Rear tailgate bulb
Hi all can someone point me in the right direction to what bulb I need for my 2012 gtc the bulb which comes on with the lights I've took the holder out but can't find what bulb it is
Tailgate Stuck Shut and wont unlock HELP
Hey all,
Wonder if any of you can help us,
We had a little trouble with the tailgate not closing so i cleaned up the mechanism and sprayed it etc and it worked perfect for a few months, now its stuck shut.
The central locking is working fine except you cant hear the click in the tailgate, I checked the fuse and its fine.
I have all the plastics and trim off and for the life of me I cannot find the switch to open it manually.
Can any of you kind souls help.
TIA
Tailgate LED
Strange thing on my bum. My GTC has factory fit LED rear lights but the O/S tailgate light is always on. So during the day none of the rear lights are illuminated except for the tailgate one. I know I have a reverse light bulb to change on the same side as this is inop but has anyone seen anything like this?
Tailgate issue
i have a 5 door hatch and i find the tailgate is digging into the rear bumper, is the boot hatch fitted wrong or has the car been in an accident and bumper is fitted too high
thanks
tailgate not opening!
Everything has been working well for a while, so I suppose something was bound to go wrong
We put shopping bags in boot, went off to the shops, got bags out of boot, got shopping, put full bags back in boot and drove home.
When I went to open boot, nothing - the little switch you press had no effect - typical! so we folded rear seats down and got shopping out that way.
Anyway, I knew there was a little grommet in the tailgate trim so went and got a suitably sized screwdriver (always the right
Astra J GTC tailgate lock failed
Hi All
The tailgate latch on my Astra J 1.7 CDTI estate has packed up and doesn't respond to me unlocking the car either with the remote key or using the switch on the facia panel.
Thanks to a post on this forum, I was able to unlock the tailgate from inside the car which got me out of trouble.
I checked the fuse (assuming I checked the correct one) and it seems fine.  In any case I can see 12v on a couple of the pins in the connector that plugs into the lock mechanism.
I took a punt
