light working driving not rear
Rear driving light not working
The rear light drives side has stopped working. At first, I thought it was a bulb problem. Bulb ok. So the next thought that it must be the bulb holders. But check that on another car and on the opposite side. I've ruled that out as well. So it can only be the wiring or the plug itself. Can this be bought separately? Or is it a case of tapping into the wiring loom with a 2nd hand plug.
Regards
Kiippax
Sent from my Pixel 2 XL using Tapatalk
Have a look in the connector at the pins are they ok or are they dirty?
Have you tried a little squirt of WD40 and a clean with a scrap tool on the connector terminals?
Which light are you talking about the outer light or the boot light & which bulb isn't working?
Some connectors you can buy new (if you can locate them) or buy a sometimes over priced repair kit from Vauxhall.
  Inner rear light Kiel0777 9 13,665 25:th-Apr-2020, 20:19:21
Last Post: Kiel0777
  DRL and rear lights Jimobob 1 8,393 25:th-Jun-2019, 15:23:09
  Rear light problem Dan1992 7 17,964 12:th-Jan-2019, 22:34:33
Last Post: Willcbrbikeboy
  drl light flicker. THOMAS123 2 6,531 11:th-Nov-2017, 15:17:43
Last Post: zzattack
  AFL basic problem (bulb not working) AlanMac 2 10,264 28:th-Aug-2017, 09:17:58
Last Post: AlanMac
  REGISTRATION PLATE LIGHT Pinhead385 1 5,935 30:th-Apr-2017, 07:14:22
  Astra j elite 1.7 beam light not work with fog light on caretaker 5 13,341 16:th-Apr-2017, 14:39:01
Last Post: caretaker
  Cluster Light guitz 5 10,546 9:th-Nov-2016, 15:37:18
Last Post: guitz
  Astra j fog light Schema insurance Kado1111 0 6,401 8:th-Nov-2016, 23:25:39
Last Post: Kado1111
  Gearstick light gregj 3 8,117 14:th-Jun-2016, 16:34:21
Last Post: gregj
