SI SRI - Replies:
One Gauge Or Two?
Really considering a boost gauge and putting it into a pod on the A pillar. Should I just go for one gauge or two but if two what other to go in pod with boost?
Farrael - Replies:
Fuel Gauge Indicator
Hi!
I've an Astra J Sports Tourer 1.7CDTI and i've a little question about the fuel gauge indicator.
When I make a corner I notice the fuel gauge indicator moves a little but when it gets straight the gauge doesn't move to the previous position, like i've lost fuel.
It's common happening this?
Regards!
kippax - Replies:
Temp gauge
Hi all
Merry Xmas to all vxoc members.
My j continually shows either -39/40c but never the correct temp. Is there a way to reset the gauge.
Kippax
Sent from my SM-T555 using Tapatalk
Speaker wire gauge
Wondering if anybody knows the wire gauge going to the door speakers. I'm assumings it's equivalent among astra/insignia since basically the whole cd400/dvd800 seems identical. If it's 20awg or thicker I suppose there's very little point in running new wires from the amp vs extending them from behind the headunit and then to the amp.
Boost Gauge
Own a 2.0 CDTI GTC.
Looking at installing a boost gauge.
Anyone done it? How did you run the tube from the engine bay to the gauge in the cockpit?
Pg1710 - Replies:
Temperature gauge
Just been out for a hours drive and the temp gauge only went up to quarter of the way , then on the way back the gauge was reading cold and then got a message saying that ac has been tuner off due to high engine temp. I stopped and checked the coolant levels but that seemed fine. Any advice would be great as I’m not too good with mechanics but if it’s a fairly easy fix will have a go myself as funds are a bit tight lately.
Nubby - Replies:
Boost gauge.
Just installed a boost gauge in my astra J 1.6 turbo. I'm far from a mechanic but managed with help from youtube. Anyone stuck on theirs give me a shout and I will try and help.
Temperature gauge and engine shaking
the problem is with my car but the temperature gauge is fully maxed out so am guessing there’s something over heating but just what and when I turn the engine on it doesn’t start sometimes and when it does the the engine starts shaking any chance you know what the problem is Would hugely appreciate it
