unlock stuck help shut tailgate wont and
Tailgate Stuck Shut and wont unlock HELP
Hey all,
Wonder if any of you can help us,
We had a little trouble with the tailgate not closing so i cleaned up the mechanism and sprayed it etc and it worked perfect for a few months, now its stuck shut.
The central locking is working fine except you cant hear the click in the tailgate, I checked the fuse and its fine.
I have all the plastics and trim off and for the life of me I cannot find the switch to open it manually.
Can any of you kind souls help.
TIA
There is an override in the boot which you can use an Alan-key to open it from the inside.
On the trim there is a rubber grommet over the hole.
It maybe the switch that has gone faulty.
(9:th-May-2018, 13:10:43)luvie Wrote: Hey all,
TIA
Had this in my Corsa when I had one previously. Try disconnecting the battery for 10 mins and see if that resets it. When I took it to Vx that was what they did and it got it working again. They then ordered a new switch and supposedly replaced it under warranty, but I'd never have known if they really did or if this just fixed it.
Thanks so much I will give it a try , thanks to you both
I have tried tried disconnecting the battery and it still wont open, I have uploaded a picture of the boot lock, for the life of me I cannot find the emergency release allen blot. (HELP)
Also where is the switch that would need replaced... Thanks so much in Advance
Just above the mechanism it’s not an Allen bolt you need an Allen key a big one or something big enough to fit.
Here’s some pics of mine to help everybody.
  Diesel door wont opel Arkanggel10 2 3,982 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  New Fuel filter. Wont start SALMHAGE 1 4,297 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  Tailgate issue Qaranc 0 3,959 1:st-Jun-2019, 09:24:16
Last Post: Qaranc
  Tailgate LED Martz66 5 6,617 12:th-Nov-2018, 13:35:27
Last Post: Martz66
  Help, doors wont open! ixlix 2 4,614 18:th-Jun-2018, 08:24:51
Last Post: ixlix
  Rear tailgate bulb Jon3sy 4 6,318 16:th-Sep-2017, 14:41:20
Last Post: Jon3sy
  Lock/Unlock buttons AlanMac 8 9,180 29:th-Aug-2017, 22:20:47
Last Post: AlanMac
  Lights on when you unlock the car?? chrisb2511 9 12,375 11:th-Sep-2016, 18:39:07
Last Post: bhalay207
  Astra 1.6 clutch judder after being stuck in traffic tina r 3 11,840 6:th-Aug-2016, 23:13:10
Last Post: marcus
  Unlock trip computer Daz21 14 15,047 19:th-Feb-2016, 13:31:35
Last Post: Daz21
