in 2012 j gtc astra 950 navi
Navi 950 in 2012 Astra J GTC
Hi all..
Is it possible to install and get navi 950 to work in a 2012 Astra that "should" be using navi 900.
I know about the VCI codes that is needed to get is paired to the car.
My car is from factory installed with a CD400, butare currently using ESX VN709 but would like either navi900 with bluetooth or the navi950 if possible.
https://www.amazon.de/ESX-VN709-OP-ASTRA...B01DT9H7UO
Thank you..
No GM will not allow a 950 only a 600 or 900 it's based on model year.
(28:th-Jun-2016, 22:17:13)Rusty2009 Wrote: No GM will not allow a 950 only a 600 or 900 it's based on model year.
Then it will be navi900.
But there is nothing for sale at the moment..
I'm still hunting a NAVI900 myself I've fitted a 600 and just done 900 upgrade.
Just be aware GM will charge 95 euro VCI fee that's on top of what someone will charge you to fit and program it up. There are only 2 people that know all the wiring changes needed tho.
(29:th-Jun-2016, 07:33:28)Rusty2009 Wrote: I'm still hunting a NAVI900 myself I've fitted a 600 and just done 900 upgrade.
The fees  and programming I am aware of and is okay with..
But missing wires? Thought it was pretty much plug and play apart from the GPS aerial.
No not for factory fitted Navi.
(29:th-Jun-2016, 09:19:54)Rusty2009 Wrote: No not for factory fitted Navi.
How much needs doing to get it to work...?
  Navi 900 to Android head unit airainchoc 1 4,285 2:nd-Jul-2023, 09:03:15
  installing Android radio in Astra J Sports Tourer Amir Khezri 23 41,498 23:rd-Jun-2023, 10:28:40
Last Post: airainchoc
  opel astra j keyless entry and remote start stop onurody 3 10,424 11:th-Sep-2021, 15:57:59
Last Post: SbVampire
  Bluetooth music streaming - does it work in your Astra...? UseThe4s 4 11,908 5:th-Apr-2021, 18:43:22
Last Post: UseThe4s
  Astra J GTC tailgate lock failed grahamf505 1 6,656 22:nd-Feb-2021, 08:22:09
  ECU 1.7 CDTI 2012 96kw alexandrufalfan 2 5,791 3:rd-Mar-2020, 10:21:20
Last Post: alexandrufalfan
  2014 Astra 1.6 Elite - No DAB / Bluetooth - Can I add? wsw 1 8,677 26:th-Feb-2019, 08:13:36
  Astra J Electric Plug jamietomlin 3 5,953 25:th-Dec-2018, 10:04:29
  navi 600 memory card usb aux wiring tzr608 1 12,260 15:th-Aug-2018, 20:22:32
Astra gtc windscreen wipers Anitamay77 1 5,323 14:th-Jun-2018, 21:03:04
