to j mechanism? fuel astra flap how change
How to change Astra j fuel flap mechanism?
 As above can anyone walk me though how to change the mechanism???
It's simple you jack up your car,
Remove your right rear wheel,
Remove the inside wheel liner,
And then you will se the locking mechanism
Poslano sa mog VOG-L29 koristeći Tapatalk
I bought the new mechanism from Vauxhall and it’s the whole flap hinge and everything minus the painted flap, doesn’t look an easy job tbh??
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,267 21:st-Oct-2024, 18:22:15
  Threaded Mode Diesel Fuel guage erratic low fuel and then half tank caretaker 1 4,863 30:th-Dec-2022, 17:32:20
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,400 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 4,045 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Vxr bumper on 5 door Astra j Sh4rk2007 10 14,543 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,481 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,734 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,260 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Fuel pump needs priming? Amazingusername 3 4,166 21:st-Mar-2021, 20:34:09
  Astra J Fault code reader suggestions Euroshopper 1 5,132 22:nd-Feb-2021, 08:50:12
