light inner rear
Inner rear light
Hi inside the rear back light cluster it looks really loose is this normal?
(20:th-Apr-2020, 10:13:55)Kiel0777 Wrote: Hi inside the rear back light cluster it looks really loose is this normal?
Any help?
I would say it doesn't look right
is it the drivers side or passenger?
hard to tell from picture, but it looks like the reflector has come loose
It's the same both sides??
Reflector has come lose you maybe able to pull them back but easy, IIRC you've only just got the car so if from a dealer or trader with warranty take it back & get them to replace them.
Out of warranty unfortunately... How are they put back do you know?
I've looked and there's a screw that should hold. It... It's snapped inside.. Is there a way of getting inside the light to possibly glue it??
Not with out opening it up and they aren't easy to open tried to open one of mine and didn't go too well.
Ahh OK it's not a mot fault so be fine for now.
  DRL and rear lights Jimobob 1 8,404 25:th-Jun-2019, 15:23:09
  Rear light problem Dan1992 7 18,000 12:th-Jan-2019, 22:34:33
Last Post: Willcbrbikeboy
  Rear driving light not working kippax 1 9,327 18:th-Nov-2018, 09:34:39
  drl light flicker. THOMAS123 2 6,550 11:th-Nov-2017, 15:17:43
Last Post: zzattack
  REGISTRATION PLATE LIGHT Pinhead385 1 5,962 30:th-Apr-2017, 07:14:22
  Astra j elite 1.7 beam light not work with fog light on caretaker 5 13,409 16:th-Apr-2017, 14:39:01
Last Post: caretaker
  Cluster Light guitz 5 10,592 9:th-Nov-2016, 15:37:18
Last Post: guitz
  Astra j fog light Schema insurance Kado1111 0 6,409 8:th-Nov-2016, 23:25:39
Last Post: Kado1111
  Gearstick light gregj 3 8,130 14:th-Jun-2016, 16:34:21
Last Post: gregj
