mirrors heated working not
Heated mirrors not working
2010 Opel Astra J A16XER.
Heated rear window works fine, the mirrors don't at all.
I checked fuse F6 in the engine bay and it is okay.
I checked the heater resistance and both sides are about 10.5 Ohm.
I measured voltage between the positive terminal on the battery and both the fuse and the both terminals on the mirror and every time I measured battery voltage. Testing to the negative battery terminal yields 0 V, which suggest that there is ground potential on the leads and something isn't switching to close the circuit.
I couldn't find any schematics or diagrams and I don't know what to check next.
There rear only is the the fuse and mirrors.
I'll dig the schematics out later
Well, it's kinda embarrassing.
Fuse was in position A and I measured that the relay output goes to the most (car's) left terminal - position B.
I honestly don't know how it got switched, but it's working now.
  Changed stereo, infotainment stopped working NELLY1996 0 1,372 10:th-Jun-2021, 15:43:10
Last Post: NELLY1996
  Speedo stopped working AlanMac 0 3,566 13:th-Jun-2019, 17:19:55
Last Post: AlanMac
  Heated Seats Pin Out's & Schematics Rusty2009 3 20,216 29:th-Mar-2019, 17:42:46
Last Post: zaapp
  Heated Seats Description and Operation Rusty2009 33 51,750 13:th-May-2018, 16:09:59
  blowers intermittently working micko 1 2,928 13:th-May-2017, 07:26:56
  Change Steering Cruise Control Not Working cosmo black 7 6,818 20:th-Apr-2016, 07:51:24
  Heated seat fault - help! ajh1984 6 6,439 2:nd-Feb-2016, 22:01:26
Last Post: ajh1984
cpeter53 (10:th-Oct-2023, 05:49:58)
