doors help open wont
Help, doors wont open!
Hi everyone, i have a 2013 J OPC with doors that will no longer open from inside or out. Im limited to getting in and out via the boot.
I took the door trims off to put in new speakers and sound deadening on the metal skins. With everything back together now the doors wont open from inside or out. The central locking seems to make the normal sounds, the interior handles pop up the door pins so the cable is still connected (even without the cable connected i could open the door from the outside with the door trims off).
Is there a fuse i could of blown that has caused the deadlocks to stay on? Could the layer of sound deadening be stopping the locks from releasing somehow?
Im stumped and not sure what to do next.
Alex
I've just replied to your other post but you could check K3 relay in rear fuse board
https://www.vxoc.org.uk/forum/Thread-Fus...3#pid11163
I dont seem to have the K3 relay in there, just the K4. I checked the number 10 30a fuse under the dash and it rattles, but when I remove it the central locking no longer works so I'm assuming it's still good.
  Diesel door wont opel Arkanggel10 2 4,217 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  Astra j bonnet won't open help Paul in sheppy 2 5,467 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  New Fuel filter. Wont start SALMHAGE 1 4,483 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  Tailgate Stuck Shut and wont unlock HELP luvie 5 13,938 18:th-May-2018, 07:25:21
