engine temperature
Engine Temperature
New Astra owner. First time poster.
I bought an Astra J 2010 1.6 SE recently. Within a few weeks the low coolant warning came on the dash, the level only dropped a little also fan wasn't kicking in and engine seemed very hot after only a short drive. Dealer replaced the thermostat and housing, within sales warranty, which had leaked some coolant and tested the fan as well.
I have only done a couple of 5 minute 20-30mph drives since, but each time have checked the engine because I am nervous and I can't hear the fan. The engine is getting really hot (to the point where rain drops are boiling when they hit it) after only that short drive. Temp gauge stays at 80C. Also the fan only kicks in for about 10 secs and goes off (presumably because it has cooled below the thermostat temp during that 10 secs). I am basing this on my previous car which never got this hot and the fan would more or less always be on once heated up.
Can anyone tell me if it is normal for the engine to be this hot. I am worried its going to overheat and blow the head gasket.
I can't say it's the same as I have the 2.0cdti.
Only real time I know my fan is on is when it does a regen other than that I've not heard it. My temp gauge sits at 90 all the time the car does get upto temp quickly.
I have the same issue with my 1.6 2010
Was getting a message saying service vehicle soon. Used the diagnostic tool and it pointed to the thermostat. I changed it and the coolant and the error message has suppressed now and fan doesn't come in full pelt any more but the engine still smells roasting hot all the time ??
Sent from my Pixel XL using Tapatalk
  1.4T Engine noise Nathan191210 1 3,911 29:th-Jun-2021, 09:05:07
Last Post: jay2801
  Please advise - Z16LET engine (1.6 turbo, 132 kW) - is it a direct or indirect port? UseThe4s 2 8,375 18:th-Apr-2021, 09:58:47
Last Post: UseThe4s
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 55,614 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
  1.6 cdti engine reliability Loddy Jeff 7 21,270 9:th-Jul-2020, 22:04:47
Last Post: Loddy Jeff
Shocked Spanner Light illuminated with engine off Wwood1991 2 5,970 11:th-Feb-2020, 13:01:57
  New Engine Needed ? Breengin 19 15,620 14:th-Mar-2019, 08:48:57
  Squeek/Rattle when starting engine Wabe_IV 4 6,749 7:th-Feb-2019, 12:15:33
  Noise when turning engine off Marc_81 6 9,638 30:th-Jan-2019, 20:46:28
Last Post: Marc_81
  Engine Oil. THOMAS123 2 5,049 7:th-Oct-2018, 21:43:14
Last Post: THOMAS123
  engine hunting marky79 3 6,244 1:st-Oct-2018, 21:28:12
Last Post: Brnjas
