sound j weird motor turbo astra 4 1
weird motor sound Astra J 1.4 turbo
Hi all
I am quite new at this forum, so this is my first poost and I hope not break any rules.
In the last days I noticed my Astra is making some weird noise. It seems there is some broken piece inside and quite often creates this `crack` sound.
The car is an ASTRA J 1.4 turbo 140cv with 67.000km
I want able to attach the video, but I share a google drive link where you can watch and hear the noise.
https://drive.google.com/file/d/1bpS0rZ ... sp=sharing
Hope you guys can help me.
Tks!
Hi guys. I share another link with a video in which the air conditioning is On and there is no noise, then i turn it off and the noise starts.
https://drive.google.com/file/d/1dVJt6DV...p=drivesdk
Thanks!!!
It's only a guess but as it seems linked to a/c maybe compressor clutch bearing, when freewheeling makes noise when clutch engaged and everything is solid all good.
  1.4 non turbo P0171 code Mohammed_Malik 1 407 15:th-Feb-2024, 07:47:47
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 12,384 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  Astra A17DTF - Timing Belt or Chain? everson38 1 1,580 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 2,148 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Exhaust sound Kiel0777 2 2,255 31:st-Jan-2021, 20:50:01
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 3,252 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 3,187 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 5,216 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 5,319 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 21,742 5:th-May-2020, 14:22:14
Last Post: Kiel0777
