failed j gtc tailgate astra lock
Astra J GTC tailgate lock failed
Hi All
The tailgate latch on my Astra J 1.7 CDTI estate has packed up and doesn't respond to me unlocking the car either with the remote key or using the switch on the facia panel.
Thanks to a post on this forum, I was able to unlock the tailgate from inside the car which got me out of trouble.
I checked the fuse (assuming I checked the correct one) and it seems fine.  In any case I can see 12v on a couple of the pins in the connector that plugs into the lock mechanism.
I took a punt and bought a secondhand lock mechanism on eBay (looks good condition), but after connecting it up, the lock is still not operating :-/
I'm now wondering whether the body control module might have gone faulty, but I'm not sure how I can check this out.  All other aspects of the central locking work OK, so I was guessing it wasn't at fault, but perhaps it is.
If anyone knows what voltages I should be seeing across the three pins of the connector plug with the lock activated and deactivated, it might be a good next step to check these.
Thanks in advance for your help.
Graham
Hopefully the attached .PDF will help you.
You may find if get it connected it may have a error code stored which will help point in the right direction for a starting point rather guessing at things.
  Trunk Release Malfunction.pdf (Size: 116.96 KB / Downloads: 7)
  installing Android radio in Astra J Sports Tourer Amir Khezri 23 41,961 23:rd-Jun-2023, 10:28:40
Last Post: airainchoc
  opel astra j keyless entry and remote start stop onurody 3 10,616 11:th-Sep-2021, 15:57:59
Last Post: SbVampire
  Bluetooth music streaming - does it work in your Astra...? UseThe4s 4 12,054 5:th-Apr-2021, 18:43:22
Last Post: UseThe4s
  2014 Astra 1.6 Elite - No DAB / Bluetooth - Can I add? wsw 1 8,783 26:th-Feb-2019, 08:13:36
  Astra J Electric Plug jamietomlin 3 6,041 25:th-Dec-2018, 10:04:29
Astra gtc windscreen wipers Anitamay77 1 5,376 14:th-Jun-2018, 21:03:04
  ASTRA J 1.4 PETROL ( NON TURBO ) karaokeking 1 8,141 3:rd-Jul-2017, 07:43:27
  Navi 950 in 2012 Astra J GTC Hummelshøj 6 16,895 29:th-Jun-2016, 12:16:18
Last Post: Hummelshøj
slartibartfast23 (10:th-Jul-2025, 12:30:36), halmu (16:th-Feb-2026, 09:54:20)
