheels: 8½J x 20 offset 41, tyre 245/40R20
Space-saver spare: 4J x 17 offset ?? (MAP), tyre 125/70R17
Standard winter wheels are 7Jx17 offset 41, tyre 225/55R17, other options possible.
If you are considering changing your wheel or tyre size, this calculator is
helpful
ALSO TRY THIS http://tire-size-conversion.com/speedome...libration/
Speed Index
Speed Index
[TR]
[TD]Speed Rating[/TD]
[TD]MPH[/TD]
[TD]KPH[/TD]
[TD]MPH[/TD]
[TD]KPH[/TD]
[/TR]
[TR]
[TD]N[/TD]
[TD]87[/TD]
[TD]140[/TD]
[TD]U[/TD]
[TD]124[/TD]
[TD]200[/TD]
[/TR]
[TR]
[TD]P[/TD]
[TD]93[/TD]
[TD]150[/TD]
[TD]H[/TD]
[TD]130[/TD]
[TD]210[/TD]
[/TR]
[TR]
[TD]Q[/TD]
[TD]99[/TD]
[TD]160[/TD]
[TD]V[/TD]
[TD]149[/TD]
[TD]240[/TD]
[/TR]
[TR]
[TD]R[/TD]
[TD]106[/TD]
[TD]170[/TD]
[TD]Z[/TD]
[TD]150+[/TD]
[TD]240+[/TD]
[/TR]
[TR]
[TD]S[/TD]
[TD]112[/TD]
[TD]180[/TD]
[TD]W[/TD]
[TD]168[/TD]
[TD]270[/TD]
[/TR]
[TR]
[TD]T[/TD]
[TD]118[/TD]
[TD]190[/TD]
[TD]Y[/TD]
[TD]186[/TD]
[TD]300[/TD]
[/TR]
Load Index.
Load Index
[TR]
[TD]Load Index[/TD]
[TD]Load in KG[/TD]
[TD]Load Index[/TD]
[TD]Load in KG[/TD]
[TD]Load index[/TD]
[TD]Load in KG[/TD]
[/TR]
[TR]
[TD]62[/TD]
[TD]265[/TD]
[TD]84[/TD]
[TD]500[/TD]
[TD]106[/TD]
[TD]950[/TD]
[/TR]
[TR]
[TD]63[/TD]
[TD]272[/TD]
[TD]85[/TD]
[TD]515[/TD]
[TD]107[/TD]
[TD]975[/TD]
[/TR]
[TR]
[TD]64[/TD]
[TD]280[/TD]
[TD]86[/TD]
[TD]530[/TD]
[TD]108[/TD]
[TD]1000[/TD]
[/TR]
[TR]
[TD]65[/TD]
[TD]290[/TD]
[TD]87[/TD]
[TD]545[/TD]
[TD]109[/TD]
[TD]1030[/TD]
[/TR]
[TR]
[TD]66[/TD]
[TD]290[/TD]
[TD]88[/TD]
[TD]560[/TD]
[TD]110[/TD]
[TD]1060[/TD]
[/TR]
[TR]
[TD]67[/TD]
[TD]307[/TD]
[TD]89[/TD]
[TD]580[/TD]
[TD]111[/TD]
[TD]1090[/TD]
[/TR]
[TR]
[TD]68[/TD]
[TD]315[/TD]
[TD]90[/TD]
[TD]600[/TD]
[TD]112[/TD]
[TD]1120[/TD]
[/TR]
[TR]
[TD]69[/TD]
[TD]325[/TD]
[TD]91[/TD]
[TD]615[/TD]
[TD]113[/TD]
[TD]1150[/TD]
[/TR]
[TR]
[TD]70[/TD]
[TD]335[/TD]
[TD]92[/TD]
[TD]630[/TD]
[TD]114[/TD]
[TD]1180[/TD]
[/TR]
[TR]
[TD]71[/TD]
[TD]345[/TD]
[TD]93[/TD]
[TD]650[/TD]
[TD]115[/TD]
[TD]1215[/TD]
[/TR]
[TR]
[TD]72[/TD]
[TD]355[/TD]
[TD]94[/TD]
[TD]670[/TD]
[TD]116[/TD]
[TD]1250[/TD]
[/TR]
[TR]
[TD]73[/TD]
[TD]365[/TD]
[TD]95[/TD]
[TD]690[/TD]
[TD]117[/TD]
[TD]1285[/TD]
[/TR]
[TR]
[TD]74[/TD]
[TD]375[/TD]
[TD]96[/TD]
[TD]710[/TD]
[TD]118[/TD]
[TD]1320[/TD]
[/TR]
[TR]
[TD]75[/TD]
[TD]387[/TD]
[TD]97[/TD]
[TD]730[/TD]
[TD]119[/TD]
[TD]1360[/TD]
[/TR]
[TR]
[TD]76[/TD]
[TD]400[/TD]
[TD]98[/TD]
[TD]750[/TD]
[TD]120[/TD]
[TD]1400[/TD]
[/TR]
[TR]
[TD]77[/TD]
[TD]412[/TD]
[TD]99[/TD]
[TD]775[/TD]
[TD]121[/TD]
[TD]1450[/TD]
[/TR]
[TR]
[TD]78[/TD]
[TD]425[/TD]
[TD]100[/TD]
[TD]800[/TD]
[TD]122[/TD]
[TD]1500[/TD]
[/TR]
[TR]
[TD]79[/TD]
[TD]437[/TD]
[TD]101[/TD]
[TD]825[/TD]
[TD]123[/TD]
[TD]1550[/TD]
[/TR]
[TR]
[TD]80[/TD]
[TD]450[/TD]
[TD]102[/TD]
[TD]850[/TD]
[TD]124[/TD]
[TD]1600[/TD]
[/TR]
[TR]
[TD]81[/TD]
[TD]462[/TD]
[TD]103[/TD]
[TD]875[/TD]
[TD]125[/TD]
[TD]1650[/TD]
[/TR]
[TR]
[TD]82[/TD]
[TD]475[/TD]
[TD]104[/TD]
[TD]900[/TD]
[TD]126[/TD]
[TD]1700[/TD]
[/TR]
[TR]
[TD]83[/TD]
[TD]487[/TD]
[TD]105[/TD]
[TD]925[/TD]
[/TR]
Posted by: Rusty2009 - 21:st-Feb-2014, 10:53:21 - Forum: Introduction Area - Replies (7)
Hello,
I'm Rusty site Admin.
Would like to welcome all those who want to join the site.
