gtc coolant leak 2017 4t 1 120
Gtc 2017 1.4t 120 coolant leak
Hi everyone,
Car overheated on Saturday, checked coolant level and nothing remaining in reservoir. Topped it up and made it home. Not easy to see where the leak is coming from, I think it may be the water pump, which I believe is a known issue on these cars.
Taking it to a garage tomorrow. If is a water pump, what work would usually be completed additional to the pump replacement. Timing belt? Tensioners?
Whats a reasonable price for water replacement?
Not sure if the pump is driven off the cambelt, but if the water pump is driven off the cam belt then yes do cam belt tensioners might as well do the aux belt to as it has to come off in the process.
  Oil Leak at Intercooler pipe / Throttle body everson38 0 1,623 9:th-Jun-2021, 23:26:09
Last Post: everson38
  coolant pressure tester chuzzle359 0 1,131 14:th-Apr-2021, 18:23:08
Last Post: chuzzle359
  Coolant light coming on when coolant is full (new sensor and no leaks) baffling me! Brasseyebaby 3 3,005 2:nd-Feb-2021, 21:12:47
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 2,681 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 2,823 25:th-Apr-2020, 07:41:05
  coolant tank hose ref needed alexy357 1 2,417 4:th-Mar-2019, 08:43:32
  Coolant is milkshake Ultraviolet 5 3,393 18:th-Dec-2018, 17:45:31
  Slow coolant loss Dennis S 21 21,929 8:th-Jan-2018, 11:13:20
Last Post: Dennis S
  Retrofit Coolant and Wiper Fluid Sensors sheppy1 11 8,100 27:th-Mar-2015, 10:12:34
  Wiper fluid and coolant bottle sensors sheppy1 6 5,347 22:nd-Mar-2015, 20:57:15
Denio (2:nd-Nov-2023, 21:57:38)
