gauge temp
Temp gauge
Hi all
Merry Xmas to all vxoc members.
My j continually shows either -39/40c but never the correct temp. Is there a way to reset the gauge.
Kippax
Sent from my SM-T555 using Tapatalk
Are you on about the outside temp?
Yes
Sent from my HTC One M9 using Tapatalk
It shows the temp on the screen.
Sounds like the sensor has gone faulty it would need changing, it's located in the lower front grill
OK. Are they available on eBay. Are they easy to fit.
Kippax
Yes here you go http://www.ebay.co.uk/itm/Vauxhall-Vectr...SwofxUgc7O
Bumper off job.
Thanks for the info.
I have a spare temp sensor I can send to you for free if you're UK based?
Yes . Leyland Preston
(25:th-Dec-2016, 09:29:24)Rusty2009 Wrote: Yes here you go http://www.ebay.co.uk/itm/Vauxhall-Vectr...SwofxUgc7O
Bumper off job.
just ordered one myself as im sure mine is not reading correctly, can this be fitted with the bumper on or has it got to come off?
Mine showing the right temperature because in the morning it was damn cold
Update on temp sensor. It had somehow been disconnected. Surprise, surprise now it's been connected it now reads correct temp!!!
  Boost Gauge Andy1874 4 6,933 25:th-Jul-2020, 17:56:32
Last Post: Nubby
  Temperature gauge Pg1710 1 4,610 10:th-Apr-2018, 07:51:14
  Fuel Gauge Indicator Farrael 7 10,275 10:th-Aug-2016, 10:01:31
Last Post: bhalay207
  One Gauge Or Two? SI SRI 6 11,472 21:st-Aug-2014, 10:54:18
Last Post: SI SRI
