indicator gauge fuel
Fuel Gauge Indicator
Hi!
I've an Astra J Sports Tourer 1.7CDTI and i've a little question about the fuel gauge indicator.
When I make a corner I notice the fuel gauge indicator moves a little but when it gets straight the gauge doesn't move to the previous position, like i've lost fuel.
It's common happening this?
Regards!
Hmmmm could be you don't have baffles fitted in the tank? Have you ever heard fuel sloshing about when you have a full tank?
(9:th-Aug-2016, 13:27:42)sheppy1 Wrote: Hmmmm could be you don't have baffles fitted in the tank? Have you ever heard fuel sloshing about when you have a full tank?
I think I heard, when I had full tank a strange noise coming from the back, knowing that the noise was from the tank, like a drum, when braking.
Yeah sounds like you don't have baffles which means the fuel will move around the tank a lot. My 1.7 didn't have them either but the car was brand new and I got vauxhall to add baffles to the tank right away... So I never saw any fuel needle problem but I'd say that's your issue as I have the baffles now and never seem the needle move like you describe
Now I see that the cause for this "problem"...
Thanks!
Mine when it's full also makes a lot of noise...
Is it too expensive to add those baffles?
Enviado do meu SM-G935F através de Tapatalk
Yep! That's the lack of baffles. I've no idea mate... Vauxhall did mine free under warranty
I've never noticed but mine was sloshing around yesterday after I filled it up. I thought the baffles were only an issue on the 1.7 and not the 2.0?
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,725 21:st-Oct-2024, 18:22:15
  Threaded Mode Diesel Fuel guage erratic low fuel and then half tank caretaker 1 5,162 30:th-Dec-2022, 17:32:20
  Fuel pump needs priming? Amazingusername 3 4,411 21:st-Mar-2021, 20:34:09
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,272 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 6,435 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  Fuel Shutoff Valve NuttySqurill 1 3,749 12:th-Aug-2020, 07:58:08
  Boost Gauge Andy1874 4 6,949 25:th-Jul-2020, 17:56:32
Last Post: Nubby
  1.7cdti drinking fuel Hazard10 2 5,196 9:th-Jan-2020, 22:13:15
Last Post: Peckalz
  New Fuel filter. Wont start SALMHAGE 1 4,486 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  How to change Astra j fuel flap mechanism? Amazingusername 2 6,078 11:th-Oct-2019, 12:56:58
Last Post: Amazingusername
