to window manual help conversion? electric
HELP! Electric to Manual Window Conversion?
Hi guys, after a bit of advice!
I’ve had to replace the whole OSR door on my J, however the newer one comes with electric windows whereas mine were originally manually operated. Is this easy to put back to manual? I dont want to spend extra making the electric work for one side! Is it a straight swap from the old door to new one?
Many thanks!
Yes it's very easy to do a couple of bolts and releasing the glass ring with a screwdriver. make sure you swap the loom over also.
Thank you! Does the window mechanism have pop rivets? If so, what size does it use do you know?
No it’s bolts no rivets .
Thank you! ?
Your welcome.
If you get stuck just holla.
Hi there, really struggling to get the manual window winder off to change the door cards! Can anybody help? Have tried pulling and pulling but nothing, tried the rag trick but still no joy, doesnt even appear to be a clip on there?
I have struggled myself with these it's just a case of persevering I'm afraid
Got it in the end!! Another question, sorry to keep asking but i want to get it right!
Does anyboy have a howto on removing the window regulator for both manual and electric windows? I’m not able to connect the electric one up and operate the mechanism though!
Struggling to find the “glass ring” that somebody mentioned before xD
https://workshop-manuals.com/vauxhall/as...placement/
(9:th-Apr-2018, 07:12:17)Jpbroad1970 Wrote: https://workshop-manuals.com/vauxhall/as...placement/
How can i do that without adjusting the window? As the mechanism ok the electric ones cant be operated!
If it were me I would smash the window on the electric one then swap manual reg and glass to replacement door, severe I know but it may help with getting regulator out.
power the motor to lower the window, just a couple of wires and a battery required
Still no joy. The links someone posted mean nothing to me and dont work on my phone!! Anyone??
Also having trouble getting the door handles to go back onto the door, get it all lined up and start to tighten the screw, yet nothing.
I’m about ready to set fire to this car for the insurance money!
  Tesla Touchscreen Conversion JYewman 0 2,972 12:th-Feb-2021, 17:54:39
Last Post: JYewman
  Astra J workshop manual Euroshopper 1 6,868 9:th-Jan-2021, 08:09:36
  Electric passenger window not working Harposaurus 2 6,121 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
  Electric Window intermittent problem Stanhope 3 7,639 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  electric rear windows marky79 5 7,478 11:th-Jan-2019, 09:04:32
  GTC water collects under rear window Canasta 2 7,277 30:th-Oct-2018, 22:23:04
Last Post: marky79
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 19,525 26:th-Sep-2018, 23:50:59
Last Post: everson38
Sad Rear electric windows & front fogs problems... Griifter 18 15,716 30:th-Aug-2018, 20:01:30
Last Post: Griifter
  Rear window Mspencer 3 7,268 10:th-Jul-2018, 03:58:40
Last Post: Mspencer
Big Grin electric connections kipper 4 6,093 21:st-Dec-2017, 10:40:27
Last Post: kipper
