problem light power rear
Rear light power problem
Anyone got any ideas.  My 2L cdti has developed an issue that has the fog, reversing and rear right indicator lose power.  The Cambus keeps giving a bulb warning but the bulbs have all been checked and they are all good.  I've also checked the power tracks in the clusters from the cable socket pins to the bulb socket and they are OK too.
This spreads across 3 of the 4 rear clusters and all the other lights not mentioned are OK.  Same time as this I believe, the dash power socket has also failed.  I've gone round all the fuses and they too are a ll good.
I'm guessing this means it's a wiring issue,  potentially a plug somewhere that's maybe come loose?   I don't really have a clue other to start checking connectors etc I can find.
Any ideas on a common denominator?
Tia,
Phlyer Phil
Head In The Clouds
Mind In The Gutter
Are the bulbs LED?
  Meriva B GID problem edomali 0 3,157 28:th-Apr-2021, 11:47:03
Last Post: edomali
  CD400 power problem bigles 6 4,083 22:nd-Dec-2020, 05:56:33
Last Post: bigles
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 9,480 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 3,224 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  IPC upgrade problem coabacje 0 3,408 11:th-Jan-2020, 18:58:54
Last Post: coabacje
  Corner light make sistem93 2 4,562 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Rear Fuse Box leeso 3 3,886 15:th-Nov-2019, 08:19:15
Last Post: tcmtuning
  Eco button light flashing jw021979 6 7,753 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  Wiring up my dashcam. Take power from...? rlievens 14 12,369 29:th-Jun-2019, 20:42:29
  Rear light out but works again with headlights Willcbrbikeboy 6 5,126 14:th-Jan-2019, 09:43:44
Last Post: vocky
Rusty2009 (21:st-Dec-2023, 08:27:49)
