springs j genuine lower astra
ASTRA J GENUINE LOWER SPRINGS
Hello.i have opel astra j 5 doors hatchback with sport chassis and electronik suspension.my car isn t lower and i want to put the springs from lower edition.can somebody help me
Just get a set of Eibach springs
Eibach is too loer for astra.i said that the springs fron lower shassis must be ok.can somebody help me?
If you have the sports setup already you are already 10mm lower than standard astra.
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 12,345 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 2,041 18:th-Jul-2021, 08:17:49
  Astra A17DTF - Timing Belt or Chain? everson38 1 1,561 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 2,135 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 3,232 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 3,154 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 5,171 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 5,281 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 21,675 5:th-May-2020, 14:22:14
Last Post: Kiel0777
  2013 Astra J SRI Galway11 2 3,986 29:th-Jun-2019, 20:20:47
