gauge temperature
Temperature gauge
Just been out for a hours drive and the temp gauge only went up to quarter of the way , then on the way back the gauge was reading cold and then got a message saying that ac has been tuner off due to high engine temp. I stopped and checked the coolant levels but that seemed fine. Any advice would be great as I’m not too good with mechanics but if it’s a fairly easy fix will have a go myself as funds are a bit tight lately.
I would recommend you got it plugged on and see if any codes are present that's the best starting point.
It could be the thermostat at fault.
Knowing what engine you have would also help.
  Boost Gauge Andy1874 4 6,942 25:th-Jul-2020, 17:56:32
Last Post: Nubby
  Engine Temperature kfalvey 2 5,581 27:th-Mar-2017, 06:42:14
Last Post: Sc0tty05
  Temp gauge kippax 11 16,857 11:th-Jan-2017, 09:55:26
Last Post: kippax
  Fuel Gauge Indicator Farrael 7 10,277 10:th-Aug-2016, 10:01:31
Last Post: bhalay207
  One Gauge Or Two? SI SRI 6 11,480 21:st-Aug-2014, 10:54:18
Last Post: SI SRI
