nipples? brake bleed
Brake bleed nipples?
hi there!
appears that I have rounded bleed nipples on my calipers, does anybody know the part numbers for them? have looked on ebay but only seem to be able to find nipples for the Astra H! does anybody know if these will fit?
Many thanks!
(25:th-Apr-2018, 10:26:11)Jake Wrote: hi there!
Many thanks!
as long its its not vxr I think you need 93172175
Can't find anything anywhere! All eBay has is ones for the older models. Mine isn't a VXR, its a 1.4 Turbo SRI
They are only about £4 from vauxhall
GM PART NUMBER DESCRIPTION RRP PG QUANTITY
93172175 VALVE, BLEEDER, CALIPER, M10 X 29 £4.74 5
ah cheers! will get onto perrys tomorrow!
  Brake pedal sensor learn. Richiew1986 0 1,316 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 2,821 25:th-Apr-2020, 07:41:05
  Rear brake pads and discs everson38 4 3,693 28:th-May-2019, 10:53:57
  Jolt when releasing brake on autobox Djones55 3 3,776 21:st-Oct-2018, 10:42:34
Last Post: Canasta
  Rear brake disc size Daniel199025 0 3,525 17:th-Sep-2017, 22:15:55
Last Post: Daniel199025
  Wheel Noise Following New Brake Pads & Discs GJH1985 5 5,134 24:th-Jul-2017, 10:12:34
Last Post: GJH1985
  Astra Electric parking brake BZone1 16 32,114 21:st-Dec-2016, 08:59:09
  High Level Brake Light? steve7 15 22,169 16:th-Dec-2016, 01:26:08
Last Post: irishastraowner
  Front brake pads replacement Phild82 3 4,209 16:th-Sep-2016, 05:15:24
Last Post: Phild82
  Brake dust cover rattle ryanh1008 0 3,107 30:th-Jul-2016, 13:27:28
Last Post: ryanh1008
cpeter53 (10:th-Oct-2023, 06:47:57)
