wiring headline
Headline wiring
Hi all, been browsing this forum for a little while and figured I'd try make use of the wealth of knowledge on here. So my problem is as follows I don't have the cable for the sun visor lights (I've taken entire headline off and still cant find it) so I purchased a complete headline loom with the suitable wires £20 so not too bad after taking apart most of the passenger side still wondering if theres a connector where the loom clips into or if have to splice connections to fit it (although on the look I purchased it doesn't appear that there any loose ends) any help would be much appreciated
The headliner loom should plug in on one of the a-pillars.
Be mindful the airbags also run on it so pull the battery negative & allow 10mins before unplugging anything.
  Opel OPC Seat Wiring Diagrams Blue Dog 2 4,183 20:th-Jul-2024, 11:04:11
Last Post: koxaz_nostraz
