| Welcome, Guest |
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
| Using existing dab aerial on android unit , |
Posted by: pawex - 29:th-Jun-2020, 15:22:31 - Forum: Electrical
- Replies (19)
Hi guys I got 2015 Astra GTC 2.0 ,
I have upgraded my radio to android head unit , originally I had cd400 plus with dab and usb ,
I know would like to use my existing shark fin antenna to plug in the dab in to my headunit ,when I took my old cd400 unit I didn't find any Dab connector there or anything there was is standard FM antenna ? I have searched the forums and found that there should be a seperate box for the dab and usb unit ,could any one confirm they actually exist and where about are they located ?
Wysłane z mojego SM-N976B przy użyciu Tapatalka
| Dpf regen led light |
Posted by: Kiel0777 - 28:th-Jun-2020, 07:49:45 - Forum: Electrical
- No Replies
Hello is anyone available to wire me up a dpf regen led... Willing to travel a bit I'm based in Leicester
Thanks.
| Insignia tpms |
Posted by: AlexFitton - 26:th-Jun-2020, 22:09:26 - Forum: Medium cars Astra, Cascada, Vectra, Monaro & Insignia
- Replies (6)
I have a question regarding my car.
I have a 2011 SRI nav with 18inch alloys.
It appears the wheels have the tpms sensors built in but there doesnt seem to be an option within the car to monitor the pressures.
Is this normal for my age of car? On the earlier version is it just the light on the dash which illuminates?
Alex
| I bought a used GTC! - Fantastic car but a few issues i could do with advice about |
Posted by: Mattymush - 25:th-Jun-2020, 22:32:25 - Forum: Astra-J/GTC
- Replies (5)
Hey all,
just bought a 2L GTC, and its fab, 42k miles, 7 years old, was a Cat D, but has full Mots (all passed but had a few advisories here and there) going back 6 years and well.... I got it for a pretty cheap price so despite the issues I'm a happy bunny
So the good - Drives wonderfully, and the Dab/stereo is fantastic and looks pretty lovely too (white).
But, the issues
No parking sensors - have a "service parking sensor" warning
No Cruise control
and no air con.
Now the aircon Im hoping is nothing more than a refill job, but the other things I really don't know.
What made it Cat D I'm not to sure about, but there is some fixed bodywork on the front left side. My current theory is was in a crash and in repairing it (possibly to save money) the parking sensors and cruise control were ignored/removed/damaged. After all they are not needed for a mot.
Its late in the day, so all I've been able to do is check the fuses for the parking sensor - the fuse was fine.
And we have a diagnostic reader but that showing no errors - but every chance Ive not set that up correctly (ill try again later)
Anyway, nice to be here, and if you have any thoughts or 1st plan of attack on any of these Id love to hear it!
| diesel mileage |
Posted by: badger64 - 24:th-Jun-2020, 18:26:05 - Forum: Mechanical
- Replies (21)
just seeing what mileage other diesel owners have covered. my 64 plate 2.0 cdti is on 74,000 only issue was a broken clutch spring at 50,000. due a cambelt and water pump anytime soon.
| Auto Lights and Bluetooth Retrofit |
Posted by: kalum0101 - 24:th-Jun-2020, 06:34:55 - Forum: Retrofit Research
- Replies (5)
Good Morning
Just picked up a used 2014 astra design as I am quickly outgrowing my 09 fiesta and was just wondering how easy it would be to add automatic headlights and bluetooth to the astra, as these are things I am accustom to having on the fiesta. I have the Navi 650 and when I attempt to use the bluetooth, it just says 'Not available'.
Thank You
| Changing rear brake discs |
Posted by: Big Dave2 - 23:rd-Jun-2020, 13:43:09 - Forum: Mechanical
- Replies (3)
I've already found the how2 for changing the front and rear pads, but no mention (that I can find) of also changing the rear discs on a 2.0 CDti with 292mm discs.
Anyone know the socket sizes I need, and what the torque settings are?
I have a rewind tool, and it was previously mentioned to me that both pistons need rotating back in clockwise. Is that correct?
Also, I have a traditional handbrake that is operated via a lever. Anything I need to know about before attempting to change the discs and pads? i.e. does it need adjusting afterwards?
I did see mention somewhere to just keep lifting up and releasing the handbrake lever until the brakes adjust themselves. Is this correct?
Thanks.
