Changing temp from F to C
Hi everyone , on the radio display how do I change the outside temp display from Fahrenheit to Celsius
Thanks in advance ....Cheers....
Show us your outside temp!
Temp gauge
Hi all
Merry Xmas to all vxoc members.
My j continually shows either -39/40c but never the correct temp. Is there a way to reset the gauge.
Kippax
Sent from my SM-T555 using Tapatalk
Outside temp display
Noticed that on my 2015 Astra I have no outside temp display showing above the radio display, is there a fix for this I.e faulty fuse or sensor.
GTC Coolant temp sensor
Daughter's 2012 GTC had what I thought to be a faulty coolant temperature sensor. Error shown on display and fan running at full speed constantly. Purchased a new thermostat with sensor included and connected it to the cables (before going to the trouble of fitting thermostat to engine block) to test.
The same error was still shown on the display, and the fan ran at full speed.
Sensor resistance very similar to the fitted one. (17 ohms) at room temperature.
Appear to be getting voltage
Failure Code 597, temp only 75 C
Hello
Astra J 2010 1.6 has servivce light on. Can be reseted by Menu button but comes back after 10 minutes. Code reader gives code 597 - related obviously to thermostat. Engine temp does not come higher than 75C, normally about 90C.  Both upper and lower cooler hoses are warm but not hot. Heater and ac works normally (blowing warm air). Runs smoothly all seems to be OK. Please help whether this is typical failure and where to start to fix it. Does this engine have electrical controlled/heate
P0128 2 weeks after replacing temp sensor
I have a 14-plate 1.6 Astra Auto.
Recently got the "AC Off Due To High Engine Temp" warning, and an OBD II dongle said it was a P0128.  At the same time the temp gauge went to minimum.  Checked under the bonnet and the fan wasn't running even though we watched the coolant temp run up past 90C.
I'm no mechanic, but my local independent garage swapped out the engine temp sensor, topped up the coolant, cleared down the error code, and everything was back to normal.  Indeed after driving
Oil Temp and pressure sensor
Hi, i just activate menus on IPC for oil temp and pressure, boost pressure.. anyone have this working on Astra J? It is maybe possible to retrofit some sensors for Oil temp and maybe transsmision oil temp? I think this will be usefull..
