Trade Count:
0)
Threads: 7
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Total Feedback: 0
Hello friends.
My car is not deadlocking. Already changed the drivers door lock and the relay kr97, in the rear fusebox.
Any ideas ? Thank you
Enviado do meu SM-G950F através do Tapatalk
Trade Count:
0)
Threads: 7
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Total Feedback: 0
19:th-Dec-2020, 13:00:10
(This post was last modified: 19:th-Dec-2020, 13:32:24 by Jonika21.)
i forgot to say that it is a 3 door gtc
found the problem. it can be closed. thank you
Trade Count:
4)
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Was going to say on one I had it there was corroded pin on the rear fuse board causing the issue.
What was the issue you found?
Trade Count:
0)
Threads: 7
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Total Feedback: 0
Hello rusty. The rear fuseboard was not the problem. I have changed it recently.
The problem is that my car hasn't the deadlock door locks. I could sware i have done it already but i have checked the epc with my vin and my door locks don't support it. I will change them for deadlock capable ones.
I assume any programing is required once in gds2 it is possible to simulate deadlock right? Thank you
Trade Count:
4)
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
GDS2 can do the testing testing yes.
But any programming would need SPS. I would have to look into the calibration files to see if there is a difference & also the wiring.
Trade Count:
0)
Threads: 7
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Total Feedback: 0
Ok rusty, thank you. Appreciated. I will do some research too..
Enviado do meu SM-T580 através do Tapatalk
