some after cleaning? won astra sensor t start
Astra won't start after some sensor cleaning?
Hey vxoc !
My car wont start anymore after i cleaned the EGR and suction control valve (scv) and the MAP sensor. the last thing that happened was whistle turbo sound from the engine and it went to ''reduced power mode'' when i sae that i parked the car it i dint turn on since.. but before all that i was haveing with power and stalling issues for the last month and after some internet research i begend to clean the sensors.
here are the error codes i got from opcom hopefully someone can help
p0238
p0098
p0402
p0404
p2003
p242F
p0409
p2262
The first thing I would do is check all wiring make sure everything is plugged in correctly.
p0238 = https://workshop-manuals.com/vauxhall/as...p0238_llu/
p0098 = https://workshop-manuals.com/vauxhall/as...p0098_luj/
p0402 = https://workshop-manuals.com/vauxhall/as...nded%20OFF.
p0404 = https://workshop-manuals.com/vauxhall/as...dtc_p0404/
p2003 = https://workshop-manuals.com/vauxhall/as...pl_or_lpv/
p242F = https://workshop-manuals.com/vauxhall/as...pl_or_lpv/
p0409 = https://workshop-manuals.com/vauxhall/as...pl_or_lpv/
p2262 = https://workshop-manuals.com/vauxhall/as...pl_or_lpv/
Thank you Rusty everything works now.. I cleaned every connector and the EGR
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 12,370 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 2,055 18:th-Jul-2021, 08:17:49
  Astra A17DTF - Timing Belt or Chain? everson38 1 1,569 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 2,140 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 3,178 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 5,198 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 5,308 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 21,715 5:th-May-2020, 14:22:14
Last Post: Kiel0777
  2013 Astra J SRI Galway11 2 4,008 29:th-Jun-2019, 20:20:47
  ASTRA J GENUINE LOWER SPRINGS blacknik 3 3,756 20:th-Mar-2019, 18:08:56
