gtc 2017 disc brake 4t 1 120 front size
Gtc 2017 1.4t 120 front brake disc size
Could someone let know what size brake discs are on the GTC  1.4t  120 2017.
If you want to pm me your reg I'll look them up for you.
Astra J GTC, DISCS AND PADS, PCD 5x115 ALL ENGINE SIZES
FRONT DISC, 321MM 13502826
FRONT PADS, 13137751
REAR DISCS, 292MM 13502138
REAR PADS, 13300867
ASTRA J 5 DOOR, DISCS AND PADS, PCD 5x105 engine size 1.4 VVT 1.6 VVT 1.3 CDTI
FRONT DISC, 276MM 13502044
FRONT PADS, 13301207
REAR DISC, 268MM 13502134
PADS SET, REAR 13300867
ASTRA J 5 DOOR DISCS AND PADS 5x115 1.6 TURBO 1.7 CDTI 2.0 CDTI
FRONT DISCS, 300mm 13502051
FRONT PADS, 13301234
REAR DISCS, 292mm 13502137
REAR PADS, 13319294
Astra J VXR, DISCS AND PADS, PCD 5+115
FRONT DISCS 355mm 13370436
FRONT PADS 13411116
REAR DISCS 314mm 13371163 or 13429575
REAR PADS 13417473
  Retrofit front parking sensors (GTC) pedroc1999 3 2,365 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Lowering springs identify front rear martinpe68 1 1,681 12:th-Sep-2021, 15:22:37
  Brake pedal sensor learn. Richiew1986 0 1,299 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Front PDC wiring diagram milozic 1 2,475 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 8,122 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 3,365 3:rd-Oct-2020, 11:48:59
  Gtc 2017 1.4t 120 coolant leak Nathan191210 1 2,068 1:st-Oct-2020, 07:02:07
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 2,640 12:th-Jul-2020, 07:37:10
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 3,726 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 7,420 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
Rusty2009 (26:th-Dec-2023, 13:16:38)
