Welcome, Guest |
Latest Threads |
VAUXHALL MANUALS FOR DEAL...
Forum: Vauxhall General
Last Post: Astra-Fan
12:th-Jan-2025, 00:34:31
» Replies: 3
Factory Reverse Camera, A...
Forum: Retrofit How-to's
11:th-Jan-2025, 19:11:34
» Replies: 31
2010 Astra J - Cooling Fa...
Last Post: Madal101_uk
19:th-Dec-2024, 22:04:08
» Replies: 3
Request heated steering w...
Last Post: emilalexandrubarb
19:th-Dec-2024, 20:16:39
VAUXHALL ASTRA 1.7 CDTI F...
21:st-Oct-2024, 18:22:15
» Replies: 3
Hello from Germany
Last Post: koxaz_nostraz
21:st-Jul-2024, 08:34:11
» Replies: 5
Opel OPC Seat Wiring Diag...
20:th-Jul-2024, 11:04:11
Old member returns
Last Post: Тania_D
20:th-Jul-2024, 11:03:28
» Replies: 3
Oil Temp and pressure sen...
Last Post: milozic
16:th-Jun-2024, 16:50:23
» Replies: 4
Have you ever thought abo...
Forum: Chris Knott Insurance
21:st-May-2024, 17:22:04
Which oil |
Posted by: Kiel0777 - 16:th-May-2020, 07:41:19 - Forum: Servicing
- Replies (3)
Hi guys is this the correct oil?
TRIPLE QX Fully Synthetic
Headline wiring |
Posted by: A.baldwinhill - 15:th-May-2020, 17:34:26 - Forum: Introduction Area
- Replies (1)
Hi all, been browsing this forum for a little while and figured I'd try make use of the wealth of knowledge on here. So my problem is as follows I don't have the cable for the sun visor lights (I've taken entire headline off and still cant find it) so I purchased a complete headline loom with the suitable wires £20 so not too bad after taking apart most of the passenger side still wondering if theres a connector where the loom clips into or if have to splice connections to fit it (although on the look I purchased it doesn't appear that there any loose ends) any help would be much appreciated
newbie needs info |
Posted by: Gary13 - 14:th-May-2020, 20:51:28 - Forum: Introduction Area
- Replies (2)
Hi al, l1st time on the site & GTC owner. Have just purchased a 2013 1.4 gtc, im not a fan of the puncture repair kits so I want to replace this with a space saver spare wheel. I have 18" alloys fitted so I would like to know what size wheel & tyre plus any other info I need to buy one
thx
passenger door deadlocked |
Posted by: celrx - 14:th-May-2020, 18:54:50 - Forum: Astra-J/GTC
- Replies (3)
hi having a few problems with my astra j 1.3 td. the passenger door is deadlocked ive tried disconnecting battery still no joy.
managed to get the door trim off i can pull the door popper up and down and the door handle from inside but still no joy so assume something electrical is stopping me opening it. any help be appreciated as ive got so far dont want to give up!
Newbie! |
Posted by: Stacker - 13:th-May-2020, 21:31:43 - Forum: Introduction Area
- Replies (5)
I'm new to the Astra scene, had a Corsa C for my first car and was a cracking little car for what it was!
Had a few random cars between then and now, Jaguars, Range Rovers, a few bangers recently -_- and now picked up a 2014 Astra J, 1.6 Design petrol model!
Haven't picked it up yet but will get a few pictures once I get it, pretty standard apart from front and rear parking sensors which I believe were optional for the year, pretty chuffed with that though!
I'm not a stranger to retrofits, I've retrofitted Bluetooth into the x type Jag I had, a heated front window into a Transit, cruise control into a Combo van and the later ACC sensor on a Mk7 Golf that hadn't been done before! ... I do have an opcom I've had for around 9 years now but not sure if it's working... think I blew it earlier this year sorting a mates VXR!
Hope I can help some people and pick up some advice on here... I will probably be looking to at the minimum add Bluetooth, as the CD400 standard model is fitted and after a bit of browsing Bournemouth is only an hour away from me Rusty!!
Cheers!
Rear Bumper PN 13346637 |
Posted by: Jonnymac07 - 12:th-May-2020, 15:44:42 - Forum: Astra-J/GTC
- Replies (1)
Hi, new to here.
Any help appreciated, I'm looking a part for my 2014 Astra Gtc limited edition, it's the rear bumper lower centre 13346637. I'm getting quoted £390 not fitted our body colour painted. Has anyone got this part cheaper and is it a common fault them coming off.
Many thanks
JONNY
PLEASE HELP |
Posted by: Kiel0777 - 12:th-May-2020, 14:31:03 - Forum: Mechanical
- Replies (9)
Dpf soot level shows 131%.. No fault codes on the car and the dpf Differential sensor is reading 102kpa... Been for a very long drive today down the m1 doing 65 in gear 4 at 3k revs but soot levels are still the same?
Blocked DPF |
Posted by: Kiel0777 - 11:th-May-2020, 09:59:28 - Forum: Vauxhall General
- Replies (8)
Saturation levels are 131% and will not regen any one know anybody who can possibly diagnose issue? Ran opcom but no codes?
Cubby box spring insertion help |
Posted by: Toffeepops - 11:th-May-2020, 00:02:40 - Forum: General Chat
- Replies (1)
Hi, hope someone can help me. The spring for the handle on the cubby box undrr the steering wheel has popped out. Strange looking thing. Can anyone advise how it goes back in. The drop down flap/door is now permanently open and I have no idea how its's supposed to go in.
