Bleed Radiator Help
I have an Astra J 1.4 turbo which the other week I knocked a hose off which is held on with a little plastic clip and radiator coolant was pumping out like a fountain (as car engine was running). It is the hose that T off another hose and leads to the expansion tank (smaller pipe), as I said the T hose is held on with a little plastic clip. [Image: https://uploads.tapatalk-cdn.com/2018021...d8d84a.jpg]
[IMG]https://uploads.tapatalk-cdn.com/20180219/1ddf4a9a214f531aa758
Brake bleed nipples?
hi there!
appears that I have rounded bleed nipples on my calipers, does anybody know the part numbers for them? have looked on ebay but only seem to be able to find nipples for the Astra H! does anybody know if these will fit?
Many thanks!
