toffc - Replies:
Astra J 2.0cdti Wont start
Hi Just broken down my Astra J 2.0 Cdti stopped at lights then would not start. It turns over and seems to catch but then turns over more quickly but will not run. I checked to see if the starter still turns the engine when it goes more quicker and it does......anybody had similar not sure if its electrical or mechanical?
gazz292 - Replies:
CD400, in meriva B, mid-speed can-bus off, wont allow can learn
Wondering if anyones had this before?
2011 meriva B (1.3 cdti) CD400 with GID,
always been getting the following code on the radio: U0074
[attachment=978]
The other 2 codes are for the IPC, as im still messing with it...
but i was getting that U0074 code when i only had an op-com for diagnosis, so it's not the clone tech2 giving a fake code, and i was getting it before i ever touched anything electrical in the car.
The Tech2 gives an option to do a can bus re-learn on most module
luvie - Replies:
Tailgate Stuck Shut and wont unlock HELP
Hey all,
Wonder if any of you can help us,
We had a little trouble with the tailgate not closing so i cleaned up the mechanism and sprayed it etc and it worked perfect for a few months, now its stuck shut.
The central locking is working fine except you cant hear the click in the tailgate, I checked the fuse and its fine.
I have all the plastics and trim off and for the life of me I cannot find the switch to open it manually.
Can any of you kind souls help.
TIA
ixlix - Replies:
Help, doors wont open!
Hi everyone, i have a 2013 J OPC with doors that will no longer open from inside or out. Im limited to getting in and out via the boot.
I took the door trims off to put in new speakers and sound deadening on the metal skins. With everything back together now the doors wont open from inside or out. The central locking seems to make the normal sounds, the interior handles pop up the door pins so the cable is still connected (even without the cable connected i could open the door from the outsid
New Fuel filter. Wont start
Hi.
Did change fuel filter, dident fill up de filter with diesel and now i have problem starting.
Someone post a picture of a sqrew to turn a half turn. That worked last timme but now the picture is gone.
Someone know what screw?
/Astra j 1.7 CDTI
Diesel door wont opel
Hi guys, anyone know a trick to open the diesel door that is stuck and wont open?
