Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
4:th-May-2014, 14:09:55
(This post was last modified: 1:st-Apr-2017, 09:24:30 by Rusty2009 .)
For any member wanting to change the LED colour in the window switch
Tools required
T20 torx driver
Small flat head
As required
10 x 0805 Blue LED (SMD) - Ultra Bright - UK - 1st Class Post | eBay]805 smd LED One led in both rear and passengers switches. Drivers 2 leds(front elec only) or 5 leds(front & rear elec windows)
Fine tipped soldering iron
3 door owners need to follow all steps but 5 door owners can miss out steps 1-4
Remove the black insert carefully, the ends move inwards as there' a right clip on each end
Showing the various clips on the black insert
Undo the one T20 screw holding the window switch in
Carefully raise the front edge of the switch through this hole
Once front edge is raised slide forward
Then raise the rear edge slide the switch backwards to release from behind the handle
Disconnect the Elec connector by pushing the little tab
To separate the switch from the housing unclip qty 4 clips
The 2 parts separated( at this point you could follow Cameron how-to and wrap the cover)
To gain access to the LED PCB unclip qty 6 clips
Picture of LED to be changed(passengers side)
LED's for front drivers switch for all 4 elec windows
LED changed I've marked the power connections for testing purposes prior to rebuild
Testing after LED change(Drivers side front elec windows only)
Switch rebuilt( in reverse order)
Refitted back into car
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Thanks mate I take it it's one LED per switch?
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Rusty2009 Wrote: Thanks mate I take it it's one LED per switch?
Yes mate, the how to was done for my GTC which is only elec front windows
Trade Count:
2 )
Threads: 220
Thanks Received:
0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
isn't it one for the left and two for the right switch ?
very well done again i like this alot
going to make this a little project for the summer
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Yes mate one led per window toggle switch
Trade Count:
2 )
Threads: 220
Thanks Received:
0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
Do the led,s de solderer from the front of the circuit board BAZ
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Yes mate all leds on the J are surface mounted
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Just to avoid any confusion here's the number of LED's for different elec window combinations:-
front elec windows only 2 LED's for the drivers side and 1 LED for the passengers side.
Front and rear elec windows you'll need 1 LED for passengers door and 1 for each rear door and I'm guessing you'll need 5 LED's for the drivers door.
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Baz I'll confirm the number on drivers door once I get the LEDs don't how quick the guy is at sending them out.
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Rusty2009 Wrote: Baz I'll confirm the number on drivers door once I get the LEDs don't how quick the guy is at sending them out.
I usually get the LED's within 3-4 days
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
4:th-May-2014, 20:27:32
(This post was last modified: 2:nd-Apr-2015, 14:58:52 by Rusty2009 .)
Cool not to bad then,
when you say fine tip how fine?
These are what I have.
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Looking at your pic I'd say the best would be 4th from left as you don't want a large heat area or too a small heat area
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
10:th-May-2014, 18:54:09
(This post was last modified: 2:nd-Apr-2015, 15:00:22 by Rusty2009 .)
Baz on the 5 door you don't have to remove the trim and undo screws to remove the window switches they just pull up and out the rear are a little bit more of a pain but if you want to update your first and link to this
how to I did .
Also there are 6 led on the full elec window switches. 5 for lighting the buttons and one for when the rear windows are locked/unlocked this is amber.
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Thanks to all the info provided by Baz I've done window switches.
The front switches are meant to be orange but they look more of light red so I'm going to change them.
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Can you link me up for the right Smds, the sharpie started to rub off lmao
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
There listed in post 1
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
cornishtaz Wrote: There listed in post 1
Stupid me lol, I got an a* gcse electronics and I'm gonna ask a real stupid question
Does the polarity matter of Smds?? Positive and negative??
If it does, how do you test them before putting them back in the car
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Yes they are polarity sensitive. From the top of my head they have a green mark donating -ve
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
cornishtaz Wrote: Yes they are polarity sensitive. From the top of my head they have a green mark donating -ve
Yes Baz that's right, Cam I just used a 9V battery and hooked up to the pins to make sure they worked (Don't put it on the SMD as you will blow it.)
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Rusty2009 Wrote: Yes Baz that's right, Cam I just used a 9V battery and hooked up to the pins to make sure they worked (Don't put it on the SMD as you will blow it.)
Ok so attach my multi meter or 9v battery to the pins not the SMD, thanks, all ordered
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Got these in today, your pictures were a great help, can't wait to see them in the dark
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
I'm gonna do my light switches to the right of the steering wheel, which is positive and negative??? Pictures would be good to show, thanks
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Cam on light switch I found they change round.
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Rusty2009 Wrote: Cam on light switch I found they change round.
When you get a min can you post a diagram of where the green line goes, that would be great!!!!!
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Cameron UK Wrote: When you get a min can you post a diagram of where the green line goes, that would be great!!!!!
Of the top of my head without opening up my switch it should be like this let me know if there is any wrong
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Rusty2009 Wrote: Of the top of my head without opening up my switch it should be like this let me know if there is any wrong
Thanks for that, I might just wait until someone can confirm 100% lol, I understand it might take some time
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Cam just do them one by one if you have a 9v bat you test they work before you solder them on (you might have to push down)
Pin 6 = neg
Pin 7 = pos
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
Rusty2009 Wrote: Cam just do them one by one if you have a 9v bat you test they work before you solder them on (you might have to push down)
Pin 6 = neg
Pin 7 = pos
Good idea, waiting for a new batch which should arrive Thursday then I'll do a how to
Trade Count:
0 )
Threads: 212
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
24:th-Jun-2014, 19:25:31
(This post was last modified: 2:nd-Apr-2015, 15:01:53 by Rusty2009 .)
Here is a comparison against a 5p, i would only reccomend doing these conversions if you have GOOD experience of soldering as its a bit tricky, if you dont want to risk it look here:
http://www.vxoc.org.uk/forum/Forum-Cornishtaz-Baz
(good pictures for a phone (samsung galaxy s4))
Trade Count:
1 )
Threads: 52
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Car: 2.0 CDTI SRi Astra J
Sex: Male
Total Feedback: 0
Are these the same leds that are used in the wing mirror switch? Do we have a complete list for all LEDs needed for a full conversion too?
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
PLCC-2 for the mirror switch IIRC off the top of my head mate
Trade Count:
1 )
Threads: 52
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Sex: Male
Total Feedback: 0
Ok thanks Rusty,
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
I can sort a complete list later with type and number required for each type of panel
Trade Count:
0 )
Threads: 0
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: 59 1.7 cdti astra
Sex: Male
Total Feedback: 0
hi im a
can anyone post the info and possibly a diagram off the headlight switch unit and what led/smds are needed. i have all smds to do the rest off the conversion just not this section as i cant find any info thanks
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Head light switch uses 0805 LED's and they all very depending on switch as to which way the led's are.
Trade Count:
0 )
Threads: 0
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra gtc
Sex: Male
Total Feedback: 0
hello i am looking for a bit of help i have followed the how to that was so helpfull but i am having issues with the mirror switch i removed the led but i cant get the new ones to work is there a way to find out what way the led goes its the plecc 2 with the corner cut away
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Off the top of my head the left side neg goes up and the right side down. (this is with the pins being at the bottom)
Trade Count:
0 )
Threads: 0
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra gtc
Sex: Male
Total Feedback: 0
thanks rusty i will give it another go do you happen to know if there is a list of what smd i will need for the astra gtc things like the light switch etc i cant seem to find anyone that sells the side load plcc 2 sideled
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
0805's and PLCC-2 LEDs there are more 0805's than plcc-2. for side leds turn normal plcc-2 on their side.
Trade Count:
0 )
Threads: 0
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra gtc
Sex: Male
Total Feedback: 0
thanks again rusty appreciated
Trade Count:
4 )
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
@Jinkie I found this on my camera roll last night so thought I'd upload it for you.
Trade Count:
0 )
Threads: 0
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: Astra gtc
Sex: Male
Total Feedback: 0
Thanks thats it sorted i had the smd in the same way cheers
