Oil leak from pipe
Hi guys,
I noticed oil kind of near the bottom of the engine, lower down than the battery. I think it may be coming from a black pipe that looks like it has a large circlip and metal clip around it. I've attached a photo here and I think it could have been dripping down over time. The car is booked into my local garage tomorrow (Tuesday 17th March) but I wondered if anyone knows what this black pipe is for and should oil be coming out of it?
As always, thanks in advance.
[url=http://s1206
URGENT HELP PLEASE - What is the pipe / oil leak
Hey guys
I have a astra J 62 1.7 diesel.
I noticed today a suction / hiss noise. Looked in my engine and saw duct tape wrapped around a pipe and could feel air escaping, this was obvs put there to try patch it and then there was oil residue over it / over my radiator fan / surrounding arwas as if it's be spraying it out.
(Will attach video links)
Video 1:The duct tape over pipe
https://youtu.be/_0Ciw7VBhrs
1) Could someone please tell me what this pipe is / does?
2) Is the oil residue and
niteram - Replies:
oil leak 1.6 petrol
Hi, I've got a couple of Astra J's, both 1.6 petrol
one has started a to leak a little oil - it doesn't seem to drip on the floor but the sump is wet - the drips fall onto the exhaust while driving (I love the smell of burning oil in the morning)
I've taken off the manifold heat shield and the front of block is also damp, so its not the sump gasket or the head gasket.
Is it likely to be the oil pressure switch?
Is this a known fault?
Water leak in boot, spare wheel
My Astra has a leak in the boot, where the spare wheel is. The boot itself is dry. But there is damp on the back seat and the passenger footwellis wet.
I have just taken it to my local Vauxhall Dealer, they did tests all day, could not find out where the leak was. They said they would need to take out the carpet, seats and take off the bumper to find out more. Would be 6 hours labour. Im picking the car up tomorrow. It would cost over £400 before any parts.
Any ideas? Thanks
Gtc 2017 1.4t 120 coolant leak
Hi everyone,
Car overheated on Saturday, checked coolant level and nothing remaining in reservoir. Topped it up and made it home. Not easy to see where the leak is coming from, I think it may be the water pump, which I believe is a known issue on these cars.
Taking it to a garage tomorrow. If is a water pump, what work would usually be completed additional to the pump replacement. Timing belt? Tensioners?
Whats a reasonable price for water replacement?
Oil Leak at Intercooler pipe / Throttle body
Hey guys
I have a 1.7 62 plate GTC. I have noticed there is a semi decent oil leak coming from the underside of the pipe , where my intercooler pipe meets my throttle body. The issue is, that the clamp seems to be in fully seated and there is no o ring so why is it leaking? I doubt it's a split hose as it was replaced a a couple years back for a new one at the garage where I bought the car?
Any ideas?
Thanks in advance [IMG]https://uploads.tapatalk-cdn.com/20210609/7eacd31e427b601533617216
