indicator amp electronic light system stability flashing malfunction quot control
"Electronic Stability Control System" & flashing "Malfunction indicator light"
When driving last night i got the "electronic stability control & traction system" symbol when is staying constant.
Today it appeared again AND a flashing "malfunction indicator light" also appeared. The cars power was restricted.
Its a 2012 1.4 petrol. The car is misfiring a small bit.
Can anyone advise the problem?
It could be anything it's best getting it plugged in and fault codes read then go from there.
(27:th-Mar-2019, 08:29:12)Rusty2009 Wrote: It could be anything it's best getting it plugged in and fault codes read then go from there.
Gone in today. I have been advised it is possibly the coil pack therefore i would require:
-new coil pack and related plug(spark)
Anyone take a stab at roughly what they would think it will cost me for parts & labour?
Additionally could this have been prevented in any way OR is it just a "wear and tear" part?
I'm confused how you've been advised possibly coil pack for stability & traction control.
Coil packs are a very common thing to fail tho tbh.
(29:th-Mar-2019, 07:54:56)Rusty2009 Wrote: I'm confused how you've been advised possibly coil pack for stability & traction control.
New coil pack & four new spark plugs & labour  =€350
I would have said abs sensor or the pulse ring not coil pack. If it were me I would have tried that first but as rusty said plug in on proper diagnosis tool for fault codes.
  Power steering warning light defrank 2 6,199 20:th-Feb-2020, 19:37:57
  Malfunction Indicator Light on after adding oil Dman86 11 18,210 16:th-Jan-2015, 22:42:53
Last Post: bannan
  Brake Assist Warning Light duncboyd 8 22,737 19:th-Aug-2014, 07:52:40
  Epb orange light richje100 41 41,774 2:nd-May-2014, 06:46:52
