tyres and wheels
Wheels and tyres
Wheels and tyres
For Astra J 5-door hatchback and Sports Tourer with 1.4, 1.6, 1.4T and 1.3CDTi engines:
PCD 5x105, centre bore 56.6mm
16" wheels: 6½J x 16 offset 39, tyre 205/60R16
17" wheels: 7J x 17 offset 42, tyre 215/50R17
18" wheels: 7½J x 18 offset 42, tyre 225/45R18
19" wheels: 8J x 19 offset 46, tyre 235/40R19
Space-saver spare: 4J x 16 offset ?? (BNX), tyre 115/70R16
Standard winter wheels are 6½Jx16 offset 39, tyre 205/60R16, other options possible
Braking system J67.
For Astra J 5-door hatchback and Sports Tourer with 1.6T, 1.7CDTi and 2.0CDTi engines:
PCD 5x115, centre bore 70.1mm
16" wheels: 6½J x 16 offset 41, tyre 215/60R16
17" wheels: 7J x 17 offset 44, tyre 225/50R17 94V
18" wheels: 8J x 18 offset 46, tyre 235/45R18
Space-saver spare: 4J x 16 offset ?? (FTW), tyre 115/70R16
Standard winter wheels are 6½Jx16 offset 41, tyre 205/60R16, other options possible
Braking system J60
For Astra J GTC all engines:
18" wheels: 7½J x 18 offset 41, tyre 235/50R18
19" wheels: 8J x 19 offset 36, tyre 235/45R19
20" wheels: 8½J x 20 offset 41, tyre 245/40R20
Space-saver spare: 4J x 17 offset ?? (MAP), tyre 125/70R17
Standard winter wheels are 7Jx17 offset 41, tyre 225/55R17, other options possible.
If you are considering changing your wheel or tyre size, this calculator is
helpful
ALSO TRY THIS http://tire-size-conversion.com/speedome...libration/
Speed Index
Speed Index
[TR]
[TD]Speed Rating[/TD]
[TD]MPH[/TD]
[TD]KPH[/TD]
[TD]MPH[/TD]
[TD]KPH[/TD]
[/TR]
[TR]
[TD]N[/TD]
[TD]87[/TD]
[TD]140[/TD]
[TD]U[/TD]
[TD]124[/TD]
[TD]200[/TD]
[/TR]
[TR]
[TD]P[/TD]
[TD]93[/TD]
[TD]150[/TD]
[TD]H[/TD]
[TD]130[/TD]
[TD]210[/TD]
[/TR]
[TR]
[TD]Q[/TD]
[TD]99[/TD]
[TD]160[/TD]
[TD]V[/TD]
[TD]149[/TD]
[TD]240[/TD]
[/TR]
[TR]
[TD]R[/TD]
[TD]106[/TD]
[TD]170[/TD]
[TD]Z[/TD]
[TD]150+[/TD]
[TD]240+[/TD]
[/TR]
[TR]
[TD]S[/TD]
[TD]112[/TD]
[TD]180[/TD]
[TD]W[/TD]
[TD]168[/TD]
[TD]270[/TD]
[/TR]
[TR]
[TD]T[/TD]
[TD]118[/TD]
[TD]190[/TD]
[TD]Y[/TD]
[TD]186[/TD]
[TD]300[/TD]
[/TR]
Load Index.
Load Index
[TR]
[TD]Load Index[/TD]
[TD]Load in KG[/TD]
[TD]Load Index[/TD]
[TD]Load in KG[/TD]
[TD]Load index[/TD]
[TD]Load in KG[/TD]
[/TR]
[TR]
[TD]62[/TD]
[TD]265[/TD]
[TD]84[/TD]
[TD]500[/TD]
[TD]106[/TD]
[TD]950[/TD]
[/TR]
[TR]
[TD]63[/TD]
[TD]272[/TD]
[TD]85[/TD]
[TD]515[/TD]
[TD]107[/TD]
[TD]975[/TD]
[/TR]
[TR]
[TD]64[/TD]
[TD]280[/TD]
[TD]86[/TD]
[TD]530[/TD]
[TD]108[/TD]
[TD]1000[/TD]
[/TR]
[TR]
[TD]65[/TD]
[TD]290[/TD]
[TD]87[/TD]
[TD]545[/TD]
[TD]109[/TD]
[TD]1030[/TD]
[/TR]
[TR]
[TD]66[/TD]
[TD]290[/TD]
[TD]88[/TD]
[TD]560[/TD]
[TD]110[/TD]
[TD]1060[/TD]
[/TR]
[TR]
[TD]67[/TD]
[TD]307[/TD]
[TD]89[/TD]
[TD]580[/TD]
[TD]111[/TD]
[TD]1090[/TD]
[/TR]
[TR]
[TD]68[/TD]
[TD]315[/TD]
[TD]90[/TD]
[TD]600[/TD]
[TD]112[/TD]
[TD]1120[/TD]
[/TR]
[TR]
[TD]69[/TD]
[TD]325[/TD]
[TD]91[/TD]
[TD]615[/TD]
[TD]113[/TD]
[TD]1150[/TD]
[/TR]
[TR]
[TD]70[/TD]
[TD]335[/TD]
[TD]92[/TD]
[TD]630[/TD]
[TD]114[/TD]
[TD]1180[/TD]
[/TR]
[TR]
[TD]71[/TD]
[TD]345[/TD]
[TD]93[/TD]
[TD]650[/TD]
[TD]115[/TD]
[TD]1215[/TD]
[/TR]
[TR]
[TD]72[/TD]
[TD]355[/TD]
[TD]94[/TD]
[TD]670[/TD]
[TD]116[/TD]
[TD]1250[/TD]
[/TR]
[TR]
[TD]73[/TD]
[TD]365[/TD]
[TD]95[/TD]
[TD]690[/TD]
[TD]117[/TD]
[TD]1285[/TD]
[/TR]
[TR]
[TD]74[/TD]
[TD]375[/TD]
[TD]96[/TD]
[TD]710[/TD]
[TD]118[/TD]
[TD]1320[/TD]
[/TR]
[TR]
[TD]75[/TD]
[TD]387[/TD]
[TD]97[/TD]
[TD]730[/TD]
[TD]119[/TD]
[TD]1360[/TD]
[/TR]
[TR]
[TD]76[/TD]
[TD]400[/TD]
[TD]98[/TD]
[TD]750[/TD]
[TD]120[/TD]
[TD]1400[/TD]
[/TR]
[TR]
[TD]77[/TD]
[TD]412[/TD]
[TD]99[/TD]
[TD]775[/TD]
[TD]121[/TD]
[TD]1450[/TD]
[/TR]
[TR]
[TD]78[/TD]
[TD]425[/TD]
[TD]100[/TD]
[TD]800[/TD]
[TD]122[/TD]
[TD]1500[/TD]
[/TR]
[TR]
[TD]79[/TD]
[TD]437[/TD]
[TD]101[/TD]
[TD]825[/TD]
[TD]123[/TD]
[TD]1550[/TD]
[/TR]
[TR]
[TD]80[/TD]
[TD]450[/TD]
[TD]102[/TD]
[TD]850[/TD]
[TD]124[/TD]
[TD]1600[/TD]
[/TR]
[TR]
[TD]81[/TD]
[TD]462[/TD]
[TD]103[/TD]
[TD]875[/TD]
[TD]125[/TD]
[TD]1650[/TD]
[/TR]
[TR]
[TD]82[/TD]
[TD]475[/TD]
[TD]104[/TD]
[TD]900[/TD]
[TD]126[/TD]
[TD]1700[/TD]
[/TR]
[TR]
[TD]83[/TD]
[TD]487[/TD]
[TD]105[/TD]
[TD]925[/TD]
[/TR]
What's the speed rating for these?
I'm more concerned with what the insurance company would say if you changed tyre size. Currently , the cost of a 225x50x17 is almost the same price as 2 225x45x17 tyres. .
WhelanUK Wrote:What's the speed rating for these?
Not sure mate I'll try and find out I know the 2.0 CDTI is 94V
I just fitted to new rear tyres . .
I had two Michelen's on the back , one had a cut on the side wall and the other had a nail in it and was down to 2.5 mm of tread (no shame to it , over 45k on it ). .
I went for two Hankook's , 235x45x17 , also got the two on the front rebalance (l was getting vibration in the steering in certain conditions) , total cost £198. .
these pcd numbers does that mean not all astra j wheels will fit eachother, some being 105 but most being 115?
i want a 'proper' spare wheel not the daft little space saver thats in the boot atm
Depends on engine mate. You will not fit a full size spare in the well in the boot (I tried).
Best thing to do is have the space saver in boot and the full size at home ready.
if you have the 1.7 your 5 115.
i went to the opel dealer and asked for winter tyres. is it true that the rims of the 1.6 and the diesels wont fit on my car? i'm pretty sure they won't make different wheels for every engine.
also he gave me a price for steel wheels but they are 16 inch, i thought 16's didn't fit the gtc?
also went tho the local tyres and wheel dealer. gave me a price of 960€ for 17 inch alloys with tyres, that seems reasonable
18, 19, & 20" from the dealers for the GTC.
You could always get a set of 16, 17" from the 5 door the list in the post will give you the info mate.
ok, thx, i thought the 5-door's didn't fit the gtc
I can't see why they wouldn't fit do anyone close with a 5 door with the same PCB if so ask if you can try a wheel.
Not very close, but i belive you
I'm gonna look in a few other places before i decide
The stud pattern is same between the GTC and the 5 door's that use the 115PCD. I had the spare from my J that I was going to use on the VXR but I couldn't get it over the rear brake's so gave up but other than that it would have bolted straight on.
JohnL Wrote:The stud pattern is same between the GTC and the 5 door's that use the 115PCD. I had the spare from my J that I was going to use on the VXR but I couldn't get it over the rear brake's so gave up but other than that it would have bolted straight on.
so does that mean vxr wheels will fit a 1.7cdti?, for stud pattern and center bore size etc?
Gilmore Wrote:so does that mean vxr wheels will fit a 1.7cdti?, for stud pattern and center bore size etc?
Yes mate they will.
i've orderd some new wheels, i will post some pictures when they are on, probably around half november
cool i look forward to that
not sure its the right place to post but here they are
heard lots of good things about nokian winter tyres, and since they were also cheaper then contintals or other big brands i decided to give them a go.
also posted at the site's fb page
nice now all you need is the snow i am sure you get a lot of it over there :cool
Nice mate. See if you can get some vauxhall centre caps.
tucpal Wrote:nice now all you need is the snow i am sure you get a lot of it over there :cool
last year wasnt very bad, but they say this year will be rough.
i wont go pulling my handbrake in the snow like i did with my old car tough
SI SRI Wrote:Nice mate. See if you can get some vauxhall centre caps.
they're sill on the other weels and they are stocked at a garage, i'll give it a try next time
Hi Guys,
sorry if this has been asked before, I did a search and this particular question did not come up, is there much difference in handling, gear ratio etc if I change from a 245/40/20 to a 245/35/20 tyre? Reson I ask is that there is a huge difference in price with the former, to say the least!
Got a puncture this morning and realised my next purchase for the car will be a spare wheel so I don't have to faff about with a "repair kit" that doesn't even work.  My car is a 5 door hatch (2.0 CDTI) so as per the table above should have a 16 inch space saver.  Does anyone know though if a 17 inch space saver from the GTC would fit in the wheel well or will that be too big?
I've bought 20" alloys with 245 35 r20 tyres. I'm putting them on a gtc that's been lowered by 30mm. Will there be a clearance issue. I know it's an old post but need advice.
(1:st-Feb-2021, 15:37:16)seosamh1968 Wrote: I've bought 20" alloys with 245 35 r20 tyres. I'm putting them on a gtc that's been lowered by 30mm. Will there be a clearance issue. I know it's an old post but need advice.
You should be ok
  Winter tyres? bigsadie 3 7,957 15:th-May-2018, 08:47:27
Last Post: rlievens
ionutalexandru (17:th-Jan-2026, 21:12:52)
